Old 03-27-2010, 07:05 AM
prokops prokops is offline
Mein Auto: 02 745i
02 745i - Trouble codes
Hello everyone!!! Long time reader first time poster!!!
I have an 02 745i with 40,000 miles. Recently she threw codes p1043 and p1062.
Here are the symptoms. I had a reduced power warning a couple of days ago. I turned off the car and started her up with no problems. Yesterday the same thing happened and again I restarted her and it went away. Except this time it was followed by the check engine light.
After reading the OBD II codes I get the above mentioned codes. A thorough search of bimmerfest lead me to many websites that had codes listed by my specific codes do to show.
Can someone help me to diagnose these codes???
Tom
Old 03-29-2010, 12:56 PM
Mein Auto: 02 745i
*bump*
Any guru's that could help with these 2 codes?
Old 04-09-2010, 11:01 AM
GermanMade GermanMade is offline
Mein Auto: 2003 745Li
Have the P1043 and P1051 and no one seems to have an answer...along with the P0363...
2003 745 Li
2007 ZX-14
2007 VN2000LT
2007 GV650
2000 Beetle GLX 1.8T
Old 04-09-2010, 04:03 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Found this for code P1043 :
Fault code for variable valve timing...........will require diagnosis with BMW compatible scan tools.
Variable valve timing faults as described for this vehicle actually relate to the variable valve lift control. Instead of having a traditional valve body, this vehicle uses a system to control the valve lift and therefore intake air volume.
Aside from performing diagnostics with a BMW compatible scan tool, check power and ground at the valvetronic control unit.
P1062 is variable valve timing bank 1 limp home mode, full stroke position not reached. remedy is check wiring at vanos, check connections or engine control module
fault.
Found this for code P0363 :
Code P0363, means a mutliple cylinder misfire has occured. The computer was unable to determine which cylinder it is or all cylinders are missfiring at random and no specific order.
My BMW ACS7
Old 04-10-2010, 11:19 AM
Mein Auto: 02 745i
TechFreak:
You beat me to the response. I finally got the info from a buddy at BMW!
Thank you for the repsonse!!!
Old 04-16-2010, 11:35 AM
fault.
vanos
Are these one and the same and if not where are they located to verify connections etc
2003 745 Li
2007 ZX-14
2007 VN2000LT
2007 GV650
Old 04-16-2010, 11:53 AM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
Remember that codes can create other codes.
The first thing you should followup on is the Misfire. That is the mostly cause of all the errors and easiest to troubleshoot.
See here http://www.bimmerfest.com/forums/sho...d.php?t=432390
Black 2002 BMW E65 / 745i 114K
My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit.
Old 04-20-2010, 01:24 AM
TechGuy TechGuy is offline
Mein Auto: E46 325i
Take out the plastic covers. The top one via 4 size10 nuts the one that says BMW by simply pulling out. You will see an electric motor of which the tip is shoved into the head cover (bank1 which is cylinders 1-4 (right side)). Check for any abnormal signs, say for discolourations, etc. This motor turns as the result of which the eccentric shaft will move up or down causig your valve lifters to fully or partially open the valves. It could well be your servomotor. These fail on 4 cylinders everytime it's Tuesday and remember BMW V8s are really (believe me they are) 2 of those 4s. They are just so alike. But I'm only guessing. Check also for signs of oil sludge or dirt/debri inside the engine as this can form into unclear signals from the eccentric shaft sensor which sits at the very end of the inlet shaft where it is toothed to help this sensor generate signals telling the Valvetronic unit how things are and it telling the servomotor to bolt on or off. I hope I'm making sense.
Old 02-04-2013, 08:08 AM
BimmerBeast01 BimmerBeast01 is offline
Mein Auto: Bmw 6sp 540i/ Bmw 745i
whats up!!kind of new to this maybe someone can help me with this...i hope lol, Ive taken my 02 745i to a well know euro car shop and he scanned it came up with these codes
2761
2760
273d
2783
27E3
but these next ones are i think the ones driving me crazy lol
282C
27EC
27ED
would like your insight on this plz ...oh and ive been having water accumulation in the REAR pass footwell
Old 02-04-2013, 10:44 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
273D - Catalytic- Converter Conversion bank 2
2738 -Catalytic- Converter Conversion but you have written code as (2783)
27E3- Knock Sensor 2
Not sure on the rest.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 02-05-2013, 06:06 PM
thx Rook!!
Old 02-05-2013, 06:15 PM
Found out the last 3 codes are modules not communicating 'timed out' (smh) ZGM perhaps? water has been acc on pass foot well, damn sunroof drain holes are clogged, cant seem to get it to drain! tried a wire didn't work,,is there a kit i can buy that can make this job easier? I'm sure dealers have something for this
Old 02-05-2013, 09:22 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Usually people will test it with water and try to "rotor router" it out with something and also try using compressed air.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 03-06-2017, 05:58 AM
Deeivy Deeivy is offline
Mein Auto: 745i
hey didnt you every find out the problem for the code p1062
