E46 (1999 - 2006)
Old 03-15-2010, 05:33 PM
CaptainTrap's Avatar
CaptainTrap CaptainTrap is offline
a man made of men like me
Mein Auto: 2001 330i 5MT ZSP
My car went into limp mode twice today
I pulled over and shut it down, followed by a restart and it went back to normal. I have had the Service Engine Soon light on 2 times this month but it cleared itself. When i got home I hooked it up to my laptop and used carsoft 6.5 to scan it and this is what it found:
-DME Module: ~Idle Speed Actuator (Mechanical Jamming)
~Mixture Deviation: bank 1
~Mixture Deviation: bank 2
-Instrument Cluster Module: ~D7 Fuel Tank Sensor 2 (without fuel pump)
~EGS signal disturbed
-ABS/ASC Module: ~Pressure Sensors
~CAN ERROR: Engine Speed (RPM)
-ZKE/ZVM Module: ~Pin Contact, Drivers Door
~Relay for rear FH drive (passenger's side) sticks
can anyone interpret these error codes and identify anything that may be causing the EML and ABS lights to go on and go into limp mode? thanks
2001 330i ZSP 5MT H&R Sport Cup Kit 18" VMR v710 18x8.5
BMW CCA #: 399644
Old 03-15-2010, 07:31 PM
cmccurdy1 cmccurdy1 is offline
Mein Auto: 325ci
Don't know about the codes but my M3 was doing that-ABS and EML lights come on and a few second later it goes into limp mode. Turn it off and start it up, everythings fine - it does it again in about 30 minutes. Replaced throttle postion sensor and its been fine ever since
Old 03-15-2010, 07:33 PM
Mein Auto: 325ci
Don't know about the codes but my M3 was doing that-ABS and EML lights come on and a few second later it goes into limp mode. Turn it off and start it up, everythings fine - it does it again in about 30 minutes. Replaced throttle position sensor and its been fine ever since
Old 03-15-2010, 07:36 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Try some Extenze in the gas tank....
The road goes ever onward....
(R.I.P. Jever)
Old 03-15-2010, 10:19 PM
lol
BMW CCA #: 399644
Old 03-16-2010, 12:58 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
lol
remove the ICV... see if its actually stuck/dirty/not free...
clean it up real good, set to dry. reassemble.... see if problem persists.
mujjuman
Old 03-16-2010, 10:44 AM
catso's Avatar
catso catso is offline
catso
Old 03-16-2010, 07:38 PM
ok last night i cleared the codes (please note that the SES light is not on nor has been on save for the two occasions i already mentioned. It is usually not on.) And today it went into limp mode again, EML light and ABS light came on and car was sluggish. Shut down and turn back on and its back to normal.
I just got home from work and scanned it again and here is what i got.
DME Module: Mixture Deviation Bank 1 and Bank 2
~and~
Idle Speed Actuator (mechanical jamming)
Instrument Cluster Module: EGS Signal Disturbed
After some superficial research i have found that the EGS is the e46 transmission computer control module. What could be causing this disturbance? are these problems related?
The Idle Speed Actuator is what we call the Idle Control Valve or ICV. When i was chasing my mixture deviation codes several weeks/months ago and had my airbox out i cleaned the ICV and it appeared to be in good working order. I guess Ill take it out on thursday and give it a cleaning as mujjuman suggested. hopefully a good cleaning will remove whatever is jamming it. the funny thing is tho my idle is smooth as butter with no surges. I hope this is related to my new mixture deviation codes because i thought i put those to rest after the leaky valve cover gasket was replaced. is this a reasonable thought?
Anyone else have any ideas? thanks
BMW CCA #: 399644
