E28 (1982 - 1988)
Old 04-03-2010, 07:01 PM
kraigka kraigka is offline
Mein Auto: 84 533i and 84 325e
Speedometer, turn signal, obc, power antenna, all not working
Can someone help me with a problem whereby the speedometer, turn signals, OBC, power antenna, and center check light are not working? The car still starts and the tachometer still work. Also, the 4 way hazard switch works as well. Might it be a bad main computer board in the instrument cluster? A quick reply from anyone out there would be greatly appreciate, especially if you had these problems and solved it!! Thanks....
Old 04-03-2010, 08:52 PM
86BlueDoor 86BlueDoor is offline
Mein Auto: 1986 528e automatic
Try resetting your Service Indicator lights. The batteries on your 'cluster' board might be giving out especially if they have not been 'updated'. Worth a try and it doesn't cost anything to try it. Good luck!!
Old 04-03-2010, 09:05 PM
Thanks for the help.....do you have instructions on how to replace the cluster board battery and where do I go and get the batteries (Radio Shack) and what type of battery do I need?
Old 04-04-2010, 11:40 PM
First, I would try resetting the SI lights (green lights on dash) before I spend $$$ on replacing the cluster board (w/batteries).
Just replacing the batteries may not completely resolve your problem. An 'up-dated' cluster board will be better than the existing unit (especially if you have the original unit..which I doubt).... if this is your problem???
So, again, try resetting and see if it makes any difference. If it does makes a difference but doesn't last very long then I would consider replacing the batteries first before I spend more money on a 'new' one.
Check out this link and photos:
http://www.unofficialbmw.com/repair_faqs/sil.html
