325 Ci Cabrio Roof problem - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 10-20-2003, 01:22 AM
berlinerb berlinerb is offline
Mein Auto: 325Ci Cabrio
Question 325 Ci Cabrio Roof problem
Here is what happened.
Got into my 2003 cabrio. Cold (5c/41F), dark, but clear evening. Pushed the Automatic Hood open button, hood started to open, then heard a big metalic crack and the hood stopped opening. Got out to see if any obstruction, was not, got back in to car, closed hood, then did the whole thing again, with no problems.
Looked at the car the next day in daylight, and there are two seperate two inch long cracks (Not scratches) in the paintwork of the outside part of the parcel shelf. Positions of cracks shown in attachment.
My theory is that the parcel shelf tried to open but the back part of the roof (with the rear window) was still in position (frozen/stuck) (the normal sequence is that the front of the roof opens slightly, then the rear window folds up firtst towards the front of the car first to then allow the parcel shelf to open). Because the rear window was still in place, the parcel shelf then buckeld slightly causing the paint cracks.
I will take it to my local dealer today to see what he thinks, but has anyone ever heard of similar incidents?
The car has only 3000 miles on the clock and is my 2nd 325Ci in 3 years. This is my first problem I have had with the type.
B.
Old 10-20-2003, 04:21 AM
Tim330Cic's Avatar
Tim330Cic Tim330Cic is offline
Not topless in NE
Mein Auto: Tripple Black '01 330Cic
B.
That sucks! I've never heard anyone else here complain of anything similar. I don't think that you need to worry though as your dealer should take care of everything.
-Tim C
2001 Jet Black 330Cic
____________
Old 10-20-2003, 11:48 AM
egruber egruber is offline
Mein Auto: 01 325CiC
I remember that the owner's manual says not to open/close the top below -10C, but you should have been OK. Good luck with your dealer.
E. Gruber
2000 323i Fern Green/Grey
2001 325CiC - Orient Blue/Sand
Old 10-21-2003, 05:59 AM
Roof Problems
Took it to the dealer last night. Agreed that it was cracked. Dealer was not interested in how it happend, simply agreed to fix it under warrantee since there are only 3k on the clock and it is 3 months old.
Fixed date for repair a week thursday.
Result.
B
