Looking to get some great BMW parts for your car? Get the latest info on sponsor group buys, new products or simply ask a site sponsor a question here!
Old 05-21-2012, 12:41 AM
BMWonderz BMWonderz is offline
Mein Auto: 328i
Hey Technic,
I received your harness... I've decided on not getting the BSWs, because I forgot I still have an amp lying around!
http://www.crutchfield.com/S-W45YSDf...ml#details-tab
From just looking at the manual and figures, looks like the harness will work for the amp; however, I was wondering: the fuse this amp requires is a 50-amp AGU. But I've read a couple of threads suggesting not using AGU amps. What would you recommend? And can you verify that this amp will work with the harness?
Thanks and sorry for bombarding you with questions.
P.S.
Technic, thanks for the fast and speedy transaction and shipping! You bring great customer satisfaction. Thanks again.
Old 05-22-2012, 01:24 PM
ankurg09 ankurg09 is offline
Mein Auto: BMW 530i
Hey Technic,
Need some clarification on the setup.
Please correct me if I am wrong , There are 2 female RCA ends on the harness. Now in a setup where I'm just adding an external amp and trunk sub I would just use Male to male RCA , plug it into the harness female ends and to my amp? Under seat subs will still be powered through logic 7 amp?
Now for a setup where I have already added a trunk sub and amp but want to upgrade under seat subs and power them with another external amplifier , how would the wiring work ?
Would I be splitting the female ends on harness and pass into 2 amps? and If i do so would i have to run the woofer wiring from amp to the cabin or would I have to splice into the harness to send power to under seat subs using the existing wiring?
Hope my question makes sense.
Old 05-22-2012, 01:29 PM
Mein Auto: BMW 530i
Smile
Originally Posted by ankurg09 View Post
Hey Technic,
Seems like I should be able to use the harness to send the power to under seat subs , guess will figure it out once i receive the cable.
Old 05-23-2012, 09:13 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Hey Technic,
The harness itself is sub-split into two connectors for the underseat woofer, as shown in this photo: http://www.bimmerfest.com/forums/sho...4&postcount=51
As shown in that photo above, there is a pigtail connector included in the harness/LOC kit. The pigtail is wired to your aftermarket amp outputs to the underseat woofers. Then the pigtail is plugged into the harness sub-connector.
The aftermarket amp will be powering the underseat woofers after that.
Old 05-28-2012, 05:18 PM
Dark5yde Dark5yde is offline
Mein Auto: 03' x5 3.0i
I have a 03' X5 with the basic "hifi" 10 speaker no sub setup. Do you have a harness I could use to add in a aftermarket amp and sub? If so how much? Thanks in advance.
Old 05-29-2012, 03:25 AM
Technic's Avatar
Mein Auto: 2017 M3
I need to see your OEM amp connector to determine if I have something that matches it. This thread is for Logic7 and E60 5-Series HiFi systems from 2004-on.
Old 05-29-2012, 01:13 PM
Mein Auto: BMW 530i
Hey Technic,
Thanks a lot , your harness saved me a lot of trouble. Worked like a charm.
I do have a question for you though regarding sub and amp , I bought the following subs and amp .
Amp --- http://www.rockfordfosgate.com/produ...?itemid=233190
Sub's --- http://www.amazon.com/Rockford-Fosga...8318756&sr=8-1
I am not really happy with the output. I mean I have the bass but it isn't great and tight. Its Boomy. I would like to have a setup with Clean and tight bass, also would like the ability to turn it loud when showing off So just wanted to get your opinion what Amp and sub/subs would you recommend. I still have plenty of time to return my current Subs and amp.
Pics of Dynamat trunk & installation coming soon.
Again Thanks a lot for the Harness man Great job.
Old 05-30-2012, 09:15 AM
Technic's Avatar
Mein Auto: 2017 M3
You need to compensate/tune somehow your total system for the new sub inclusion. If you kept a high level of bass adjustment at your OEM HU/iDrive then the new sub may sound boomy like that.
Hey Technic,
Old 05-30-2012, 11:45 PM
bigballa765 bigballa765 is offline
Mein Auto: 06 BMW 750LI
Does anyone have pictures of the harness installed and does anyone have a diagram or pictures of where the seat subs are located. Only reason I ask is my installer who is also a friend is putting my sub in Friday and I want my original amp powering the factory subs in the seats and not the logic. So want to kind of a have an idea where they are just in case he doesn't know thanks. Also how did people tune their logi 7 head unit to get the best sound in addition to the sub they installed? Thanks.
Old 06-03-2012, 07:14 AM
Technic's Avatar
Mein Auto: 2017 M3
The underseat woofers are located... under the front seats.
The Logic7 harness includes a sub-connector that allows the underseat subs to be powered by the OEM amp after the addition of a trunk sub. No need to rewire anything. That's the harness standard configuration: http://www.bimmerfest.com/forums/sho...4&postcount=51
Old 06-04-2012, 06:41 PM
Thanks.
I just wanted to thanks Technic for the harness. My installer got it put in he did things a little different by tapping into the underseat subs for the signal but everything works great. For those of you who think the noise cancellation in our cars hurt the bass it doesn't. My 15" along with the stock clarity is awesome. The only thing I hate is that the head unit in our cars doesn't go all that loud leaves a little to be desired. Thanks again Tech.
Old 06-22-2012, 02:39 AM
Technic's Avatar
Mein Auto: 2017 M3
Bump...
Old 06-29-2012, 12:27 PM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
I am interested in a harness. I have an 09 1 series w nav. Do you offer step by step instructions on how to plus in your harness with pictures ?
Old 06-29-2012, 11:57 PM
E7forty5 E7forty5 is offline
Mein Auto: 2003 745LI
Been looking for something like this! 03' 745LI Logic7
Old 07-01-2012, 01:43 PM
Technic's Avatar
Mein Auto: 2017 M3
No harness instructions are provided as this is PnP...
Old 07-04-2012, 04:54 PM
mpw70 mpw70 is offline
Mein Auto: '07 328xi
Just got my first BMW, '07 328xi sedan with Logic 7. I have been frustrated with what I believe to be the processing of the Logic 7 amp. The sound seems to fade in and out in a subtle way in Logic 7 "Music" mode. When I turn Logic 7 off there are no issues so I believe it to be how the Logic 7 processor is working. I am on my second amp as the dealer replaced the first one for me. Similar issues with second amp although not as bad. Is this normal? If so, I might need a Technic harness to upgrade to the JBL MS-8 as it sounds like that is optimal. Please provide some feedback on this issue so I can point myself in the right direction for upgrades.
Old 07-05-2012, 09:55 AM
Technic's Avatar
Mein Auto: 2017 M3
First, you will replace one Logic7 with another Logic7 processor. Second, the harness that I sell will have to be modified to add the MS-8, it is not PnP.
Please PM for details and price.
Old 07-07-2012, 07:35 AM
Thanks Technic for the harness! My 7 sounds like it should now! I also appreciate the fast shipping, even with the holiday I had it on day 3 of order! I'm very pleased!
Old 07-16-2012, 09:02 AM
thewarlock666 thewarlock666 is offline
Mein Auto: '08 335i
Interested in buying, sent you a pm
Old 07-20-2012, 01:18 PM
capnmorganxx capnmorganxx is offline
Mein Auto: 2012 X3 35i F25 MSport
Any change this will work for a '12 F25 X3 with premium sound?
Old 07-23-2012, 10:24 AM
badboyt badboyt is offline
Mein Auto: X5 4.6is, M5
I am planning to install this rockford fosgate punch r500-2 with Kicker sub into my 2011 X5M, and was wondering if your harness would work? Thx for all your help!
Old 07-23-2012, 10:55 AM
jkidem's Avatar
jkidem jkidem is offline
Mein Auto: 745Li
anyone got this to work in E66 non L7 setups? i got the harman\becker OEM amp in the back but its the half the size of the L7 one but the connectors look the same??
2013 328i M Sportline
2003 745li sold
2000 528i sold
Old 07-24-2012, 11:06 AM
Af335i Af335i is offline
Mein Auto: 2011 335i M sport Coupe
Technic I sent you a PM from af335i. Get back to me when you can plead
Old 07-25-2012, 01:06 PM
Technic's Avatar
Mein Auto: 2017 M3
Yes, as long as it is a 20-pin/9ch black connector at the OEM amp.
Old 07-25-2012, 01:08 PM
Technic's Avatar
Mein Auto: 2017 M3
Is your X5M equipped with the Individual Audio/16-speaker system?
