Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > 3 Series > E36 (1991 - 1999)
E36 (1991 - 1999)
Old 03-07-2010, 02:48 PM
haydar1984's Avatar
haydar1984 haydar1984 is offline
bimmer 4 life
Mein auto: bmw 325i 1992 sedan
car electricity shut off for a momment when going uphill
Hi everybody it has been long time since writing here because of marriage arrangement
This problem I'm having is somewhat weird as randomly sometimes when I'm going uphill the car and dashboard gauges go off for an instant and come back on , some times when driving randomly the car will stop responding to gas pedal and hesitates for several second and then everything just returns to normal , I had these 2 symptoms before but it ended when I had to change my faulty ECU so I'm suspecting the same problem again but the problem is that this ECU is the third one I replace since I bought the car 15 months ago
So what the hell is going on?? I'm so sad cause i love this car and I don't want to sell it because it just burns ECUs and I don't know how to stop it
ANY suggestion would be greatly appreciated...
_____________________________
Old 03-10-2010, 10:54 AM
haydar1984's Avatar
bimmer 4 life
Update:
The car now is increasingly behaving like that when i press the gas pedal it won't rev up but actually like it looses power and this happens randomly (not when the fuel pump is hot after a long ride) i wonder if anybody is going to answer me or should i go to another forum ??
Old 03-10-2010, 11:28 AM
Chris S Chris S is offline
Mein auto: 1997 323i
grounds or loose wiring?
Tinting, Phillips Vision Bulbs, NGK standard Spark Plugs, Yokohama S-Drive Tyres
Old 03-10-2010, 11:30 AM
Crashj Crashj is offline
Mein auto: 1994,318ci,Red,vert
+1 fawlty grounds.
Old 03-10-2010, 11:52 AM
injunmort injunmort is offline
Mein auto: 1990 525, 1991 535
+1 on grounds rubbing wiriing.
Old 03-10-2010, 12:52 PM
haydar1984's Avatar
bimmer 4 life
Which grounds should i check can you tell me more in a specific way??
Old 03-11-2010, 08:05 AM
haydar1984's Avatar
bimmer 4 life
Do you mean ECU ground or other part ground every thing in the car has a ground?!!
Old 03-12-2010, 06:30 AM
crisscross's Avatar
crisscross crisscross is offline
Mein auto: 1994 325i Boston Green
Check this out:
http://www.bimmerfest.com/forums/sho...rument+cluster
I fought my cluster, connections, grounds etc for a while. I replaced the cluster and it hasn't happened since. Apparently its something within the circuit board that shorts out. I tore my old one apart and couldn't find the problem, but I read that it has been going on since the late e30's until about the end of OBDI e36's. Search around for some good info on removing the cluster, you don't need to remove the steering wheel if its pointed straight.
Patiently waiting for my ///M
Old 03-12-2010, 09:23 AM
haydar1984's Avatar
bimmer 4 life
crisscross thanks but my problem now is not just the electricity its that sometimes when i press the gas pedal the RPMs goes down and the car won't go and this happens randomly also the ecu become blazing hot when i run the car so what's going on i don't know and no one is helping me here...I searched every where for hours and couldn't find an answer...
Old 03-12-2010, 02:24 PM
crisscross's Avatar
The DME or ECM or whatever its called isn't getting water in it right? Do you have a manual or auto? Maybe this will help:
http://forums.bimmerforums.com/forum...tation+bogging
A lot of those guys just tried a bunch of stuff, if nothing else its good reading. Good luck!
Old 03-12-2010, 02:38 PM
haydar1984's Avatar
bimmer 4 life
Thanks a lot crisscross i'm going to read this now and no we rarely have rain here and it automatic transmission
Old 03-13-2010, 11:52 AM
haydar1984's Avatar
bimmer 4 life
UPDATE:
I went today to 2 ECU and electronic systems specialists they are very known here to be great experts in ECU and this stuff , the first one told me that my ECU is getting hot because of 2 things the first thing is that the ECU is not properly inserted as it should be in it's place which causes its heat not to dissipate in the car body (the ECU proper place is in intimate contact with the car body mine was hanging in the air) and second it could be either fuel injectors or coil packs that drawing a lot of electrical current causing the ECU to overheat.
The second tech told me right away that it's either fuel injectors or coil packs faulty and drawing a lot of electricity which leads to ECU overheating.
I don't know what to do now, I think I will put my ECU in a proper manner (slide it in it's place) and wait for something to happen...what do you think guys?
I have to add that no one of the 2 tech guys told me why it loses all power momentarily when going uphill or up a bridge.
I will keep this thread updated as much as possible until i find a solution (I hope) so that it could help someone in the future.
ecu, hesitation, uphill
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2001-2010 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
