Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 02-20-2010, 09:05 AM
mmihailov mmihailov is offline
Mein Auto: 02 530I and 01 740I
01 740i - Right window rolls up but won't roll down
The right window of my 2001 e38 stopped rolling down. I could hear a click from the motor but no movement. I decided that the regulator or the motor broke, because I have had similar problem with my 530I which I fixed a year ago and bought a used window regulator with the motor for $100 on ebay. I trust the guy from whom I bought it. His ebay link is featured on the www.e38.org website. I installed it last night on my car and pushed the button to close the window up. The window went up fine and closed - the regulator came with the window brackets positioned half way down the rail tracks. However,the window won't roll down again. I hear the same click in the motor that came from it before I replaced the whole thing. I wonder if the problem could be coming from the switch, but why do I hear a click?
Any ideas how to proceed further with troubleshooting this problem? Thank you.
Old 02-20-2010, 12:12 PM
I got it working. I swapped switches and it works now. All windows work all right. I think the problem was a bad connection at the switch, but I might be wrong. Most likely I did not have to replace the window regulator though. I wish I thought about playing with the switches sooner.
Old 02-20-2010, 12:53 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
The regulators are common failures, you just did it proactively and can sit back and enjoy a working window for a while!!!
(I do my radiators every 60K miles for the same reason.)
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 02-20-2010, 02:47 PM
Right, that is my only consolation - that it would have broken down soon anyhow. I replaced my fuel pump for $230 a month ago thinking it was making a loud noise. It turned out that was not what made the noise. The noise was made by the pressure valve in the fuel tank for $16 only. Rather expensive way to learn but hopefully I get better with time.
