Old 03-01-2010, 01:48 PM
whoustonjr whoustonjr is offline
Mein Auto: 2003 745LI
Exclamation 03 745Li - PDC malfunction
I have a 2003 745LI and received a PDC Malfunction Error and am hoping I can try some kind of reset. The error appeared when I was backing my car up and the PDC was audibly beeping; I don't think I came to a full stop and put the car in drive as a car was pulling into the travel lane quickly. It was at that point that the PDC Error lit up.
Hope someone can help me - -thank you.
Old 03-01-2010, 03:17 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Turn the PDC ON ....go round the back of the car and listen to each PDC sensor ...you should hear it clicking.
The sensor that isn't clicking is the one that is faulty and will need replaced.
My BMW ACS7
Old 03-01-2010, 03:40 PM
745ByMySide 745ByMySide is offline
Mein Auto: 745Li, X5 3.0, A6 2.7t
Get some rubbing alcohol and thoroughly clean all of the sensors, sometimes the dirt can cause problems.
budder
Old 03-02-2010, 07:07 AM
Thanks - - I heard the rear sensors clicking and didn't hear two in the front clicking -- it was hard to hear with the engine running though. I'll try and clean them good.
Do you think there is any benefit to trying to reboot the idrive -- I did read a post from someone else who had a very similar story about backing up and putting their car in drive before coming to a full stop. They recommended rebooting the iDrive, however I wasn't able to duplicate their recommendation as by Nav/DVD is in the trunk and I can't hold the eject button there and the radio/power and CD eject buttons at the same time.
When I scrolled for further detail regarding the "PDC Malfunction" the screen says "No Acoustic Warning Available"
Again, many thanks for your input.
Old 03-02-2010, 07:32 AM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
They were likely talking about resetting the MOST bus by pulling the jumper in the glove box for a minute. Open your glove box, then open the little door at the top of the glove box (to get to the fuse box). On the fuse box door there is a loop with two optical cables plugged into it, unplug its connector for a minute and plug it back in. This is considered a MOST bus reset (basically you are breaking the MOST bus network (a ring topology) for a minute, then reconnecting).
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 03-02-2010, 08:17 AM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
i got these errors 3 times when i first got my car, but i think it was due to dirt or moisture in there, because once i washed car and stuff it never happened again to this day.
Old 03-02-2010, 10:27 AM
I checked all the sensors; the back ones clicked -- three in the front clicked but not the 4th. . . Tried the rubbing alcohol but that didn't seem to work so I guess the drivers side sensor on my front bumper is in need of replacement.
Old 03-02-2010, 12:18 PM
UltZeven UltZeven is offline
Mein Auto: 2002 745LI
Anyone know the part number of the rear left side PDC sensor? I found this thread to be very useful and noticed that the only sensor not clicking is the rear left.
Old 03-02-2010, 02:08 PM
For info : your new PDC sensor will also need to be colour coded to match the colour of your car. So you'll need this info when ordering.
I think the Front Sensor part no. is : 66200309541
and the Rear Sensor part no. : 66200309542
Enter part no.s here to check: http://www.realoem.com/bmw/select.do
My BMW ACS7
Old 03-02-2010, 10:05 PM
Thanks bro, you're the man, but honestly $200 just for one sensor . Oh well, I love using the PDC so I'll have to order it.
Old 04-22-2010, 07:04 PM
jjv.659 jjv.659 is offline
Send a message via AIM to jjv.659
Mein Auto: BMW 750Li
my pdc error comes and goes like couple times a week. what do you guys think maybe a lose wire or do you think the sensor is messed up even though it works sometimes?
Old 04-23-2010, 04:37 AM
TechGuy TechGuy is offline
Mein Auto: E46 325i
It could well be a loose connection. Remove the strips to check all sockets on the bumpers (7s are a delight in that sense) and then make your way to the main wiring harness shall you not find any of the sensors loose.
Old 04-23-2010, 11:10 AM
Red face
wait im not the greatest person for that, uhm can you tell me how to do that again in detail? thank you sir
Old 09-03-2010, 09:33 AM
tonelab77 tonelab77 is offline
Mein Auto: 745i
Yes, please give us more detailed instructions. Please.
Old 09-03-2010, 01:06 PM
Master Tinkerer
The first few pictures in my bumper drop set show/tell how to pull off the trim strips that house the sensors --> here.
Old 09-03-2010, 01:42 PM
Mein Auto: 745i
You're pics and help on this forum rule! Thank you.
Any pics for pulling off the back sensors, or is it basically the same technique? My rear, middle passenger side sensor is not clicking. Just bought it 2 days ago, but the owner told me it was "intermittent", which it is NOT. Is it possible that the sensor is good? Maybe it's a connection issure (ie: loose and/or dirty).
It sucks, but at the same time it's nice to know there are people on here like you and techfreak to help. So, thanks again! Both of you!
Old 09-03-2010, 02:05 PM
Swap the NON-clicking sensor over with a known good clicking one ....this will tell you if the cable is ok ....
My BMW ACS7
Old 09-03-2010, 02:15 PM
Mein Auto: 745i
Thanks for that helpful tip! Should I use the same (or similar) technique for removing the front sensors, as described by Keif?
Old 09-03-2010, 02:30 PM
Master Tinkerer
I haven't done it, but from what it looks like in TIS, it's the exact same way as doing the front -- pull off the side pieces first, starting from the edges nearest the middle of the bumper, pull them out toward the sides a little, then slide back and out, then pry the center piece out in a similar fashion.
Old 09-03-2010, 02:34 PM
Wot Keif said .....
My BMW ACS7
Old 09-03-2010, 02:35 PM
Mein Auto: 745i
THANK YOU!
I'm going to try this in the next couple days. I would today, but it's my birthday, and I don't feel like it.
Old 09-11-2010, 10:54 AM
Mein Auto: 745i
Strip came off very easily and I switched the "bad" sensor with the one next to it (to test the harness). Turns out, the PDC sensor is bad. Anyhow, here's a pic. I can't find a part number that matches "66200309542" anywhere.
Here's what it says:
6 913 942
602 482
GERMANY
602 398
6 907 128
A103
02
Can someone please verify the part number I need. THANKS!
I just got off the phone with the local BMW stealer, and they said the part number is #66202184264
This is so confusing! Please help.
Old 09-13-2010, 12:44 PM
Master Tinkerer
Part #3 on this diagram is what you are looking for... a guy at a local dealership just told me that the part number 66200309542 listed on realoem was superceded last month by the number you gave (so YOU have the correct part number, not realoem.com).
That being said, a known working rear bumper sensor of the same color from a member here on the board should work fine and be much cheaper. Good luck!
Last edited by Keif; 09-14-2010 at 01:46 PM. Reason: Apparently my fingers can't spell as well as my brain.
Old 09-13-2010, 10:49 PM
Mein Auto: 745i
Will this part work? http://www.bimmerfest.com/forums/sho...72#post5467272 Thanks Keif!
Old 09-14-2010, 02:07 PM
Master Tinkerer
Unsure...there is one part number for the front PDC sensors and a different one for the rear ones...and I haven't taken off the rear bumper, so to be honest, I'm not quite sure what visible design differences there are. I'll try to drop by the dealership after work and see if they have a rear one to look at.
Ok, just talked to a parts guy at a local dealership and he said that the front PDC sensors have the connector coming straight off the back, while the rear PDC sensors have the connector coming off the side. So, it sounds like the one at the bottom of the picture in the link you posted is probably the one you want (the one on the top does look like my front PDC sensors).
