Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
This seems prety straight forward but....
I have a 2000 540i with alloy wheels. I have had several unsucessful attempts at removing the wheels. After removing the lug nuts, pulling or (gingerly) tapping with a rubber mallet fails to move the wheels. Is more brute force required, or is something else holding them on? The owners manual has a cryptic picture of removing the wheel and talking about some kind of adaptor. If it's just brute force, any suggestions for applying more clout are appreciated...(I dont really want to lay under the car while I do this.) |
Once or twice, I have gently lowered the car on the jack, and the weight of the car is enough to loosen the wheel. I wouldn't recommend making a habit of this but it does work.
I don't know how BMW feels about this, but I use a touch of anti-seize on the mating surfaces between the wheel and the hub to prevent this very thing, as it would suck on the side of the road with a flat.
bimmerfest 5-Series Welcome Later, Dave E39 - 1998 540iA Sport (11/97 Production) E30 - 1989 M3 (44k miles) 1979 Triumph TR7, still have my first car ;-) Past cars: E21 - 1980 320i (sold at 130k) E23 - 1986 735i Avatars under the signature are MUCH more prestigious than to the left of the post...
Thanks alee
Tried this once before I posted (unsucessful). Will go back and try a few more times. |
alee
Just tried your suggestion again.. a little more velocity this time... worked like a charm! (A little more exciting than I thought though..) Thanks for the suggestion, glad I had a hydraulic jack, don't think this would have worked with a screw jack. |
Yeah I would NOT want to make a habit of doing that, but it does work if you are stuck. Definitely pick up some anti-seize compound, and apply it sparingly to the contact surfaces as suggested above. Be careful and put it only on the touching surfaces, and don't get it on the lug bolt areas. A little bit will save you from this aggravation later on. |
Not sure that I would subscribe to the lower it on the jack theory... you might bend a wheel if you let too much pressure off. Brute force is what really gets you there though... you sometimes have to grab the tire around the back at 3 & 9 oclock position and push and pull side to side with all of your might!!! A little rubber mallet is not going to do jack... you have to yank and pull until the wheel pops off and lands on your foot or something more important.
The antiseize idea is spendid, however if you are using centering hubs, the friction should be there regardless. Good Luck JB |
I've had this problem...I just use my foot/heel and give the tire a good kick or two or three until freed. This has worked for me every time. Just be prepared to grab the tire once you've freed it. It helps to just have the jack adjusted so the wheel is barely off of the floor however, you should have the car on jack stands at this point but we all don't always follow this advice!
![]() Once you have the tire off, use a wire-cup brush on a drill and clean the hub really, really well. Your arms will probably be really tired after doing all 4 wheels but this should prevent sticking next time. I haven't tried adding anti-sieze but the above method as worked for me thus far. Chris |
The way to get leverage on a truly stuck wheel is to sit on your butt facing the wheel, lean back on your elbows and then kick one side of the wheel then the other using a right leg, left leg, right leg routine as long as it takes for you to get that thing loose. Watch out when the wheel comes off that it does not fall on its face and mar the rim. Be ready to catch it before it falls, as opposed to jumping away in fear while your rim lands face down on the concrete. Yes, it happened to me.
Then use the anti-seize goo so you don't have to do this the next time. Or, if you are like me, realize that you don't have any such goo and the wheels are off your car, so just put the wheels back on and promise yourself that "next time" you will get the goo. Then, next time, the wheels are stuck again, so you repeat the process. |
I second the anti-sieze comment above. I've been using it for years on the hub center and the lugs as well as anything else you want to be able to take back off (except brakes). Although I have used it on the sliding rails for the brake shoes.
I find you get a much more consistant torque reading with the anti-sieze, I usually bump the torque up a bit as a 'just in case' measure anyway. NAPA has a can that includes a brush, mine has lasted 3-4 years so far. |
Anti-Seize should increase the effective torque you apply already shouldn't it? I think it acts like monkey grease causing the torque to actually be higher than what your wrench will read. The data sheet for the anti-seaze should call out exactly how much to decrease your torque in order to maintain the same effective torque.
__________________________________________ 99 540iT Sport 264 rhp 300 tq - pre powerchip 262 rhp 300 tq - post powerchip Modifications: Performance: Powerchip Gold 93, M5 rear Sway Styling: Shadow Badge, Shadow Chrome Grill
I hate it when your wheels get stuck, expecially when you want to do a quick change with the spare
As an added bonus antiseize will help the bolts loosen over time...like while your hammering down the highway
![]() - 2004 BMW 330Ci - Mystic Blue - Sports Pkg - Hole in Roof - - Bum Warmers - M3 Wheel - ZHP Knob - Arai for the noggin - - UUC Swaybarbarians - To tell me this is a repost, get in line - |
Anyone try these KLEEN WHEELS® WHEELMATES™ BRAKE/WHEEL ISOLATOR DISCS???
I was thinking about ordering a set with my P21S order. Trying to save a little on shipping. From here: http://bavauto.com/shop.asp More Info: http://www.jcwhitney.com/autoparts/P...951471/c-10101 |
Most shun KLEEN wheels as they can impare proper cooling to your brakes and some other things I can't think of right now. If you hate the dust, I suggest switching your brake pads to Axxis Deluxe+...get from Dave Z.: www.zeckhausen.com
2001 530i/5 (E39), Topaz Blue/Stone Green/Black 2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred) |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
