Old 03-27-2010, 10:32 AM
BobSherwalla BobSherwalla is offline
Mein Auto: 650i Convertible
Help!!!
My key fob is not making the clicking sound and staying in place when I am trying to put the fob in. I get an alert with a picture of a key with a slash through it.
any ideas on why this is happening and how I can fix it???
Old 03-27-2010, 10:48 AM
pablo645's Avatar
pablo645 pablo645 is offline
Do you have the comfort access feature? Also if your key is not fully charged, this indication will come up as well. One of my FOB had this issue and the dealer replaced the battry and reprogram it. The car will reject the key if it cannot pick up the signal so you may have a battery issue in the FOB
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 03-27-2010, 10:51 AM
Yes I have comfort access.
Old 03-27-2010, 10:55 AM
pablo645's Avatar
Your battery might be dead. the Key actually has two battries and one controls the comfort access. If you have been driving with the FOB in in the ignition for a while, it should have been charging. If you have not placed it in the ingnition slot for a while then the battery is dead. It's easy to forget to charge since you have gotten used to just pressing the start button. If you have the second FOB, try it and see but all indication is pointing to the FOB battery.
Previous Cars:
Old 03-27-2010, 10:59 AM
docpaulo docpaulo is offline
Mein Auto: 07 650i Convertible
you can buy the button battery from any store... remove the actual key from the holder and look at the holder from the back and the part that the metal key exposed there is a small slot that you can pry open and the battery will come out...
it should not need reprogramming....
but it could also be the key itself is bad... but I'd try the battery replacement before spending money at the dealer unless you're under warranty
07 650i Cabrio CPO, Titanium Silver
Black Matte Grill
Dark Birch Wood Interior and Shifter
HUD, Cold Weather and Sports Package
Logic 7 Sound
Aluminum Racing Pedals
K&N Air Filters
Rays Master Piece REM 20" Forged wheels w/ Conti Extreme DWS
Old 03-27-2010, 11:08 AM
Thanks for the responses. I will go get a new battery and try it out. Worst case I have an extended warranty on the car and I will take it to the dealer if it doesn't work. I will let you guys now how it turns out!
Once again thanks for the help!
Old 03-27-2010, 11:11 AM
pablo645's Avatar
No problem and let us know what happens.
Previous Cars:
Old 03-29-2010, 08:17 AM
After looking at the slot I felt around it and found that the latch inside was just stuck and the system was looking for a key but it wasn't in there. i just pushed the latch up and everything works great now! I also changed the battery in remote just to be on the safe side.
Old 03-29-2010, 08:19 AM
pablo645's Avatar
Great! Glad things worked out
Previous Cars:
