E36 (1991 - 1999)
Old 03-05-2010, 01:13 PM
SouthFL SouthFL is offline
Mein Auto: 1994 318is
Leaking Oil Pan Drain Plug
Hi, does anyone know of a DIY fix for a leaking oil pan drain plug? wife took the car to get oil changed and after a few days i noticed droppings on the driveway. I took the car back but they CLAIM that's the way it came in... liarssssss!
Old 03-05-2010, 01:16 PM
Los's Avatar
Los Los is offline
Too soon Junior
Mein Auto: Elise<3
They probably did not replace the washer. Remove the plug and check to see if it has a washer on it. Other than that I don't know why it would be leaking.
@hanloso. '98 328i/'09 Tahoe LTZ
Old 03-05-2010, 01:18 PM
I think it's cross-threaded... is there a way I could re-thread it?
thanks for the quick reply
Old 03-05-2010, 01:24 PM
Los's Avatar
Los Los is offline
Too soon Junior
Mein Auto: Elise<3
That I do not know. I suggest just going to your nearest dealer and getting a new one. Should be pretty cheap.
Old 03-05-2010, 01:26 PM
I thought about doing that, but I'm thinking the threads on the oil pan are screwed up.
Old 03-05-2010, 01:38 PM
stlbmw stlbmw is offline
stlbmw
Mein Auto: 2002 745Li/1999 528i
Huh..why am I not suprised. I've had a few friends that have had issues with the oil change stations and the staff that performs the oil change job not doing a profesional job.
My suggestion is to open the oil pan plug. Drain the oil...you can keep the filter in place since its new.
Get a tap and die set and chase the threads on tha pan, but !!! Heres the kicker
Acquire a new oil drain plug(stock size/exact replacement oil pan plug) because many of the stripped oil pan bolt thread fixes involve an increased size in oil pan bolts which subsequently ream open the oil pan hole by cutting new threads. If this would happen later on, the next increased size of plugs will be used.. and on and on until there is not another "bigger" oil pan bolt thread which then requires you drop the oil pan itself and replace it.
stlbmw
2002 745Li
1999 528i
Old 03-05-2010, 01:44 PM
the_brouhaha's Avatar
the_brouhaha the_brouhaha is offline
I run as fast as my car.
Mein Auto: e36 coupe
Find a CL ad parting out an e36 and take that oil pan.
Shouldn't be that expensive or hard of a job.
Freude am Fahren
Flickr Album!!
Old 03-05-2010, 02:00 PM
stlbmw
Thanks stlbwm, this fix sounds like exactly what I'm looking for. I'll pickup a tap and die set on the way home and tackle this tomorrow (if this south florida weather will ever warm up.. it was 40 this AM, brrrr)
Old 03-05-2010, 02:02 PM
That's what I had in mind but wanted to see if you guru's had a fix, and I think I've found one with the suggestion from stlbwm.
thanks ALL for you input
Old 03-05-2010, 05:37 PM
Larry_N Larry_N is offline
Send a message via AIM to Larry_N
Mein Auto: 2005 645CI convertable
You can also go to a parts store and see if they have a helicoil (Heal Lee Coil).
Beyern 19's
Old 03-05-2010, 06:10 PM
I've never heard of a helicoil so I looked it up and youtube and was very impressed. I appreciate the advice, if the tap and die does not work I have other options.
Thank you!
Old 03-05-2010, 06:15 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
You need to go back to that oil place and have them buy you a new oil pan. E36 pans are aluminum are strip out very easily if you get some clumsy mook torquing your drain plug back down with an impact gun. (and apparently forgetting the crush ring as well)
They are responsible for damages that they did to your car.
Old 03-05-2010, 07:44 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
enjoyed this temp today...spring is in the air, and them termites are already swarmin!!!!
df
Old 03-05-2010, 08:44 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
^+1 I think it reached a high of 40 today and it was really nice!
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-06-2010, 11:32 PM
I've tried that, they're denying they caused the damage... they've lost a customer (and many more after I spread the word).
