E46 (1999 - 2006)
Old 09-04-2016, 01:06 PM
vinzchau9 vinzchau9 is offline
Mein Auto: BMW E46 Couple
BMW E46 323 - Whining/Howling noise from drivers side rear
Hi All,
Over the last month I have been experiencing a slight whining/howling noise coming from the rear drivers side at around when I shift into 4th gear at around 30mph. This noise then goes away once I am in gear and drive on. Also I have tried coasting at around 30mph and the noise is still audible. When I de-accelerate to 30mph the noise is audible too.
At first I thought it might be tyre noise, however I have rotated my rear tyres with my front tyres and there has been no change. This then led to me thinking it could be a differential issue, so I changed my diff fluid using Redline Synthetic Gear Oil (75w140) and put in liqui moly gear additive in the hope it would quieten the noise, however this has not worked.
Could it be something further with the diff like a bearing wearing out or gearbox/clutch related?
Old 09-07-2016, 09:20 PM
Y2K_Bimmer Y2K_Bimmer is offline
Mein Auto: 2000 323i
Wheel bearing would be a good place to start.
And 4th gear at 30 mph? jk
323, bmw, bmw e46, differential, drivers, e46, noise, rear, side, whining noise, whining or howling
