Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 10-16-2003, 07:05 AM
joema joema is offline
Mein auto: 2003 330i SP sedan 5-spd
Right pull on Pilot Sport A/S
I just had the OEM ContiSportContacts on my 2003 330i SP replaced with same-size Michelin Pilot Sport A/S, on the same 68M wheels.
Alignment was checked shortly before this at a BMW specialty shop, and was OK.
With the Contis, the car tracked straight, except for the expected left/right pull based on road camber. On a flat road it tracked perfectly straight.
With the A/S, it pulls noticeably but not severely to the right, even on a flat, non-cambered road. Tire pressure is 32/38, per the door jamb placard.
I've heard of this before and seen it attributed to "radial pull". It's not severe, but I like it to track perfectly straight. Can the toe-in or other alighment be adjusted slightly to compensate for this and make it track straight? I wouldn't mind even if it shortened the tire life somewhat.
Old 10-16-2003, 07:16 AM
AF AF is offline
Here since day one
Mein auto: Corvette,C350, 650i,GL450
If the alignment is correct then I would give the tires a chance to break-in a little bit.
If you still have this issue as severely at 500 miles I would have it checked out but if it eases up a little bit then I would wait until you have 1000 miles to see if it gets better.
My best guess though is the tires are probably fine and your not used to the car tramlining *as much* and following the grooves as in comparison to the Conti's. The Conti's don't tramline nearly as much as any other tire I have had on my car (and I've had at least 4-5 different tires on my car).
Though it sounds like you are aware of these type of issues, unless you've actually experienced it first hand it might feel strange.
I am still surprised by how much my car tramlines when I switch tires . . .
Old 10-16-2003, 07:17 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein auto: M3 & 323i/999 KP
The Pilot Sport A/S drives VERY differently for the Pilot Sport. If it were not for the exorbitant cost, I'd recommend it to the more comfort oriented performance driver.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
1995 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1989 325is S50
Alpinweiß/Black
1988 M3
Alpinweiß/Black Basket Case
Old 10-16-2003, 12:03 PM
Yes for an ultra high perf tire, the A/S has a fairly soft and quiet ride. Wet traction is excellent. However turn-in and transient response is more sluggish than even the ContiSportContacts, a mid-grade summer tire.
But the only characteristic that really bugs me is the persistent mild right pull (not the road-groove tramlining). I'll give them another 1,000 mi. to break in.
The front wheels are currently in the middle of the toe-in tolerance band. I was just wondering if a little more left toe (but still within the band) would be compensate for the mild right pull.
Old 10-16-2003, 06:33 PM
ObD's Avatar
ObD ObD is offline
Mein auto: '08 535 6mt
Try upping the front air pressure. It will reduce under-steer and the tendency of the front end to push. Which is what I think you are experiencing.
A much cleaner place now that the trash is gone.
Old 10-17-2003, 07:05 AM
Thanks I'll try more presssure. However my main problem is a mild persistent right pull even on flat roads, not push (understeer).
However if more pressure improves turn-in and transient response without making the right pull worse, or unduly degrading ride quality, that would be good. I'll try it.
Old 10-17-2003, 08:07 AM
ObD's Avatar
ObD ObD is offline
The right pull maybe the understeer is all I'm suggesting. The rear end torque could be plowing the front end. I know by upping the pressure I reduced tramlining during the tire break in. I find the SP suspension very sensitive to air pressure and I can actually feel the difference in a 1 or 2 lb change.
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
