Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 02-09-2010, 04:31 AM
Chumpy Chumpy is offline
Mein Auto: BMW 745
DIY Reference - Battery registration
I'm looking to replace the battery in my 2002 E66, 745Li
I found the useful thread in the DIY section
http://www.bimmerfest.com/forums/sho...d.php?t=419230
However, it says "Don't forget to register the battery once the new one is in."
My question is...... HOW?
I heard this was a dealer only thing..... Is it?
Old 02-10-2010, 08:01 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Yep, registered mine with INPA (using a VAG-COM KKL interface). No problems. INPA has a more simple interface (and is easier to set up) than DIS. If you're a software guy, you should have no trouble getting this stuff running.
Also, find the thread in this forum (not the DIY forum) with the same title as the one you linked to. There is some useful info there (like the shortened version of replacing the battery -- gracias, Haz1).
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 02-11-2010, 11:22 PM
Mein Auto: BMW 745
Thanks to all that helped directly and indirectly with their posts on here.
I got INPA working with my E66.
Now just to find a new battery (90Ah AGM), and then find the option somewhere in INPA.
Cheers!
Old 02-12-2010, 06:12 AM
Mein Auto: BMW 745
I got INPA working, but my battery has finally died, so I'm ordering a new one from BMW.
Can anyone point me to where the option is in INPA to do the battery registration?
Old 02-12-2010, 03:47 PM
Master Tinkerer
Power module
Old 02-13-2010, 05:22 AM
Mein Auto: BMW 745
HI Keif,
Sorry to sound a bit dumb, but could you confirm which option it is in the Power Module bit?
I have the following
<F1> Information
<F2> Identification
<F4> Error memory
<F5> Read status
<F6> Activate
<F7> Read memory
<F8> Select
<F9> Print screen
Not sure which one is for Register battery.... Any info appreciated.
Old 02-13-2010, 11:08 AM
Mein Auto: BMW 745
Thanks to Keif and the folks on here for helping me with this.
Just to feedback.....
If you have INPA working, then select the following to Register the new battery
1. Select BODY from the left hand pop-up menu
2. Select POWER MODULE in the right hand list
3. Select ACTIVATE from the next menu
4. Another menu comes up, which has ACTIVATE1 and ACTIVATE2.
5. Select ACTIVATE2 from the menu
6. Then select F7 - Register battery replacement
Almost instantly you get the message:
"Register battery replacement Activated properly."
Job done!
Hope this helps!
Old 02-13-2010, 03:28 PM
Master Tinkerer
Might want to repost this or ask for it to be reposted in the DIY section. Surely many will find this useful! Good stuff, glad everything worked out!
Closed Thread
HTML code is Off
