Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Mobile Electronics and Lighting
Car Stereos, Cell Phones, DDEs, HIDs, foglights etc...
Old 07-25-2012, 12:43 PM
chorn562 chorn562 is offline
Mein Auto: e92 m3
Hey, I have a 09 E92 w/ L7 and idrive. Just to clarify.. this will work with my vehicle right? I got a pair kicker c10s.. could you recommend an amp? Paypal is ready for your harness
Old 07-25-2012, 02:32 PM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Yes, it is for Logic7 systems...
Old 07-29-2012, 07:50 AM
mpw70 mpw70 is offline
Mein Auto: '07 328xi
Thanks for the harness Technic. It worked perfectly and made my installation very easy. Great product.
Old 07-30-2012, 02:50 AM
Technic's Avatar
Test... 1, 2 ,3
Much appreciated...
Old 08-01-2012, 05:55 PM
jceli728 jceli728 is offline
Mein Auto: e46
Originally Posted by Technic View Post
Yes, as long as it is a 20-pin/9ch black connector at the OEM amp.
Did anyone try this on the F25?
Old 08-02-2012, 07:16 AM
capnmorganxx capnmorganxx is offline
Send a message via Skype™ to capnmorganxx
Mein Auto: 2012 X3 35i F25 MSport
Nope, I haven't tried it on my F25 yet. I'm nervous about unplugging the harness from the amp. This isn't going to throw off any warnings that I'll have to return to the dealer to get reset right?
I'm starting coding on the vehicle now, but I'm nervous to just start unplugging wires.
I've done a ton of car audio installs, just not on a vehicle as computer controlled as the F25.
The amp according to the part list looks very similar to the x5 and other vehicles. I think it's the same thing..Anyone can confirm this for sure?
Old 08-03-2012, 02:21 AM
Technic's Avatar
Test... 1, 2 ,3
A photo of the OEM amp connectors-side in question here will help determine compatibility.
Old 08-03-2012, 07:50 AM
Any risk unplugging the amp connector? Is this going to set off any warnings on the computer as long as the vehicle is off?
Old 08-03-2012, 12:20 PM
Technic's Avatar
Test... 1, 2 ,3
The only connector that when unplugged can cause errors is the MOST (digital data fiber optic cable) connector in the OEM amp -but only if the car is on and there is in fact a MOST connector in that OEM amp.
If the OEM amp is analog -non-Premium systems- then the main connector can be unplugged regardless of the car being on or off. There are no data lines/fiber optic cables in the analog OEM amps.
In other words, any OEM amp connector can be unplugged without errors if the car is off. Just make sure that the car is still off when it is plugged back in for safeguard of all the components.
Old 08-03-2012, 06:30 PM
Ok all. Disconnected on my '12 X3 F25 with premium sound. There were three connectors on the amp. One large one, and two smaller (that look like power?)
Here are pics of the connectors, and the connections on the amp.
Thoughts on if this sub adapter will work?
Old 08-04-2012, 05:18 AM
Technic's Avatar
Test... 1, 2 ,3
Thanks.
Your OEM amp is a much higher power-output version than the "regular" Logic7/Premium sound systems. The telltale is the separation of the power and ground signals from the 20-pin connector. You can see that the first photo (20-pin connector) is missing 2-pins, and in your second photo you have a 2-pin connector by itself. The third connector is the MOST fiber optics.
With all that said, my Logic7 harness 20-pin connector and the pin assignments will match to your OEM amp connector. However there will be no remote turn on provided by the LOC as it requires the 12V and the ground to be at the 20-pin, and the LOC (line output converter) itself needs to be upgraded to an Audiocontrol LC2i ( http://rs.audiocontrol.com/company_38//LC2i_OM.pdf ) because of the higher output (100W+/20V+ peaks) of your woofer OEM amp outputs.
The LC2i may or may not provide the remote turn on signal as this high-power OEM amp type uses a different power supply and voltage configuration than other OEM amps that makes the signal sensing circuit of any aftermarket device useless.
Please PM for pricing details if interested.
Old 08-04-2012, 10:54 AM
Are there any other BMWs that have this type of amp system? Anyone have experience with an LCI2 or something like it?:
http://www.crutchfield.com/g_318850/...rocessors.html
I basically only need a 12V remote lead to get this working with your harness. Is this system similar to the 7 series with MOST like I've read previously?
Old 08-05-2012, 06:43 AM
Technic's Avatar
Test... 1, 2 ,3
The M3 has that type of OEM amp as an optional system. The LC2i is the LOC used with the harness in all higher-output Premium OEM sound systems as stated before.
Old 08-05-2012, 11:13 AM
Bajamcse Bajamcse is offline
Mein Auto: E92
Hi Technic,
New to this forum. I have a 2012 E92 with Harman Kardon and iDrive. I'm finding the bass lacking after initially being impressed. I wanted to go the BSW underfloor sub route but the shipping costs to the UK is stupid. So the next option for me is a regular trunk sub and amp. Could I request one of your harnesses please?
Old 08-06-2012, 01:01 PM
Ok so I made a call to Audiocontrol, maker of the LC2i and they confirmed none of their products will auto turn on using the signal sensing feature when it receives a subwoofer signal. It has to be a full range/higher frequency sound.
So the question is:
Technic- do you have any harnesses that are similar to this one that instead of the subwoofer line out, would provide a high range signal? It freaks me out a bit to tap into the factory wires to get the high pass signal.
I'd probably have to use a 6 channel audiocontrol unit to sum all the channels together to get the subwoofer channel. Any ideas on how to do this? I'd like to get a sticky written with this info for everyone with the new 2011+ X3 F25.
Old 08-07-2012, 03:57 AM
Technic's Avatar
Test... 1, 2 ,3
So the question is:
As stated before, the LC2i may or may not provide any remote out with your particular OEM amp regardless of which outputs you use. Most probably it won't so plan for that.
I do not sell any other Premium/Logic7 harness than the one in this thread, sorry.
If you are planning to add a trunk sub/amp then there is no need to sum any signals. The harness already have the correct wires/connectors for the required signals and the remote line can be tapped at the back of your iDrive unit (at pin 13, thin black wire). That's all you need.
Old 08-09-2012, 01:18 PM
1kenny3 1kenny3 is offline
Mein Auto: BMW 745i
want to buy one of your adapter plugs for amp... how can i do so..
Old 08-18-2012, 06:16 PM
lnswadecar lnswadecar is offline
Mein Auto: 2002 745i
would like to purchase for a bmw 2002 e65
can you give me a price quote and email to purchase a harness for my vehicle. Thank-you in advance.
Old 08-21-2012, 02:31 PM
Technic- Any idea which color wires would be the rear speakers for the F25? If I can figure out exactly what I'm doing/if it can be done to add an LCI2, I will be pick up a harness. Looks like it's been done on a '11+ E92 M3
Old 08-22-2012, 03:33 AM
Technic's Avatar
Test... 1, 2 ,3
Please use PM... thanks.
Old 08-22-2012, 03:34 AM
Technic's Avatar
Test... 1, 2 ,3
There is no bass in the front/rear/center speakers in your F25 -they are all high passed. All the bass -low passed- signals are in the underseat woofers.
Old 08-23-2012, 11:12 AM
Sending you a PM Technic.
Old 08-26-2012, 08:33 PM
Jblaze516 Jblaze516 is offline
Mein Auto: 745li
How much is your harness? I have a 2004 745 li
Old 08-27-2012, 03:38 AM
Technic's Avatar
Test... 1, 2 ,3
http://www.bimmerfest.com/forums/sho...4&postcount=51
Old 08-29-2012, 02:27 PM
jalia43 jalia43 is offline
Mein Auto: 320d M Sport
Harness
Hi. My 320 has the logic 7 system in it and I would like to install an amp and a couple of subs in the trunk. I've been browsing for days in different forums trying to find a good solution and your harness seem to be the best solution there is. Clean and doesn't tamper with or damage the original system.
So a few questions:
So can you make a harness for my 320? If so how much is it?
Do I need to reprogram the system after the harness has been installed?
And finally how do I order?
