Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
Gary: Help with 19" tires for 2008 X3 Sport
Gary: as you and other Bimmerfest posters know, options for 19" tires for the X3 are limited.
I would like to switch to an all season, longer mileage tire other than the OEM summer tire short mileage Pirelli PZero Rosso's but keep my 19" rims. I post here as I know many other X3 owners have the same questions. Question one: I have Style 191M Y spoke rims. Do you know what the dimensions of the rims are? The 2008 sales brochure in one place states they're 19 X 9 front and 19 X 9.5 rear but in another place it lists them as 19 X 8. Several other places I looked including this link http://felgenkatalog.auto-treff.com/ state that they're 19 X 8.5 front and 19 X 9 rear and this seems to be what I have when I try to measure them (on the vehicle...not an easy or accurate job). Question 2: If I have 19 X 8.5 in front and 19 X 9 rear, would the Michelin Pilot Sport A/S Plus 245/45ZR19 work. My review of specs seems to suggest so, and as it would a higher profile tire, I suspect the ride would be better. Thanks for your advice, sorry for the long post! |
The Sport A/S+ would be an outstanding choice for an all season tire that has top rankings in wet and dry grip, cornering, as well as fast steering response but with a better ride and longer wear than a summer performance tire. Tires http://www.tirerack.com/a.jsp?a=AB2&...ires/index.jsp
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link. Gary@Tirerack.com
Thanks Gary!
Will take off a couple of wheels in a day or two and post back for others benefit what I find on inner side of rims. If I find a different rim size, we'll have to go at this question again. |
Please let me know, I'm not sure if I have to replace all four tires right now but the rears need replacing. I was going to go with a cheaper tire at factory size 255/40/19, but if I could get something better and longer lasting at 245/45/19 I might do that. I'm not sure how much it will mess up the speedometer and if it will cause any other problems.
BMWCCA Since 2007 ED 28.10.2010 335d ED 09.07.2008 X3 PCD: 04.09.2008 ED 24.05.2006 X3 ED 27.07.2005 X3 |
Larry '11 328iT BMW CCA #115780 |
Front, cast into the back of the Y spoke:
8.5J X 19 EH2 and on another spoke 3 417 267 Rear, cast into the back of the Y spoke: 9J X 19 EH2 and on another spoke 3 417 268 I think that answers the final question for all of us |
I'm not sure if I'm keeping the car and the lease is up in July, but it would be a waste for them to tell me at turn in that I need new tires, so I might as well get them now.
Best to match the same brand and model of tire for an all wheel drive vehicle if only buying two tires.
Just looking at other size options for the X3..considering replacing the factory rear tires with the same size, or going to a different size all around.
Overall diameter on rear/front is 27"/27.3" on the OEM's 245/45/19 all around 27.7" overall...Pirelli Pzero Nero All Seasons, seems like a great tire, $152 245/40/19 all around 26.7" overall...Goodyear Eagle...not a great tire but $97 after rebate, good deal short term? Could get four of these for about the price of two OEM sized rears. I don't need winter traction but need at least 30,000 miles of life.
Help with tire size
Hello , can you use 245 40 19 on the front of a X3 2008 and still use 255 40 19 on the back? Or is there another size I can use on the front (not 235 45 19) and still keep the 255 40 19 on the back? Please Help
Thanks Russ |
The only other front size that matches to 255/40R19 other than 235/45R19 is 225/45R19.
Sorry to be anal, but I know nothing about tire sizes. To re-re-confirm, if one were to put the same size tire all around on 19" rims for the X3, 245/45/19 are recommended right?
I'm thinking of upgrading from 18" Bridgestone Turanza Serenity to 19" rims. I like the Serenity and have mild weather where I live. So if I get the 19" rims, I can put 245/45/19 Turanza Serenity all around and can rotate the tires evenly right? How do the Serenity compare with the Pirelli PZero Nero? I'm looking for (in order of priority): 1. Quiet 2. Soft riding 3. Lasts 35k or more miles 4. Handles well in dry and rain (can be summer or all weather) Thanks, Thomas |
While the Turanza Serenity is quieter, softer riding, and longer wear than the Pzero Nero A/s, it is nearly *twice* the cost and only slightly better. Tires http://www.tirerack.com/a.jsp?a=AB2&...ires/index.jsp
Just put on a set of Pirelli Scorpion Zero Asimmetrico 245/45 R19 all around. Link to tires below.
http://www.us.pirelli.com/web/catalo...pe=CAR-SUV-VAN Put about 1000 miles on them and so far so good. Regarding Thomcat's post, I would be careful rotating them since the rims are different sizes. I'm going to rotate the rears and fronts separately. I wouldn't want to put narrow wheels in the back and wider wheels in the front. |
Rotating
What's the harm in rotating separately? I would think that's only a problem if the tires were directional. |
Hey Gary,
How do you feel about the tire size 245/40/19 all around? |
For what year and model of X3?
For the 2007 X3 with the stock 19" sport wheels
While that would fit with no problem, it is a bit shorter in height so may look a bit odd. Also be sure to bump the air pressure up by 3-4 PSI all around to help with the difference in load capacity of the shorter 245/40R19 size.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
