Old 03-11-2010, 08:45 PM
GermanRides GermanRides is offline
Mein Auto: Glacier Blue 528i
Question Changing the oil line to the Vanos.
I need to change the oil line to the vanos on 2000 528i.
I see the lower bolt holding the oil line in place. How does one get
a tool of some sort in there? Does the entire top portion of the engine need to be
removed to get at that bolt?
HAs anyone done this procedure?
Old 03-11-2010, 08:50 PM
guvy16 guvy16 is offline
Mein Auto: 2000 540
I have the same problem. I ordered a new vanos line from rmeuropean , but im waiting to get time to change it out.
Old 03-11-2010, 09:22 PM
cn90 cn90 is offline
Once the Air Filter Housing is OFF, it is easy.
I re-used the 2 aluminum washers.
Best is to do this DIY, once the housing is out, it is a piece of cake. You likely has leak from the Oil Housing Gasket too:
http://www.bimmerfest.com/forums/sho...d.php?t=414315
Old 03-11-2010, 09:34 PM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
http://www.realoem.com/bmw/showparts...01&hg=11&fg=30
Is the line itself leaking or is it leaking at the bolts? The other end of the vanos line goes to the oil filter housing. As you have seen things are tight in that area. It's a 19MM, I can tell you that much. I've never tried to change just the line but I have done several oil filter housing gaskets. Do not over torque these hollow 19mm bolts, they will break off in there and ruin your day.
you guys might consider taking the belly pan off the bottom and having a look around below the oil filter housing. Chances are if there is a significant oil leak it is the oil filter housing gasket, very common on all the I6 BMWs.
Old 03-11-2010, 09:36 PM
1+
The Torque for these 19-mm Banjo Bolts: 32 Nm.
Old 03-11-2010, 10:08 PM
Thank you for the link. Plenty of bolts to get the entire oil filter housing out, but ok.
I believe the oil line is leaking and I should replace the gasket on the housing since I am removing it to change the line.
Old 03-12-2010, 08:34 AM
wice.lt wice.lt is offline
Mein Auto: 525iT, Porsche
I concur with cn90. Once the air filter is off then you can get to it. I also re-used the aluminum crush washers and no more oil leaks...
2002 525iT
Toledo Blue
Sport
Xenon
Old 03-12-2010, 08:41 AM
Yes,
I suggest that you do the whole thing in one shot:
- Oil Housing Gasket
- Seal the 2 Freeze Plugs in the back of the housing.
- Change the oil Line to Vanos.
Budget about 3h for this job. Not hard, just pay attention to things in the DIY.
Old 03-13-2010, 10:43 AM
I don't really want to pull the whole Oil Filter Housing. I replaced the thermostat and after putting everything back together, I noticed the Vanos Line was leaking. I just want to replace the Vanos Oil Line. I don't see a way to get a wrench on the bottom Oil Line bolt. I am not sure if this can be done without taking everything out? It is such a tight squeeze.
Fan/Alt/Air Filter/Vanos....etc....
Can that lower bolt be handled without all of the other dismantling?
Name:	IMGP0861 (Medium).JPG
Old 03-13-2010, 01:10 PM
Poor you!
You can approach it from below. Remove the Splash Shield (Phillips screwdriver).
Give it a try from below.
Old 03-13-2010, 05:37 PM
If you do't want to remove the Oil Housing, another approach is:
1. Disconnect (D/C) #1 electrical connector.
2. Move #2 out of the way.
3. D/C #3 (connector to oil pressure sensor).
This should give access to the bottom banjo bolt of the Oil Line to Vanos. Hope this helps:
Old 03-14-2010, 11:29 AM
cn90 thank you for your help. I was going to try method #2 and see if I can get a wrench on that Banjo. I don't think it can happen this way as the angles are tight and just plain wrong.
I just cant take all that stuff out to get at this Oil line so I must make it happen.
Old 03-14-2010, 05:05 PM
Why don't you replace the Oil Housing Gasket as well, then it is a piece of cake.
As I mentioned, if you follow steps #1-3 above (Simply disconnect the connectors), you should be fine. Do you have LARGE hands?
Old 03-14-2010, 08:22 PM
I do have large hands but was ale to get it done. In 2 weeks I have done the Valve Cover Gasket, Thermostat and now the Vanos Oil Line.
Thank you so much for your help.
JC
Old 03-20-2010, 11:43 AM
nyclad's Avatar
nyclad nyclad is offline
Mein Auto: 2002 530i Sport
Got it done.
I just finished this job today without removing the oil filter housing. It took about 30 minutes total. Most of that time was trying to figure out how to remove the banjo bolt to the oil filter housing.
Background:
I replaced the oil filter gasket about a month ago, and realized I was still losing oil at about 1 quart every 2 weeks. With a small mirror, I noticed there was fresh oil coming out of the lower crimp fitting on the VANOS oil line. There was not much of any oil above this point.
After removing what cn90 said, I realized the alternator's upper connector (voltage regulator?) was in the way. I disconnected the battery for safety and removed the alternator's upper connector. That helps a LOT! I also removed the upper intake boot, as that annoying resonator(?) box gets in the way.
I managed to fit a 16 point 19mm wrench in there to break the friction. Once overcome, the banjo bolt is easy to unscrew. Don't drop the crush washers!
With the VANOS oil line already removed.
Picture 013
The old VANOS oil line. Notice the oil appears where the banjo fitting meets the crimp. Thats the lower portion of the oil line that connects to the oil filter housing. I should have suspected this as the banjo fitting turns 360. The banjo fitting on the new VANOS oil line doesn't move at all.
Picture 016
New line about to be put in place. Don't tighten the banjo bolts until you get both sides loosely threaded into their fittings. New oil line is clean and shiny....
Picture 017
Old 03-22-2010, 10:03 AM
I did drop one crush washer (Top one) and the lower one was already gone.
I am trying to figure out what size they are so I can replace them. One top and one bottom?
How important are these? What do they do?
What size are they?
Any help would be appreciated.
Old 03-22-2010, 10:43 AM
The Banjo Bolt is M14 (which means the diameter is 14 mm).
Options:
1. Remove your plastic shiedl under the engine, likely down there.
2. Go to dealer and ask for these, they should have them.
3. Or autoparts store and buy aluminum washer with I.D. a tiny bit more than 14 mm.
Best is to bring one washer to compare.
These washers are important, they prevent LEAK!
Old 03-22-2010, 10:45 AM
Thanks cn90,, how important are they to be in place? The lower one was already missing and I dropped the upper one. I did remove the shield and can not find it.
Is there supposed to be a top and bottom washer?
Old 03-22-2010, 10:50 AM
At EACH connection, there are 2 washers. So total = 4.
And YES they are important, they are under very high pressure.
Go to dealer, they are cheap washers.
Old 03-22-2010, 10:54 AM
wow 4? ok then the PO lost 3 of them. So 1 on each side of the line? Yeek, ok here I go again to get that lower Banjo bolt out. Grrrrrrrrr
"Poor You" lol,,, yea poor meeeeeeee!!
Old 03-22-2010, 11:54 AM
Past Sponsor
Mein Auto: e39 5
why are we guessing here guys?
get on realoem and look up the correct part you need.
http://www.realoem.com/bmw/showparts...42&hg=11&fg=30
find the part number. in this case it is: 07119963200
copy/paste that number into my website or take that number to a dealership if you need the parts today.
http://www.eactuning.com/parts/produ...ls/07119963200
Old 03-22-2010, 01:50 PM
Hey thanks guys I have ordered 4 from www.BMAautoparts.com
Thanks for your input. Now where did I put my SMALL hands?
Old 03-22-2010, 01:52 PM
Why didn't you go to your local BMW so you don't have to pay shipping charges?
Pull your oil housing and go the gasket too.
Once the oil housing is out, it is a piece of cake.
Old 03-22-2010, 01:54 PM
My friend owns BMA Auto,, I don't pay shipping.
To do the housing gasket I need to Remove the fan,,, drop the Altnerator and then pull the housing correct?
Not wanting to remove all of that I want to do just the washers on the oil line just like before.
Old 03-22-2010, 03:27 PM
nyclad's Avatar
What size are they?
Yes, as cn90 said, there are 4 crush washers, 2 on the upper, 2 lower. One on each side of the banjo fitting.
Actually, did you check the side where the banjo fitting mates with the VANOS or oil filter housing? When I first removed the VANOS oil line, the crush washer on the VANOS head was stuck to it, and I had to use a small screwdriver to pry it off. I knew it was there though. Same thing may have happened to the side that mates with the oil filter housing.
They are very important. The crush washers "crush" into the banjo fitting and the other surface you're trying to mate it with (whether it's the banjo bolt or the oil filter housing/VANOS housing.) The crushed washer is made of a softer material such as aluminum or copper, and it "crushes" into the shape of the surfaces and forms a tight seal.
I was able to put on the crush washers and banjo bolt, and install the oil line without removing the entire oil filter housing.
Hope this helps...
Steve
