Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 03-28-2010, 09:10 AM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Odd oil pan plug..
Well I did the oil change on my 740i myself, the dealer had refused to change my oil due to the odd looking drain plug in my oilpan... I bought 8 quarts of mobile 1 5w-30 and a WiX filter and headed home.
Turns out the dealer was right, there was a very odd looking oil pan bolt.. I have attached a picture, the bolt is a pretty smart little design and was obviously installed due to someone stripping out the threads.
I searched the patent # on the plug- patent # 5197567 http://www.freepatentsonline.com/5197567.html
I am not super happy about the non OE plug, and i will probably replace the pan at some point, but for now the plug is functioning..
Oil change complete, light reset.. ready to roll again. A little irritating that the dealer wont change my oil..
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 03-28-2010, 01:58 PM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
That is because the dealer didn't feel like paying for a new oil pan and plug, should he "damage" it upon removal - I would have done the same thing...
...can't tell from the pictures how much thread contact the plug actaually has, but I would be careful that you sdon't accidentally cross-thread it.
White 1993 850Ci - 251,187 miles
Black 1993 850Ci - 125,508 miles
Old 03-28-2010, 02:41 PM
rrtec's Avatar
Bored Worker
It functions like a butterfly anchor.. The round plug has a thick plyable rubber o-ring that has a threaded rod attached to the butterfly anchor. You then have to pull down and twist to get it to start tightening.. It was nerveracking for sure..
FC3S LS1/6Speed
Old 03-28-2010, 08:29 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
i sell those at my store. this is for times when someone that has removed a proper plug that has been stripped out. instead of retapping the hole, many people will go this route and these are honestely for temporary use. but they do work in cases where you cant get or afford a new oil pan or it is not repairable. i see them all the time.
you may want to see of you are able to retap the threads to a larger size, use the proper type of bolt/plug to replace it with a larger size. or get a new lower oil pan.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
