Old 03-09-2010, 09:35 AM
teacherblh teacherblh is offline
Mein Auto: 2007 328i
Exclamation Tire Pressure Monitor System: How reset?
I have the red exclamation point (tire pressure warning) light on. How do I reset it? I do not have the "i drive" system. Help!
B
Old 03-09-2010, 09:51 AM
Grey3's Avatar
Grey3 Grey3 is offline
Mein Auto: 2009 335i
You might want to check and see if you need air in the tire, if it is low then fill it up that should clear the code. Also use the search button, I'm pretty sure this topic has been addressed already.
2009 335i Sedan| Space Gray Metallic | Black Dakota | Aluminum | Premium | Sport | Cold Weather | Steptronic | Paddle Shifters | iDrive/Navigation | Comfort Access | Parking Distance | iPod | Sat Radio | JB3 | Dual Cones
Old 03-09-2010, 10:18 AM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
Check the tires, read the manual. If everything really is ok, you can reset the TPMS using the cruise control stalk.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 03-09-2010, 10:40 AM
guerilla twang's Avatar
guerilla twang guerilla twang is offline
I do my crosswords in pen
Mein Auto: OEM+ 330i
That^ or just take it to your dealer and they'll air your tires and clear the code for you.
Old 03-09-2010, 11:19 AM
Not a real doctor.
whoa! No, no! If you've lost air overnight due to a slow leak, you might be able to fix the run flats. However, if you drive on them, game over. And then you'll likely need to replace both tires on that axle. Better to check it out first.
Old 03-09-2010, 11:23 AM
energetik9's Avatar
energetik9 energetik9 is offline
energetik9
Mein Auto: 911 Carrera 4S
I just added air and the code cleared itself.
Current - 2009 Carrera 4S
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
"In car rock, paper, scissors 911 beats Prius everytime."
Old 03-09-2010, 11:40 AM
cali311soca cali311soca is offline
Putting the O in O face
Send a message via AIM to cali311soca
Mein Auto: 2004 M3 6sp
First check and re-inflate all tires to proper/desired pressures. Scroll through your on-board-computer till you find the tire with the exclamation in the middle and the word "INIT" underneath it. The car has to be at a complete stop for you to be able to get this option. Once you find it, press the button on the tip of the stalk inward and hold it until you get a check mark. Once you see the check, (might have to press it twice and hold) you can drive away. All tire pressures are now recorded.
Friends don't let friends drink Monster and drive
