Old 05-20-2013, 01:47 AM
jopoth jopoth is offline
Mein Auto: BMW X3
problem sunroof
Originally Posted by Chancevought953 View Post
Mine is back from shop. My wallet is empty but I can see the sun through a fully opened rebuilt panoramic sunroof. They used parts from 2 of the 3 repair kits available. Says I will never have another problem with it and they will stand by it. Also said the problem comes from some of the plastic parts cracking over time due to what? Answer: sunshine. He showed me the service bulletin for the roof and no kidding it says that if the roof is subjected to the sun for long periods this and that particular part is at risk. Hmmm. Sunroof on the roof. Gonna see alot of sun.
But regardless it is fixed.
Hello,
I also have a problem sunroof, bad closing the small roof, could you tell me where I can find the PDF for the repair, I thank you in advance, cordially
Old 05-20-2013, 08:03 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
here you guys go.
you have to lower it incrementally while pushing the rear plastic triangle pieces one at a time a little bit at a time, it will make sense after you read the instructions and look at it.
My roof failed about a month ago, have not gotten around to doing the "fix" yet.
Old 05-21-2013, 02:11 AM
Mein Auto: BMW X3
Hello,
Thank you for your prompt reply, but I'm sorry but I can not read a PDF file
can you send it to me at the following address: dpomat@free.fr
Thank you again.
Regards
Old 06-12-2013, 06:53 PM
DBSonic74 DBSonic74 is offline
Mein Auto: 2006 530xi, 2005 X3
Just bought a 2005 X3 and the roof is stuck in the closed position. We just had some very heavy rain and water came into the rear of the X3 and flooded out the battery compartment. Mechanic said the drains are clogged in the roof area (something along those lines) but cant get to them because of the stuck roof. Very disappointed in my X3, my third BMW.
Old 06-13-2013, 02:53 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
i scared my wife in to not using it
15486372<-----
Old 06-13-2013, 04:11 AM
Here is what I'm thinking. I have had cars before with removable sunroofs, non removable sunroofs (the type that just flip up), t-tops(which were notorious for leaking but mine never did) and recently 2 e60s with the motorized sunroofs which never had any issues.
Im reading tons of threads on different forums with BMW e83 owners saying they are getting repair estimates from $3,000 to $5,000 with one owner saying he had the issue fixed 3 times....
I really don't care if the panoramic sunroof works or not at this point, I just don't want rain coming into my trunk area and battery compartment. Since my sunroof doesn't work and I can pretty much say with confidence from all the threads I have read so far that if it did work it would just break and leak eventually anyway.
What if you just seal the window up like a rear window or windshield. I have never had any rear window or windshield leak on any of my cars. I understand what another member is saying when he said " why bother having a sunroof if you can't open it " but at this point I just don't want it to flood out my car.
I would assume the cheap fix would be sealing it up with clear silicone or to be a little more thorough, sealing it like a windshield with the adhesive they use along with the black weather stripping.
The pic is us using a cup and paper towels getting the rain water out of the trunk area and battery compartment. Fun day...
Old 07-15-2013, 06:25 AM
vince217 vince217 is offline
Mein Auto: 2011 R56 Non-S
this finally happened to me last friday. thank you everyone for the information on this forum! I was able to manually close it using the tips here and the PDF file. When I have the time, I will attempt doing the fix, but for now, i am glad I was able to close the sunroof! I just hope the seals are on tight... will have to wait for the next time I'm driving in the rain to find out!
2005 E83 X3 2.5
2010 Acura MDX Tech
Old 07-15-2013, 12:51 PM
since I manually closed the roof after it breaking, I have not had any leak issues, even is a few torrential PNW downpours, you have to pay attention to it being closed properly when manually cranking it down.
Old 07-27-2013, 09:21 PM
Jeff Vallarino Jeff Vallarino is offline
Mein Auto: 2005 x3, 1960 bmw 700
I have the same problem on my 05 X3. The sunroof will open and close normally if I slide the switch forward or backward. If I push the sunroof button the front and rear glass will open to the vent position and the headliner will open an inch or so, but if I try to close it the glass will go down and come right back up. I can close it manually, but would like to get it working as it should. My thought is either the cable guide or the rear mechanism is not moving it at the right time or sticking. Does anyone know the sequence of events required to get the vent glass open and closed as it involves both the front and rear glass along with the headliner. Any input would be greatly appreciated
Jeff
Old 03-21-2014, 03:28 PM
MCmikPort MCmikPort is offline
Mein Auto: 08 X3
Sunroof Modification
I've just purchased a 2008 X3 E83 and found the vent function jams when trying to close and the re-sequencing does nothing because of the binding between the rear and front glass.
The PDF for sunroof repair as well as 2 Youtube videos were helpful in getting the roof closed. Has anyone performed the "modification" whereby disabling the rear roof section on a 2008 X3?
Old 02-02-2015, 06:41 PM
oakwood909 oakwood909 is offline
Mein Auto: 2004 x3 2.5i
Sun roof mod
[QUOTE=Martin5333;5450062]FHODD
Mein auto: BMW 525i Executive E61
View My Garage
Rear Sunroof issue: fix it yourself.
With my 5 series touring E61 I had the same issue and I modified my roof myself.
The roof mechanisms for the 5 series and X3 and X5 are practically the same.
With attached instructions you can lower the rear roof and then choose to do the modification.
Regards
I had the same problem with my 2004 x3 sunroof rear glass stuck in vent position. I downloaded the instructions and found a YouTube video that walks you through it titled:
BMW x3 sunroof repair 1 and 2
My personal input is that I noticed pictures of repairs with large chips and broken pieces making it look untidy. Only the triangle piece hanging down on the in board side of the shuttle needs to be removed. Mine had a casting line that ran parallel with the bottom edge of the shuttle I used that line and a Dremmal tool to cut it off. It looks very clean and difficult to tell it was modified.
Cheers
Old 03-19-2015, 07:00 AM
denpmp denpmp is offline
Mein Auto: 325xi w
Originally Posted by Martin5333 View Post
FHODD
View My Garage
Regards
Well guys, thanks to our fellow from Netherlands up here with his post of last November ; I followed the instructions in order to shut the rear panel of the sunroof. Im forwarding the attachment once again. It was extremely useful for me.
Anyhow I would add to the procedure that you first need to be sure that the front panel of the sunroof is partially closed (always talking of the vent position) in order to be able to shut the rear panel. This needs to be performed manually with the allen tool.
Bottom line, in order to shut the rear panel, you first must partially close the front panel manually, secondly turn to the rear panel from the inside of the vehicle and push backwards the item 6 indicated in the file attached as much as you can ( both sides of the panel of course); follow this two steps again ( two or three sequences should be enough) until the rear and front panel are completely shut.
From there on just decide what would you like to do with the sunroof; pay top dollar to get it fixed if you ran out of a warranty, modify the system and block out the rear panel (It is a DIY task, as detailed in the attachment) or just keep your fingers off the push up button to engage the vent position!!!
Thanks FHODD and mlukas161
The PDF instructions provided an easy DIY fix to get the vent closed, thanks for posting. D
Old 03-21-2015, 03:22 AM
rick.gill rick.gill is offline
Mein Auto: X3
fixed mine with the repair tip, cut off the offending broken bit as per pdf. reset and works great- except rear roof stays fixed but who cares
Old 02-03-2017, 03:50 PM
firereigns firereigns is offline
Mein Auto: BMW X3 2004 2.5i
Hello everyone, new guy to the block, I have a problem, my 2004 BMW X3 2.5i Panoramic Sunroof has completely broken down. It would appear that all the little plastic lift and support mechanism have cracked or broken due to the extreme cold weather since I had the car. So now to save myself a $4,000 bill by taking it to the dealer, I would rather try and replace are the little parts myself. The only thing is, I don't know how to take the sunroof out of my car in order to replace the broken parts. The visor or shade still operates by opening and closing but the glass itself does not move at all. So how do I take out the inner shade and then the railing that the sunroof sits on so that I can replace everything. I have already purchased the replaceable parts, can some one send me instruction on how to do this from beginning to end. I have a lot of free time, retired Navy so I would like to have it ready by the summer of 2017. Can anyone offer a video that shows how to take out the interior paneling so that I can take out the entire sunroof cassette so that I can replace the broken parts.
Frustrated with BMW's
Old 02-03-2017, 03:58 PM
Mein Auto: X3
Please see the pdf in the previous post. It is a easy no cost fix which took me about an hour: 50 minutes to understand the instruction 10 minutes to do the job.
Old 02-03-2017, 04:04 PM
Removing interior roof
Thanks for the post but I am trying to repair the cassette that runs the sunroof and so I don't know how to get the interior roof down from inside my BMW so that I may unloosen screws and take the whole cassette out, after I have unloosen the screws from the exterior side. So how do I get the interior carpeting which is the interior roof, down so that I may take out the whole cassette. That's what I am trying to do.
Frustrated with BMW
Old 02-03-2017, 04:06 PM
Mein Auto: X3
OK got it. Can't help you with that one.
