Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 10-14-2003, 04:56 PM
Andy's Avatar
Andy Andy is offline
Mein auto: E30, M3, 540i
Gary : Hoosier A3S03 Fitment Question
Hi Gary,
I have a couple of questions for you...
1.) Will the Hoosier A3S03 245/35ZR18 fit on my 8" x 18" and 8.5" X 18" wheels?
2.) If I put the 245s up front, do you think I'll have any problems with the tire rubbing?
Thanks,
Andy
- 1987 BMW 325is
- 2002 BMW M3
- 2003 BMW 540i Sport
Old 10-14-2003, 05:07 PM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein auto: a BMW killer
1) yes
2) no
I wouldn't advise a noobie to start out on Hoosier rubber in a stock BMW but it's your hard earned money to cord away, you'd be better off staying on street tires if you buy that other set of wheels/tires
Please note that the 2003 DS National Champion (Ron Bauer) won on Kumhos in a 330i, healso beat the top 330i Hoosier driver every event they ran against each other, both are top national level drivers
Old 10-14-2003, 05:23 PM
Andy's Avatar
Originally Posted by TeamZ4
Please note that the 2003 DS National Champion in a 330i won on Kumhos
Dude, you're pimping ( ) those Kumhos pretty hard. I would take those things off your hand pretty darn fast if they weren't staggered sized. I am still thinking about it though.
Are you sure the 245s won't fit up front? I thought I heard someone doing that in a 3er.
EDIT : Will the 265/35-18 Kumhos fit my 8.5" x 18" rear wheels? If so, will they fit up under the rear of my car without rubbing?
- 1987 BMW 325is
- 2002 BMW M3
Old 10-14-2003, 05:36 PM
TeamM3's Avatar
no they won't rub or if they do it's insignifcant, yes they will fit,
see edit above which occurred while you were posting, my concern is not just for selling you Kumhos, I hate to see noobies make the same basic mistakes over and over again
a) Hoosiers require much more setup equipment and driving skill to be worthwhile
b) You have a lot to learn before making that step, you need to be learning how to control the vehicle properly and other techniques than focusing on max grip, etc. Simply installing larger front tires is not the answer.
but that's just my opinion based on competing nationally on Hoosier DOT radials since their inception in 1996 with Stock BMW's.
Old 10-14-2003, 05:53 PM
Andy's Avatar
You're referring to the 265s on the rear, right? I wasn't sure if you saw my edit above.
I do appreciate the advise. Thank you.
Check your PM.
- 1987 BMW 325is
- 2002 BMW M3
Old 10-14-2003, 07:10 PM
nate's Avatar
nate nate is offline
I like cookies.
Mein auto: 328Ci
repeat after me:
"Novices should not use Hoosiers or any other track tire."
"265s in the rear = extreme understeer."
Old 10-14-2003, 07:46 PM
TeamM3's Avatar
have to disagree with you, the Z4 3.0 Sport comes with the same size wheels/tires as the 330i ZHP and 18" option (18 x 8, 225/40f 18 x 8.5, 255/35r) and the handling balance with the Kumho's is equal or better than the OE tires, the 265/35 is essentially the same size as the original 255/35 tire. The handling balance on the 330i ZHP is well documented. Going to a 265/35 IS NOT going to suddenly create extreme understeer.
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
