Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 10-19-2003, 04:26 AM
blackhawk77 blackhawk77 is offline
Mein auto: 330Ci
E-46 wheel change tech questions (Tire Rack return customer)
I am getting ready to purchase wheels from the Tire Rack for my 2003 330 Ci and was told by a fellow E-46 owner that a wheel swap requires some sort of "hub-centric" washer anytime the wheel is changed. He said these are "one-time" use items.
Is this true, and if so, will the Tire Rack automatically include these "washers" when I place the order online?
Also-- I am deliberating between two wheel choices:
Choice 1-- Mille Miglia Spider II 18x8 Front and Rear
Choice 2-- Mille Miglia EV-S--18x8 Front, 18x9 Rear
My questions about these choices are:
- Will choice # 2 fit okay without rubbing in the rear?
- Which tire choice do you recommend between the P-Zero Nero & P-7000 Supersport?
- What are the manufacturers weight listing for above choices (per wheel, with your recommended tire choice)?
- Will ride comfort decrease significantly with 18 inch wheels?
Thanks in advance for your help~
2003 330CiA. Japan Rot, Sand Leather, Premium Pkg, Htd Seats
__________________________________________________ ________
The power of accurate observation is commonly called cynicism by those who have not got it.
George Bernard Shaw (1856-1950)
Old 10-19-2003, 08:56 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein auto: M Roadster/M3
Hub centric rings are used to match wheels to different cars using the same bolt pattern. Even with teh same bolt pattern teh hub diameter is different, and the wheel shuold bear against teh hub.
They are one time per wheel per car. And Tire Rack should supply the proper ones for your new wheels to fit you car.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-19-2003, 12:42 PM
HW's Avatar
HW HW is online now
lurking
Mein auto: 323ci, manual
so which popular aftermarket wheels are hubcentric w/ the 3er? which ones don't need those washers?
323Ci / 5 speed manual / BBS RK 17" / Goodyear F1 Asymmetric 225/45ZR17
"Respect the man's car and he'll respect you."
"You know, by the time you become the leader of a country, someone else makes all the decisions. You may find that you can get away with virtual presidents, virtual prime ministers, virtual everything" - Bill Clinton
"Give me control of a nation's money and I care not who makes the laws." -
Old 10-19-2003, 12:46 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein auto: M3 & 323i/999 KP
One should note that at least some hubcentric rings are plastic. This is a mon-issue for street use, but if you have any thoughts of going to the track, it's a big deal.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
1995 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1989 325is S50
Alpinweiß/Black
1988 M3
Alpinweiß/Black Basket Case
Old 10-19-2003, 02:14 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein auto: 01 325iT, 88 M6
One-time-use hubcentric rings? This is the first I've heard of this. The ones I've seen have always been a hard aluminum alloy and are very difficult to remove from the wheel (I've had to grind them off in the past), let alone replace every time you take the wheel off and on.
I would imagine that nearly every BMW application (E36/Z/E46 in particular) should be natively hub-centric, as these are the only cars out there that use the particular combination off offset (varies), PCD (5x120) and centerbore (71mm, I think). I know E30M3/E23/4/8/E32/4/8/9) is a little different, as E39s are 72.5mm centerbore vs 71 for everthing else.
Old 10-19-2003, 05:08 PM
pmb1010's Avatar
pmb1010 pmb1010 is offline
Mein auto: 2003 330xi JetBlk/Blk
Old 10-19-2003, 07:52 PM
DZeckhausen's Avatar
DZeckhausen DZeckhausen is offline
www.zeckhausen.com
Send a message via AIM to DZeckhausen
Mein auto: 2001 540i 6-Speed
Actually, the E39 is 74.1mm centerbore and the other BMW models are 72.5mm.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
StopTech 4-wheel big brake upgrade
M5 3.15 Limited Slip Differential
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
Rogue Octane Short Shifter
Rogue Performance Transmission Mounts
European Dash Conversion
CDV Deleted (of course!)
Old 10-19-2003, 11:09 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Thanks for the correction. I knew there was a 72.5mm in there someplace.
Old 10-20-2003, 05:47 AM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein auto: 1995 BMW M3
Rings can be resued, as they rarely 'wear out'. They aren't items that woud need to be replaced periodically like brake pads (unless broken of course!) but they often don't transfer from one application to another, since even within BMW the center bore sizes can vary from model to model.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Old 10-21-2003, 06:37 AM
Mein auto: 330Ci
Gary-
I started this thread to ask YOU some questions and you ended up answering the "red herring" posts.
Could you take a stab at answering my original questions?
Old 10-21-2003, 07:38 AM
Moderator
No problem, in the future be sure to put my name in the subject as the first word when starting the thread so that I and other members know its directed at me
Yes, use 255/35R18 in rear
Pzero Nero is much better
Mille Miglia Spider II 27lbs.
EVS 18X8 30.5lbs 18X9 31.5 lbs
Tires 255/35R18 24.4
225/40R18 21.8 lbs
It will be a noticable difference from stock, but there is not really a way to quanitify the difference. Perhaps some other members with 18" on E46 can weigh in with their opinions.
Old 10-21-2003, 07:48 AM
www.zeckhausen.com
I have a 2001 540i/6, but I just made the switch from 17" wheels to 18" wheels last weekend, so I'll weigh in.
My ride comfort actually improved. I switched from the factory Style 66M staggered wheels at 17x8 and 17x9 to the factory Style 37 at 18x8 and 18x9 and went from the factory-supplied Dunlop SP Sport 2000E tires to a staggered set of Goodyear Eagle F1 GS-D3. I suspect the ride would have become harsher had I stayed with the same tires. But I changed two things at once.
You will also be changing both tire type and wheel size at the same time. This makes it much harder to predict what will happen in your case. Depending on your tire selection, the ride comfort could go either way.
Dave Zeckhausen
2001 540i 6-Speed
M5 Front Swaybar
Old 10-21-2003, 08:21 AM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein auto: a BMW killer
pssst: P-Zero Nero also has a 235/40, same dia. as the 225/40 yet a slightly better footprint on an 8" wheel
Old 10-23-2003, 11:38 AM
Mein auto: 330Ci
Thanks for the feedback, Gary. Thanks to the other posters also.
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
