7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code! |
What tire pressure are you running on the OEM 19's w/ Run Flats?
Don't have the door jam here to check.
Thanks in advance |
32 PSI all around (as per the door jamb).
Current: 2013 M5 Previous: 2012 A7; 2011 S5; 2011 X5M; 2010 750Li; 2009 M3 Sedan; 2008 X5; 2003 M5; 1998 540i 6 spd. |
I'm running on Pirelli P Zeros run flats 275/40/19 and 245/45/19(same as 750 specs). Not to sure in PSI but the machine reads 240 which the techs pumped on all 4 tyres.
2012 BMW 640i (AC Schnitzer Package) 2011 Mercedes E250 2007 Ford Mondeo "Age is but a statistic that has no relevance to enjoyment of horsepower" |
Mike
Is that to much?
Not necessarily. I think it calls for higher pressures for higher loads and for sustained high speeds.
Mike
Ok thanks. Does lower pressures mean more comfort?
How are those runflats, are they loud because runflats generally run louder then regular performance tires..My vette has runflats but thats only because there is no spare, otherwise I would have swapped them out.
Mr. Officer ![]() 335i xdrive coupe,750 sport(sold), S550 sport pack,C6 vert... |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
