Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 03-06-2010, 06:00 PM
BMW 3-SERIES BMW 3-SERIES is offline
Mein Auto: 2000 540i Sport (E39)
Exclamation 01 740iL - Sport package?
Ok. Well not going for the 530i cause after I brought it to a mechanic it was in a world of problems. So went to another dealer and found heaven. A almost straight up even trade for my 01 A6 4,2L Quattro -
2001 740iL with "Sport Package" 109k miles runs and drives great. No clunks and anything from engine, suspension, or tranny. Umm it shows sport-package on the original sticker paper but not sport wheel or transmission with step-tronic but idk why it is probably cause its a iL? But let me know what you think.. Asking $ 10,000 for it.
** Removed **
Old 03-06-2010, 08:09 PM
sealbeach740 sealbeach740 is online now
Mein Auto: 2000 740iS, 2003 540iS
Nice looking 740iL! Hope it works out for you.
As far as I know, the 740iL's did not come with the steptronic trannys, nor the sport differentials. I do think the 750iL's did come with the steptronic tranny though.
I think you'll really like the 740iL. Nice driving cars, plenty of power for long drives & cruising. Darn comfortable, also.
Good luck!
PS - I should have added my info is based on USA 740iLs.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 03-07-2010, 12:20 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
+1. Interior wood color, shadowline exterior trim, and if stock M-Parallels and clear turns make it look like an 01 Sport Package. The missing steptronic shows it's an iL.
4x3 NAV screen, if stock, make it appear as a 3/00 to 8/00 build date of the 01 model year. (16:9 wide screen NAV would indicate 9/00 to 7/01 build date of the 01 model year.)
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 03-07-2010, 03:11 PM
Quick question - Can the nav be updated any? Looks just a little out dated, looking to go widescreen anyway but just wondering. Has Premium, Sport, and Cold Weather packages with a few others. Almost fully loaded. Almost. Will be saving up for a transmission rebuild. Will be going with the IPT Transmission Rebuild Kit and torque converter.. I know they use the same ZF Tranns as in my Audi and it failed.
** Removed **
Old 03-07-2010, 03:35 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
i believe you will need to replace the nav unit in the trunk along with the screen to have a functional widescreen. mine has it.
this iL looks to be just a regular model, not a sport package. you might be able to tell by the vin number if you ask a BMW dealership though. if so, it would have the sport gearing in the rear differential. it does have cold weather package seats front and rear, which is pretty nice. its just missing the M steering wheel and sport seats.
personally, i'd go for it. it looks to be in great shape. make sure to get a carfax report, see if they have service history on the car. do they have the floor mats for the car. mine didnt come with any when i bought it, i ended up getting the all weather ones. smart idea on my part.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 03-07-2010, 03:39 PM
bmwtime740 bmwtime740 is offline
Owned A Good V8 In My Day
Mein Auto: E Thirty Eight
Behind your factory amp in the boot of your car is the Sat. Nav. wiring.
Rebuilt Motor
283 Small Block 4.6L v8
Bored .030 Over
Forged Dinan Internals
Dinan Stage 2 Engine Software (Chip)
K&N Intake
Eisenmann Dual Catback Exhaust
Borla Headers
EMp Stewart Components High Flow Water Pump
Eagle Racing Cams
3:15:1 e39 M5 Differential Swap(Newest Mod)
Royal Purple Synthetic 10w-30 (Soon to be 15w-xx)
///7
Engine Torque: 365.062
Engine Power: 340.210
Old 03-07-2010, 04:04 PM
It has the original sticker - showing sport package and such
** Removed **
Old 03-07-2010, 04:15 PM
M.Wong's Avatar
Mein Auto: The E38
Originally Posted by bmwtime740 View Post
sorry to burst everyones bubble but my 1997 740iL came with the sport/winter package. Steptronic tranny which I use all of the time. I can shift in and out of every single gear without setting it to the M for manual mode.
In the USA, the factory Sport Pacakge was not available until 1999 for the i, and 2000 for the iL.
The iL's in the USA with the Sport Package did not get the lower gearing.
If the iL in the photo is in the USA, unless modified, appears to be an early 2001 iL Sport. However, the OP location is "Germany" so the available configurations are going to be different.
The photos show Vavona (red'ish) wood interior trim, and the black "shadowline" exterior trim. These are both expensive to change out on a non-Sport to make it look like a Sport.
M.Wong
Old 03-07-2010, 10:12 PM
Sure. The Nav screen swap from a 4x3 to the 16x9 screen is a pretty simple swap. If I remember correctly, on my 2000 740 which originally came with a 4x3 screen, I swapped it to the 16x9 screen before I updated to the MKIII (& later to a MKIV).
That 740iL probably has a MKII Nav unit in the trunk (since it has the 4x3 Nav screen), but that can also be updated to either a MKIII or a MKIV. That also is a pretty simple plug & play.
No wire cutting needed to do either upgrades.
Old 03-08-2010, 01:57 AM
Also have the Euro model. Manufacture location is in Europe, and also my dash doesn't say US. It says EUR.
Rebuilt Motor
Bored .030 Over
K&N Intake
Borla Headers
Eagle Racing Cams
///7
Old 03-08-2010, 10:12 AM
M.Wong's Avatar
Mein Auto: The E38
They were all manufactured in Europe?
M.Wong
Old 03-08-2010, 11:49 AM
The salesman is showing up today to appriase my gay ass problematic Audi. KBB Suggested Retail in good condition is $ 9,000 with a trade in value of $ 5,000 but I am making agreements to get it for its suggested value. Even though they are pretty similar in mileage, year, packages and such.. I cant wait to get the iL! This was the car I first wanted got this superbly unreliable Audi...
So how does the 740i rated on reliability? I know the transmission is ehh but what about electrical and engine, suspension and such?
** Removed **
Old 03-08-2010, 06:38 PM
This iL has the hydrolic suspension if you didn't notice. Gives a great ride. Don't know about reliability with that, but it isn't like the car is really old either. Reliability for these cars is pretty high. I've found that the parts aren't terribly expensive, especially compared to your Audi. Most expensive thing are alternaters. But rarely go out. Might want to see if the cooling system has been replaced ever. I've replaced hoses on mine, cheap and easy. My intake manifold had been replaced also, they are plastic, but so are most in modern vehicles.
I still say go for it, they are really satisfying vehicles.
*Der E38*
manufactured: 7/01
Old 03-08-2010, 08:23 PM
Yes but mine also has EUR where yours will say U.S under the MPH in your gauges.
Rebuilt Motor
Bored .030 Over
K&N Intake
Borla Headers
Eagle Racing Cams
///7
Old 03-10-2010, 01:27 AM
armenian armenian is offline
Mein Auto: 2005 325XI
From all the research I have done, the Sports Package on these cars (ILs) don't come with the 3 spoke M steering wheel, and I have yet to see sports seats on these cars ( That were not swapped in)
Also the IL DOES not come with the steptronic tranny. The 740i's (with sports package) and all 750IL's come with steptronic.
And all of these cars have been built in Germany, according to WIKI.
2002 525I SOLD
2005 325XI Current
Old 03-10-2010, 01:33 AM
I have the navigation unit from my old 525I, 2002. The screen, and the unit that is located in the trunk.
It is basically plug and play. I don't have the wiring harness, but if you had the screen and the unit you should be able to just plug them into your current wiring harness and it will work. But you should doublecheck.
We can work out a price if you wanna buy it, once you get the car. PM me if you are interested.
And I am not 100% sure, but it seems to me that the car has the sports package.
2002 525I SOLD
2005 325XI Current
Old 03-13-2010, 04:25 PM
Post
"Widescreen nav?"
Its got 17's M Parellels but whatever. I applied for the loan so its official, getting rid of Audi unreliable crap. Edmunds shows 45 bulletins for the 4.2L A6 and only 27 for the 740iL lol I know them ZF trannies are garbage on both Audi and BMW but I'll get it rebuilt. I dont care. Well worth it. Waiting for the approval decision, so I'll keep updated.
** Removed **
Old 03-14-2010, 05:46 AM
"Widescreen nav?"
Yes it is the wide screen one.
Car Fax will also let you know if it has the sports package or not.
Regardless it's a very nice car!
Good luck with the loan.
2002 525I SOLD
2005 325XI Current
