Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 03-03-2010, 08:51 PM
kinglo82 kinglo82 is offline
Mein Auto: 740il
95 740iL - White smoke
I NEED HELP MY 740iL BLOWS WHITE SMOKES WHEN I START IT IN THE MORNING AND SOMETIMES THROUGHOUT THE DAY I HAVE HEARD SO MANY DIFFERENT THINGS FROM RINGS TO VALVE GUIDES MY CAR STILL RIDES VERY SMOOTH WITH NO OTHER PROBLEMS. NEED AS MUCH INFO AS POSSIBLE
Old 03-04-2010, 02:35 AM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
it really could be anything. most of the time, its the oil seperator valve located on the intake maifold. not a very expensive piece. could even be the actual oil seperator which is considerably more difficult and expensive to replace.
my car had this white smoke problem when i bought it a year ago. it was some type of cold start valve, which was making it run way too rich. you may want to give the exhaust a smell to see if it smells oily, like fuel, or like coolant. honestly you probably need to take it to a certified mechanic. might want to get a few different mechanics to look at it also as they may try to screw around and tell you to replace parts that arent related, mainly to get you to spend money. that said, try and find a good honest independent mechanic.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 03-04-2010, 01:17 PM
Mein Auto: 740il
Thank you for the advice. The exhaust does smell oily when I bought the car it was not doing this it just started all of a sudden. What do you recommend I try to repair first
Old 03-06-2010, 02:30 AM
bmwtime740 bmwtime740 is offline
Owned A Good V8 In My Day
Mein Auto: E Thirty Eight
95 was a bad year for the e38. Engines were made with Nikasil making the earlier year e38 a weak engine block. The engines have been known to suffer damage to the cylinder bores from the excessive amounts of sulphur in the US fuels. Sulphur reacts adversely with the Nickel , causing very slight blemishes in the top few millimeters of the cylinder bore. The cylinder bores are crosshatched, which is the name given to a pattern scratched into the surface of the cylinder wall. These scratches help seat and seal the piston rings, allowing good compression.
Clearly stated...the smoke could be simply the burning off of sulphur and nickel in your combustion chambers.
Rebuilt Motor
283 Small Block 4.6L v8
Bored .030 Over
Forged Dinan Internals
Dinan Stage 2 Engine Software (Chip)
K&N Intake
Eisenmann Dual Catback Exhaust
Borla Headers
EMp Stewart Components High Flow Water Pump
Eagle Racing Cams
3:15:1 e39 M5 Differential Swap(Newest Mod)
Royal Purple Synthetic 10w-30 (Soon to be 15w-xx)
///7
Engine Torque: 365.062
Engine Power: 340.210
Old 03-06-2010, 08:06 PM
Mein Auto: 740il
How do you solve this problem? Couse it is getting worst
Old 03-07-2010, 03:20 PM
well this isnt a pleasing fact to know. i'm looking at a '95 740i right now.
*Der E38*
manufactured: 7/01
Old 03-07-2010, 03:36 PM
BMW changed the engine completely from Nikasil to Alusil in 1997 in which they created a much better block. Redesigned thus causing the 4.0 to the 4.4L change.
The 95 and 96 e38's are cars to watch out for...it's kinda like buying an 02-03 745.
I don't know much to tell you...but I do know to stay away from 87 and 89 fuels. The 95 and 96 engines need a higher octane fuel because the additives in those low octane fuels will harm your engine more. 93 will have less additives and will burn more efficiently. Also try using a fuel stabilizer.
Seafoam your engine oil, and your intake to clean the deposits from your engine.
Rebuilt Motor
Bored .030 Over
K&N Intake
Borla Headers
Eagle Racing Cams
///7
Old 03-07-2010, 05:02 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
For the E38, it should have been only 1995 in the USA.
Here is one of the best articles on the topic, plus an introduction/update from 2004:
http://www.koalamotorsport.com/tech/article-m60v8.asp
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
