Old 01-21-2014, 04:15 AM
Galla10188 Galla10188 is offline
Mein Auto: 2007 328XI
Exclamation Brakes?
So I own a 2007 328xi (74,000mi). Recently have been hearing a slight metal "scratching" or "Rubbing" noise when braking. However the computer says the brakes have several thousand more miles before needing to be checked (for both the front and back brakes). The scratching sound is only noticeable when braking to a stop.
Might I still need to replace the brake pads?
i also heard a very loud scratching noise for about 5 seconds one time when reversing out of a parking lot.... in the middle of a 2 hour trip. Not sure if this is related to the above situation.
Any feedback would be greatly appreciated!
Galla10188
Old 01-21-2014, 07:44 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Take your wheels off and check between the dust shield and rotor for rocks or other debris. There can also be debris stuck between your pads and rotors. Look for score marks on the rotor, front and back.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 01-21-2014, 03:10 PM
Arlene@XIX Arlene@XIX is offline
www.xixwheels.com
Mein Auto: ..
Could be the dust, or could be the pads. At times pads, crystallize causing those type of noises.
Old 01-21-2014, 05:46 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
There is no substitute for getting in there and visually checking the pads - both inner and outer - YOURSELF. Computers can get confused. Or lie.
Yes, also check for rocks stuck in the calipers, bent dust shields, etc.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 01-21-2014, 05:49 PM
luigi524td luigi524td is online now
Mein Auto: '17 540xDrive; '98 Z3 2.8
Exclamation Brake inspection required
Take an hour to inspect all 4 brake calipers / discs and pads. A timely inspection might let you avoid brake disc damage from word out pads and save you a few hundred $$$s in add'l replacement parts.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 01-21-2014, 05:59 PM
Thanks for the feedback, I will be sure to take all 4 wheels off and check the rotors, pads, and calipers.
Galla10188
Old 01-21-2014, 06:55 PM
Fastpaddler Fastpaddler is offline
Fastpaddler
Mein Auto: 2016 Jaguar XF AWD Presti
Yes, the OBS estimates the time remaining on your disk pads. My computer says 5000 kms but I know that it is not based on the actual condition of the pads. Usually, when you hear a scratching sound when braking you should get a warning on the screen. If you are not, then the brakes need to be looked at for sure.
brake pads
