Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 02-27-2010, 10:43 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Service Indicator Display: fuel is only value used to determine ''load''
I was researching info about the e39/e53 (X5) low instrument cluster...and ran across the info below that went into greater detail about SIA III (service indicator display III).
Before today, I was still INCORRECTLY assuming that the same values used in SIA I and SIA II (fuel, mileage, engine temp, RPM) were still being used to determine "load".
The old SIA I formula was e=a(1+t+r) where:
  • e = estimated mileage
  • a = actual mileage
  • t = 1 (if engine operating temps is below normal) otherwise t=0
  • r = .5 (if engine is above 4500 RPM) otherwise r=0
So under this old calculaton, if you drove 5 miles with a cold engine @ 5000 RPM...the SIA I would calculate "e" as 12.5 miles although you only drove 5 miles:
  • a = 5 (the actual miles driven)
  • t = 1 (since the engine was cold and never reached normal operating temps)
  • r = .5 (engine exceeded 4500 RPM)
  • e = 5(1+1+.5)= 12.5 estimated miles
But starting with the 1996 model year...BMW started implementing SIA III where fuel is the ONLY value used to calculate "load"...see the info below for more details:
Q {BMW CCA Member #191509}
(SOLD)
Old 03-11-2010, 06:30 AM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Good to know. Thanks for posting that!
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
