E46 (1999 - 2006)
Old 03-27-2010, 10:45 AM
mohammed.khalid mohammed.khalid is offline
Mein Auto: 2001 BMW 325i E46 Silver
E46 White smoke from the exhaust
Is it normal for an 2001 BMW 325i to produce light white smoke (Almost transparent) from the exhaust? Especially when you turn the car for the first time (The engine is still cold).
Old 03-27-2010, 11:22 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
It's probably steam from the condensation inside the exhaust system.
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 03-27-2010, 05:12 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
yep sounds normal to me, especially if it goes away and happens in COLD starts
mujjuman
Old 03-28-2010, 11:53 PM
Sp00k Sp00k is offline
Mein Auto: BMW E46 316i '01
Yeap seems normal, it's caused mostly by cold weather or/and cold start, heat it up normaly, and observe if the "white smoke" becomse more transparent. You can ask a friend to tap the acceleration pedal for a short period of 10-20 seconds and observe the smoke... in seasons when the temperature varies from 5- below 0 Celsius, you might see some drops of liquid don't worry that is just water melting in the exhaust system... heat the car well and that too will go away!
Old 03-29-2010, 12:29 AM
e46kid2000 e46kid2000 is offline
Mein Auto: 2000 323i 346 4dr
yeah i say the same just let the car run for a minute or two and it would stop something similar was happening to me but just let the car run. trust me it will work
Old 03-29-2010, 03:53 AM
Schnell!!!'s Avatar
Schnell!!! Schnell!!! is offline
.... Wha? ....
Mein Auto: E46 325
In this case unless it has a very sweet smell, i guess almost like burned sweet tea, then you should be alright. (present of a busted head gasket or similar.)
I dont know why either but for some reason mine did it more before I changed the O2 sensors , yeah, not sure, uneven burn shouldnt mean condensation from a clean burn... maybe just a coincidence of temperatures...
NO MORE AUTOBAHN.... NO MORE NURBURGRING...
-1998 540- sold... sniff..... miss ya ol blue...
-2002 325 titansilber
-The 2 wheeled toy: 1970 BMW Motorrad
Old 04-26-2010, 05:41 PM
stuartmw stuartmw is offline
Mein Auto: 2002 330cic
If i am not mistaken, I believe that white smoke means that the College of Cardinals has selected a new Pope. All the more fitting for a German car to be selecting a German Pope.
Sorry...but i couldn't resist.
Old 04-27-2010, 07:55 AM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
Mine smells abit like that...some strange smell, abit sweet.
No coolant leak though..
Old 06-11-2010, 12:11 PM
ln3grls ln3grls is offline
Mein Auto: 2001 325IC conver
I am having the same problem 2001 325Ci, no visible leaks and i have to add coolant once and a while
Old 07-15-2010, 08:06 AM
yoda1138777 yoda1138777 is offline
Mein Auto: 2003 BMW 325i 4dr S and P
Mine just did this same thing today at 7:30 am and Im in Arizona and its hot here. My buddy thinks that I had a bad tank of gas but I usually go to Chevron and Im always putting in super all the time. I hope it isnt a sign of a head gasket if it is the car is going.
2003 325i 80,000 miles
Old 07-15-2010, 10:57 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Head gaskets don`t "go" as matter-of-factly as say, VANOS seals or CVV (which are sure bets for failure somewhere down the line)....it`s usually precipitated by overheating, brought on by a failed component in the cooling system (a good reason to rebuild your cooling system NOW if it hasn`t already been done)
The road goes ever onward....
(R.I.P. Jever)
Old 07-15-2010, 11:01 AM
I just did the water pump and had the coolant changed when I had to have my engine mounts replaced. The coolant level is fine and the dipstick didnt have any weird colors it actually looked really clean. One of the shops I call said it may be the Crankcase Valve? the one with 4 hoses and that its gonna cost between 300-480 bucks.
Old 07-19-2010, 08:58 AM
jtb.baker jtb.baker is offline
Mein Auto: 2004 330CiC
Defintely could be CVV. Had the same issue last winter and then started getting the goose honk sound after the enging shut off. Replaced CVV and hoses 3 months ago and no issues since though I have not been through the winter with the new CVV.
Old 01-04-2012, 10:19 PM
veli510 veli510 is offline
Mein Auto: 2001 bmw 330i
if there is no honk noise after engine shut off, then CVV is good? I'm getting a weird honk noise and i have big cloud of white smoke after a few seconds. It goes away though
2001 BMW 330I
Old 01-05-2012, 04:05 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Yup, most likely bad CVV. Have you had it scanned for codes?
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 01-05-2012, 05:07 AM
BeauDog BeauDog is offline
Mein Auto: 2004 320i 2010 Lexus RX
Bless you your Eminence!
Old 01-05-2012, 11:10 AM
I'm getting no codes. I changed my CVV about a year ago. It does make a weird honk noise everytime i shut off my engine. I do hope it's CVV and not a head gasket.
2001 BMW 330I
Old 01-05-2012, 12:29 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I'd say it is almost assuredly the CVV. Your head gasket will only let go if you overheat it, otherwise these engines are pretty bulletproof.
Old 01-05-2012, 06:13 PM
Jonathan, where did you get that avatar? Looks like the hairpin at the Canadian GP
Name:	Montreal F1 018.jpg
ID:	307275   Click image for larger version
Name:	Vettel F1 095.jpg
Old 01-15-2012, 06:13 PM
Old 01-16-2012, 04:28 AM
Cogito Ergo Zoom
Mein Auto: 325iT
That is indeed the hairpin in Canada. I'm sitting in the fourth row on the right hand side. Our seats ( we've had them for 3 years now) are about 15 feet from the edge of the track. Close enough to clearly see the drivers hands on the wheel. I think that picture came off Fernando Alonso's website.
Old 01-16-2012, 04:32 AM
Cogito Ergo Zoom
Mein Auto: 325iT
Pics from 2011. We did the pitlane open house on Thursday. Highly recommend if you haven't done it yet.
ID:	308395   Click image for larger version
ID:	308396   Click image for larger version
Old 01-17-2012, 05:22 AM
I have been attending since 1982, about 15 times so far. I have the next generation with me now, my 24 YO son. This will be his 5th race in 2012. We sit in Sec. 24 one row off the rail.
Photos of us in our grandstand, race start in the rain and the amazing finish.
Name:	Friday Practice F1 057.jpg
ID:	308554   Click image for larger version
Name:	The Start F1 004.jpg
ID:	308555   Click image for larger version
Name:	Button Win F1 014.jpg
Old 01-17-2012, 08:38 AM
Cogito Ergo Zoom
Mein Auto: 325iT
My first Canadian GP was 2004. We sat in section 24 the first two times. Then one year over the Senna Turn, then the end of the hairpin (too far from the track) and then we got these seats and we're never giving them up. For 2013, we're doing Canada and NJ. The track at Port Imperial is about 45 minutes from home. As soon as I can get a layout, you know I'm going to drive it.
If you come to NJ, after race barbeque at my house. All are invited.
BTW, if you look at your post race pic, there are some guys standing on the steps at the right of the low grandstand; pretty sure that's me in the red jacket.
Old 01-17-2012, 09:01 AM
2013 f1
Very cool. 2011 was a long wet race day but I will remember it as one of the best races I saw in Montreal. NJ looks fantastic, hopefully there will good access to Hotels as Montreal, as you know, is crazy during F!.
