you'll laugh. iphone stuck under seat air vent
54K views 128 replies 59 participants last post by  MalibuMafiaV
#1 ·
Had my friend drive my car for two seconds and his iphone went under the driver seat and into the air ducks under there for the heater/air conditioning. How the hell do I get under there!? lol. it's like all the way in under the driver seat in the floor.
#2 ·
Take a wire coathanger, open it up, make a small loop in one end, and wrap a few rubber bands thru the loop.....hopefully, you can get into the opening, and snag the phone using the friction from the rubber bands....good luck !
#5 ·
Yeah, those air ducks really are nasty enemies of skinny phones. Probably peck'em to death in no time. :rofl:
After a lady friend's skinny Samsung almost found its way there, I've seriously considered removing the seats, drilling holes right down the middle and passing a wire loop thru each air duct, to avoid this nasty occurence. Fortunately, even without its armored case, my N97 won't fit in there...
#7 · (Edited)
Call it over and over again, maybe it will vibrate it self out, there's gotta be an app for this :D
Or you can do some 0-60 acceleration runs, drive hard around some corners... hopefully gravity will be your freind.
EDIT: I got my Zippo trapped in there once, and I thought it was a goner, but about 2 months later after a bout of spirited driving it flew out of the vent and into the rear passenger area.
#9 ·
[/B]
I tried that. Make it more stuck LOL.
Only way it's coming out is to remove the duct. And that's just to much work.
I guess an iphone 3G-S now lives inside my car.
#12 ·
Tape up all of the other vents on the car, then turn the fan up on high and see if the phone gets shot out?
#13 ·
I laugh at this, but with trepidation, as I have an iPhone which usually sits on top of the (closed) ashtray and tends to slide back and forth a bit when I drive. It's been known to fly off and into the footwell if I take a curve in a lively manner....
#36 ·
#37 ·
You're right, I did laugh. Maybe try jacking the front end up, if it slid that far forward it should slide back out.?.
I have used this tool numerous times in my engine bay. Not having to jack the car up, remove skid plate and retrieve dropped socket, ratchet, screwdriver, etc...priceless.
