Old 02-24-2010, 04:40 PM
jose_lg jose_lg is offline
Mein Auto: BMW 335i Coupe (E92)
Exclamation DOEs the new Curt hitch fit the 335i coupe?
I have a 335i coupe and I want to be able to transport my bicycles. I tried the BMW roof rack and couldn't stand the noise and looks. Curt manufacturing is now selling a hitch for the 335 sedan, the hitch model number is 11756. Has anyone tried to install this hitch in the coupe?
Comparing the two cars undercarriage, it seems that the exhaust system and the bumper beam studs are the same. I'm not sure if the rear mounting strap will fit.
See link with hitch instructions below:
http://sitepro12.sitepro.com/masterl..._11756_INS.pdf
Old 09-04-2010, 02:04 PM
Billt335 Billt335 is offline
Mein Auto: 335i coupe
I am wondering the same thing, I know you can order a westfalla tow bar from Europe but it is a little costly... I did the same measuring and it seems like it would work?
Old 09-04-2010, 04:29 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
I built a hitch for our E91 using stainless steel square tubing and the Westfalia designed basic attachment points. I am sure that any hitch that is close can be easily modified to fit and the manufacturer would probably do the adjustments to create a new version for your model.
I leave the trailer ball installed at all times as a deterrent to those drivers who like to bump and run in parking lots. I don't pull a trailer but I have accessories that mount on the back for extra capacity like your bike rack.
A hitch is a good thing to have on all cars, in my opinion.
Don
328XiT Sonora
Old 10-07-2010, 01:40 PM
It fits, I just installed it on my 2008 335i coupe...
Old 04-05-2011, 10:41 AM
carsnoceans's Avatar
carsnoceans carsnoceans is offline
Mein Auto: '05 330i ZHP
Linky no worky. Share again please.
Modified Clutch Stop
Valentine-1 hardwired (DIY)
Zeckhausen CDV
BMWCCA Member #401517
Old 04-05-2011, 11:15 AM
It works fine, bought mine on ebay for my 2008 335i.
Old 04-05-2011, 09:17 PM
Nice. Is it easy installation or did you take it to dealer/shop?
Zeckhausen CDV
Old 04-06-2011, 12:01 PM
Very easy to install, took about 30 minutes or so!
Old 06-11-2011, 09:30 PM
Phil335i Phil335i is offline
Mein Auto: BMW 335i
Needing to sell the vehicle I use to carry my bikes, I wanted to be able to carry a bike rack on my car and so just had the Valley hidden hitch installed on my 2007 E92. It's completely invisible from any position other than lying on the ground looking up under the rear bumper.
I ordered it and the adapter below from etrailer.com. Great service ! Bimmers R Us here in St. Louis installed the hitch and did a beautiful job, especially since my car has the Dinan mods, including the Dinan exhaust. The mufflers are taller than the OEM ones and when the exhaust expanded as the pipes warmed-up, they would touch the hitch. So Bimmers R Us removed both mufflers and heated the edged or lip of the back, top-end of each muffler and dimpled it in slightly to clear the hitch. No change in exhaust sound and no baffles were loosened internal to the mufflers.
I'd show pictures but the attachment points are hidden behind the heat shield. Except for the exposed hitch bars, everything looks like it did before the installation.
V81821 Valley Stealth Vertical Trailer Hitch Receiver - Custom Fit - Class I - 2"
V76462 Valley Stealth Vertical Trailer Hitch 2" Horizontal Receiver Adapter
2007 335i | Crimson | Saddle Brown | 6MT | Sport | Dinan S1 Pkg | Active Steering | Premium | Nav | CA | PDC | Sat Radio
Old 06-12-2011, 10:26 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
It doesn't appear that you have the M Sport Package. Do you think that it would fit a E92 with the M Sport Package? I have a 335is Coupe which has a slightly different rear valence than the one with the M Sport Package and I'd like to use this hitch if it will fit.
If you'd be willing to take some pictures from underneath the rear that shows where the trailer hitch lies in relation to the bumper I'd appreciate it.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 06-12-2011, 03:32 PM
Mein Auto: BMW 335i
I'm not familiar with the IS but, correct, my car is a stock 2007 335i when it comes to the bumper, etc. Here are some photos that I took. Hopefully they are helpful to you.
My car is crimson red and all the photos are taken from the right side of the hitch looking to the left. It's a vertical hitch that uses an L-shaped adaptor that slides up into it to bring out the hitch perpendicular to the ground. Note too that the cutout in the bumper that is evident in the first image is actually off-center to the right, so the hitch appears not to be centered when compared to it.
The first three photos show the hitch pretty clearly and give you some points of reference for orientation as well as some idea of fitment. The 4th photo shows the top of the hitch in more detail and the last photo attempts to show where the hitch support arm runs relative to the bumper - the hitch is the dark part of the image at the right so this is looking past the hitch.
Hope this helps.
ID:	281451   Click image for larger version
ID:	281452   Click image for larger version
ID:	281453   Click image for larger version
ID:	281454   Click image for larger version
Old 06-12-2011, 03:50 PM
SD ///M4's Avatar
Great, thanks a lot! Was the cutout in the bumper already there or was it required for installation?
Here's a picture of the rear of our car. I don't know what it looks like underneath because we don't have the car home yet! Do you see anything in this picture of the rear valence that you think would prevent this hitch from working with our car:
Also, which bike carrier are you using? My wife and I both have mountain bikes and I have a road bike. We would probably only be carrying both mountain bikes together.
- Tom
Old 06-12-2011, 04:02 PM
Mein Auto: BMW 335i
You're welcome ! You've got a beautiful car, by the way.
The cutout was already in the bumper and was not required for installation. I don't see anything offhand that would effect installation on your car, only if the bottom lip of your bumper curves in further than mine and might interfere with the hitch being in position or block the hitch opening.
We have a Yakima two bike platform mount which we've used with my wife's Lexus RX-400H and it has worked very well. Being a platform type of carrier, the bikes sit on their wheels and are held in place firmly so the bikes don't swing or otherwise move around and contact each other or the vehicle. The only issue I had with it for use on my car is it's weight. I haven't checked the specs but I'd guess it weighs about 40 pounds. I wanted a lighter and a bit more compact carrier for my 335i.
I've ordered a Kuat Sherpa rack for my car. About 22 lbs and compact and gets good reviews. I should have it this week. Here's the link: http://kuatracks.com/index.php?page=products
Old 06-12-2011, 04:45 PM
SD ///M4's Avatar
The KŁat rack looks pretty nice even if it is a little pricey. Who did you order it from? It does seem like the best solution as it's aluminum, lightweight, has a platform, swings up when not in use, and swings rearward for easy access to the trunk. This hitch/rack solution just went to the top of my list! Good find!
- Tom
Old 06-12-2011, 05:00 PM
Mein Auto: BMW 335i
I ordered it on Amazon from Xtreme Bike & Sport for $370 plus $28 shipping. Hopefully it's as good as it looks !
Old 06-13-2011, 10:48 AM
watever watever is offline
Mein Auto: '14 435i
Anyone know an Indy in the Greater Delaware Valley who is capable of installing this on a 335i coupe? I have tried several and no one is comfortable doing it.
Current ride: 2014 435i M-Sport Estoril Blue, Beige, CW, DA, DA+, DHP, LP, PP, TP, MS Brakes, PS, HK. PCD 5/20/14
Most recent: 2007 335i Coupe, Sparkling Graphite, Step, Paddles, Sport Pkg, Nav, PDC, Rear Shade, USB/IPOD adapter ED 4/13/07
Retired: 2003 325i Coupe 5MT, 1993 Mazda MX6 5 Spd, 1980 Datsun 200 SX 5 Spd, 1977 TR7 4 Spd, 1972 Corolla 4 Spd, 1967 Camaro SS 350 4 Spd.
Old 09-17-2013, 07:40 PM
dogdaysunrise dogdaysunrise is offline
Mein Auto: 323
Can anybody tell me if the Curt hitch 11756
fits a 2009 328xi e92 coupe?
I have googled like crazy, called manufacturer after manufacturer and it seems there is no hitch for the 328!
I was about to purchase a 328xi coupe, but I need a trailer hitch for my bikes (so no towing) and it seems I might be better off with a 335xi coupe.
Thanks for any info
Old 09-18-2013, 10:58 AM
invisihitch invisihitch is offline
Mein Auto: 2012 X3
^ We do have an invisihitch specifically for the coupe (E92). The hitch is absolutely undetectable when not in use, since the hitch beam mounts behind the fascia and the rack connector is snap-out removable.
Attached are some photos... the photos are of the 335 but the same hitch fits the 328. The removable rack connector is available in a 2-inch or a 1.25-inch square receiver, depending on your rack's requirement.
Daryl
daryl@invisihitch.com
Old 09-18-2013, 10:59 AM
Mein Auto: 2012 X3
Daryl
Oops, this time with the photos attached!
Name:	BMW 3 Series Coupe [E92] with invisihitch receiver installed.jpg
ID:	397543   Click image for larger version
Name:	BMW 3 Series Coupe [E92] with removable ballmount inserted.jpg
ID:	397544   Click image for larger version
Name:	BMW 3 Series Coupe [E92] with removable rack-connector inserted.jpg
Old 09-18-2013, 01:06 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Hey, Daryl.
I've seen the picture of the hitch on the 335i coupe in the past, so I know it fits that.
Does it fit the 335xi coupe as well? The underbody and frame structure of the xDrive models are different from the RWD versions (the space under the trunk floor, as an example, is greatly reduced), and I've wondered if it goes onto both the AWD and RWD models the same way.
Old 09-18-2013, 01:14 PM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
That looks horrible! It is what it is. If you need it...
Old 09-18-2013, 01:34 PM
Mein Auto: 2012 X3
^ I respectfully beg to differ. During the 90% of the time that you are not towing anything and you don't have a bike rack attached, it looks exactly like your beautiful, unspoiled BMW. Because the hitch cannot be seen. And on those gorgeous Saturdays when you put your bikes on the back or tow your jetski to the ramp, it looks like you have some really nice toys. Attention during those times would not be on the hitch, but on the toys attached.
It does indeed fit the xDrive models. While the differences between the iDrive and xDrive models are significant, the differences all occur forward of the rear chassis studs, which is where our hitch bolts onto the vehicle. So one invisihitch fits both models.
Daryl
Old 09-18-2013, 02:29 PM
My bad. I didn't see that the first pic had no hitch hardware in it. It looked like the receiver was there but obscured by shade. In the words of the late great Emily Latella, never mind.
Old 09-19-2013, 05:42 AM
Zooks527's Avatar
Thanks, Daryl!
Old 09-19-2013, 07:20 PM
fun2drive's Avatar
BMWCCA 149159
I would have used your hitch over the one I installed had it been available. I do think it is a robust elegant design. I have nothing to do with any company but I am someone who values good engineering and while my hitch is also invisible it required drilling which this hitch doesn't.
Nice work...
