E46 (1999 - 2006)
Old 03-12-2010, 04:57 PM
Kieffer Kieffer is offline
Mein Auto: BMW
Transmission Fluid
Is there anyway for me to determine the type of transmission fluid inmy 2001 325i. I'm getting ready to have it changed.
Thank you,
Jim
Old 03-12-2010, 05:08 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Step 1 would be telling us auto or manual.
Step 2 would be to check the wiki.
Old 03-12-2010, 05:09 PM
ardsee ardsee is offline
Mein Auto: 02 325I
You need to look at the sticker on the bottom pan of the transmission, check the color. Then look in the Bentley manual to find out which type fluid you have.
Old 03-12-2010, 07:13 PM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
I dont know how many times it has to be said. The number on the sticker > color of Sticker..............
Old 03-12-2010, 07:22 PM
IAS IAS is offline
Mein Auto: 2013 X3 XDrive 28i
i would not recommend to change trans fluid, check the forum.
2014 328 GT X drive , M Sport, Mineral Grey, Coral Red, Tech. Package, CWP, DAP, Lighting Package, HUD, Harmon Kardon.
2013 328 X drive Mineral Gray, Moonroof, CWP
X3 2013
E90 2011
E90 2007
E46 2005
Old 03-12-2010, 08:39 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
I use Red Line MTL. It is a matter of removing the drain and fill plugs and pumping in new fluid. Both of my BMW's are manual transmission.
Old 03-12-2010, 09:30 PM
Mo.licious's Avatar
Mo.licious Mo.licious is offline
Who is John Galt?
Send a message via AIM to Mo.licious
Mein Auto: 2001 325Ci Convertible
I *would* recommend you change your trans fluid, check the forums!
From the outside looking in, you canít understand it. From the inside looking out, you canít explain it.
Old 03-12-2010, 10:21 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Originally Posted by mo.licious View Post
i *would* recommend you change your trans fluid, check the forums!
+1
Old 03-12-2010, 10:43 PM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
Originally Posted by KrisL View Post
+1
Depends on age and mileage - and use.
Generally speaking, if E46 Auto, it needs to be changed not before 60k miles, and you need to change the pan filter as well - and clean the magnets.
Definitely, not a DIY, be very careful with which oil to use, better ask for an opinion at the main dealer. Also, I have heard of people changing the pan filter with non oem, and they then had alot of problems with slipping.
If its a manual, different story, any bmw approved synthetic gear oil is fine - and no filter to change!
Old 03-13-2010, 06:46 AM
GoingNuts GoingNuts is offline
Banned
Mein Auto: 04 330Ci M-Sport
I would recommend if it ain't broke, don't fix it. Check the forums for my posts.
Old 03-13-2010, 06:53 AM
conrad721 conrad721 is offline
Mein Auto: 2002 325i
Generally speaking, if E46 Auto, it needs to be changed not before 60k miles...
i've read in this forum about this urban legend that if you cross a certain "point of no return", and then change the fluid, you'll screw up your transmission.
i hope this isnt true, and if it is, there's got to be a logic behind it.
2002 325i
Driven...daily.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=153873&dateline=1265945823
Old 03-13-2010, 09:07 AM
Problemeveryday's Avatar
Problemeveryday Problemeveryday is offline
Mein Auto: 2011 335i coupe
automatic transmission oil is changed between 80k-95k depending when the power gets lost dramtically enough for you to realize it. i changed mine when it had 82k. it looked like black oatmeal lol. you should ask your mechanic or dealer for which type of oil to buy if your going to change it yourself. mechanics should have a computer or book that tells em which year/make/model car requires which part.
Old 03-13-2010, 09:44 AM
tk4454 tk4454 is offline
Mein Auto: 2000 328i
the dealership told me i was leaking tranny fluid i looked in the car manual and couldnt find where the dipstick is for it, is there a way to check if its low??
Old 03-13-2010, 09:54 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
There isn't a dipstick. Check out the tranny fluid change DIYs in the wiki.
Old 03-13-2010, 05:02 PM
dont listen to those ****s. theres prolly 1 out of 100 that knows what they are talking about. if your car is shifting good, and there are no visual leaks, no lights on the gauge, then its not the end of the world. but if you wana clear your head, take it to a good mechanic and ask him to inspect it. if you were in CA i woulda told you a couple of the best mechanics around here.
Old 03-13-2010, 06:04 PM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
here is service data for GM and ZF auto trans
BMW CCA Member, Capital Chapter
Old 03-14-2010, 12:47 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
What I mean above is that lifetime oils should last at least 60k miles, with an average change interval of 70-80k miles.
I guess the PDF attached says it all, you should check the sticker on you transmission, it will say which one it is, and choose the appropriate oil from the main dealer.
Also, the pdf specifically states that all measurements should be done by an oem BMW diagnostic pc, so its a main dealer job or skilled specialist.
I would like to say again that the use of an OEM filter is a must, I have heard people having problems with a non oem filter.
Old 03-14-2010, 09:18 AM
phlfly's Avatar
Mein Auto: 07' 550i
It's only $35 OEM filter, even cheaper then from ECS
Old 03-14-2010, 09:43 AM
Nando779's Avatar
Nando779 Nando779 is offline
Send a message via AIM to Nando779 Send a message via Yahoo to Nando779
Mein Auto: 2003 325Ci, Orient Blue
Slipping caused by the filter? That sounds a bit odd Did they mention the fluid they used too? I would think it would be the fluid they used that is causing the slipping.
My bimmer and the son of Sam himself.
http://www.facebook.com/Nando.Alvarez
Old 03-14-2010, 11:03 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Strange but yes, fluid was correct, filter was not oem, and it was slipping. Changed to oem filter and all was fine.
Old 03-14-2010, 12:19 PM
Nando779's Avatar
That is very good to know. Will save others some time and headache.
