X3 E83 (2004 - 2010)
engine bay leak
I have an 08 with an oil leak showing up near the front of the engine. The oil is red. Is the transmission oil red? I haven't found the source of the leak yet or checked transmission level.
The power steering fluid may also be red. The power steering reservoir is located at the front, too.
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog 1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb BMW CCA #422951 |
I would look at the trans cooler lines towards the bottom of the radiator towards expansion tank. Also how thick is the fluid and what does it smell like? Is it more watery? If someone replaced the blue antifreeze with dex cool or g85 coolant it could be the expansion tank. The first two things that I would do is 1) remove the top engine cover (4 torx screws and intake snorkel to look around top of engine 2) get the car up on jack stands and remove bottom engine cover 4 17mm bolts by tranny and about 12 8 or 9mm bolts around the perimeter. This will allow you to get a good look of what might be happening. Last edited by x3brian; 12-05-2012 at 07:20 AM. |
