Off-Topic
Everything not about BMWs. Posts must be "primetime safe" and in good taste. No personal attacks allowed. Political posting is restricted to the Political Science forum! |
fugging script kiddies
does this seem excessive for a dialup connection Alert 10/17/2003 0:12:28 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (68.98.174.123,17300) Unknown 10/17/2003 0:07:35 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (213.103.76.95,2177) Process name is "N/A" Unknown 10/17/2003 0:07:35 IP Filter Trojan attempt detected from address 213.103.76.95 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 23:57:32 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.88.15.66,3150) Process name is "N/A" Unknown 10/16/2003 23:57:32 IP Filter Trojan attempt detected from address 24.88.15.66 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 23:51:25 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (68.13.198.146,17300) Unknown 10/16/2003 23:40:06 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (216.55.222.81,4419) Process name is "N/A" Unknown 10/16/2003 23:40:06 IP Filter Trojan attempt detected from address 216.55.222.81 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 23:36:08 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.67.103.184,1289) Process name is "N/A" Unknown 10/16/2003 23:36:08 IP Filter Trojan attempt detected from address 24.67.103.184 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 23:25:19 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (24.202.198.5,17300) Alert 10/16/2003 23:20:50 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (65.96.195.167,17300) Alert 10/16/2003 23:16:05 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (66.215.11.65,17300) Alert 10/16/2003 23:13:20 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (68.185.151.230,3223) Alert 10/16/2003 23:13:14 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (68.185.151.230,3223) Alert 10/16/2003 23:13:11 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (68.185.151.230,3223) Unknown 10/16/2003 23:12:32 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (212.121.160.217,49991) Process name is "N/A" Unknown 10/16/2003 23:12:32 IP Filter Trojan attempt detected from address 212.121.160.217 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 23:08:34 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.60.109.162,4823) Process name is "N/A" Unknown 10/16/2003 23:08:34 IP Filter Trojan attempt detected from address 24.60.109.162 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:53:11 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (63.163.233.124,1740) Process name is "N/A" Unknown 10/16/2003 22:53:11 IP Filter Trojan attempt detected from address 63.163.233.124 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:42:19 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (141.157.233.241,3077) Process name is "N/A" Unknown 10/16/2003 22:42:19 IP Filter Trojan attempt detected from address 141.157.233.241 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:38:50 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.94.120.4,4139) Process name is "N/A" Unknown 10/16/2003 22:38:50 IP Filter Trojan attempt detected from address 24.94.120.4 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:33:56 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (218.188.79.208,1424) Process name is "N/A" Unknown 10/16/2003 22:33:56 IP Filter Trojan attempt detected from address 218.188.79.208 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:33:20 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (4.17.158.10,28319) Process name is "N/A" Unknown 10/16/2003 22:33:20 IP Filter Trojan attempt detected from address 4.17.158.10 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:30:27 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (67.84.4.11,3576) Process name is "N/A" Unknown 10/16/2003 22:30:27 IP Filter Trojan attempt detected from address 67.84.4.11 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 22:07:53 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (172.176.162.6,3839) Process name is "N/A" Unknown 10/16/2003 22:07:53 IP Filter Trojan attempt detected from address 172.176.162.6 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 22:05:53 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (12.216.224.254,1454) Alert 10/16/2003 22:05:47 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (12.216.224.254,1454) Alert 10/16/2003 22:05:45 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (12.216.224.254,1454) Unknown 10/16/2003 21:54:19 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.194.13.169,3456) Process name is "N/A" Unknown 10/16/2003 21:54:19 IP Filter Trojan attempt detected from address 24.194.13.169 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 21:52:00 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (66.112.20.11,42704) Process name is "N/A" Unknown 10/16/2003 21:52:00 IP Filter Trojan attempt detected from address 66.112.20.11 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 21:50:48 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (24.55.19.206,1454) Alert 10/16/2003 21:50:42 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (24.55.19.206,1454) Alert 10/16/2003 21:50:41 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (24.55.19.206,1454) Alert 10/16/2003 21:43:03 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (24.175.210.240,17300) Alert 10/16/2003 21:35:43 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (141.156.132.85,1454) Alert 10/16/2003 21:35:37 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (141.156.132.85,1454) Alert 10/16/2003 21:35:35 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (141.156.132.85,1454) Unknown 10/16/2003 21:35:15 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.243.76.25,4489) Process name is "N/A" Unknown 10/16/2003 21:35:15 IP Filter Trojan attempt detected from address 24.243.76.25 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 21:20:38 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.195.157.140,1454) Alert 10/16/2003 21:20:32 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.195.157.140,1454) Alert 10/16/2003 21:20:30 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.195.157.140,1454) Unknown 10/16/2003 21:16:45 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (172.157.59.8,3622) Process name is "N/A" Unknown 10/16/2003 21:16:45 IP Filter Trojan attempt detected from address 172.157.59.8 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 21:16:19 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (63.238.104.2,1204) Process name is "N/A" Unknown 10/16/2003 21:16:19 IP Filter Trojan attempt detected from address 63.238.104.2 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 21:14:09 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.66.250.16,4380) Process name is "N/A" Unknown 10/16/2003 21:14:09 IP Filter Trojan attempt detected from address 24.66.250.16 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 21:11:21 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (64.80.222.91,17300) Alert 10/16/2003 21:05:34 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (80.235.55.163,1454) Unknown 10/16/2003 21:05:29 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.126.121.129,2657) Process name is "N/A" Unknown 10/16/2003 21:05:29 IP Filter Trojan attempt detected from address 24.126.121.129 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 21:05:28 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (80.235.55.163,1454) Alert 10/16/2003 21:05:26 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (80.235.55.163,1454) Alert 10/16/2003 21:01:35 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.141.31.207,3223) Alert 10/16/2003 21:01:31 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.141.31.207,3223) Alert 10/16/2003 21:01:26 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.141.31.207,3223) Alert 10/16/2003 21:00:23 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (66.81.22.194,socks(1080)) Alert 10/16/2003 20:50:29 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.170.56.56,1454) Alert 10/16/2003 20:50:23 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.170.56.56,1454) Alert 10/16/2003 20:50:21 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.170.56.56,1454) Unknown 10/16/2003 20:46:41 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (212.194.114.102,1039) Process name is "N/A" Unknown 10/16/2003 20:46:41 IP Filter Trojan attempt detected from address 212.194.114.102 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 20:42:54 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (80.183.3.50,2323) Process name is "N/A" Unknown 10/16/2003 20:42:54 IP Filter Trojan attempt detected from address 80.183.3.50 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 20:37:55 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (69.22.114.54,3244) Process name is "N/A" Unknown 10/16/2003 20:37:55 IP Filter Trojan attempt detected from address 69.22.114.54 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 20:36:21 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (67.162.73.28,4739) Process name is "N/A" Unknown 10/16/2003 20:36:21 IP Filter Trojan attempt detected from address 67.162.73.28 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 20:35:24 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (130.184.91.157,1454) Alert 10/16/2003 20:35:17 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (130.184.91.157,1454) Alert 10/16/2003 20:35:14 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (130.184.91.157,1454) Unknown 10/16/2003 20:33:40 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (66.65.40.4,1719) Process name is "N/A" Unknown 10/16/2003 20:33:40 IP Filter Trojan attempt detected from address 66.65.40.4 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 20:32:43 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (80.8.39.251,4488) Process name is "N/A" Unknown 10/16/2003 20:32:43 IP Filter Trojan attempt detected from address 80.8.39.251 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Unknown 10/16/2003 20:25:31 IP Filter Rule "Default Block Backdoor/SubSeven Trojan horse" blocked (unknown(172.147.81.149),27374). Details: Inbound TCP connection Local address,service is (unknown(172.147.81.149),27374) Remote address,service is (24.197.121.41,1181) Process name is "N/A" Unknown 10/16/2003 20:25:31 IP Filter Trojan attempt detected from address 24.197.121.41 by rule "Default Block Backdoor/SubSeven Trojan horse". Blocked further access for 30 minutes. Alert 10/16/2003 20:22:27 IP Filter Unused port blocking has blocked communications. Details: Inbound TCP connection Remote address,local service is (172.150.100.58,17300)
Yesterday's history, tomorrow's a mystery, but today is a gift; that's why it's called the present . |
E90 M3 997 C2S - Sold E92 335i - Sold E46 330i - Sold E39 530i - Sold |
my hit count was so low recently I was almost wondering if the firewall was working, then this type of steady pinging started up.
It almost seems as if I'm being specifically targeted for an attack now
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
