Old 03-31-2010, 07:53 PM
jaytone jaytone is offline
Mein Auto: 330xi
Brown sludge in oil cap
Recently bought a very low mileage 528. Last oil change by the former owner was last July and only 2000 miles have been driven since.
I was cleaning the engine today and I removed the oil cap. There was brown sludge on the bottom of the cap and on the rim of the cover.
Any idea what is going on ?
Car just turned 49,000 miles.
Old 03-31-2010, 08:33 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
like this?
Old 03-31-2010, 09:11 PM
cn90 cn90 is offline
1+,
Mine looks like that at 100K.
Car runs fine.
Old 03-31-2010, 10:26 PM
ecool ecool is offline
Mein Auto: 92 325i, 00 528i
Mine looks like that too. Just changed the oil last week. Runs fine at 114,000.
Old 03-31-2010, 10:34 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Signs of a failing CCV
0.02
Old 03-31-2010, 10:48 PM
Quackers's Avatar
Quackers Quackers is offline
Learning all the time
Mein Auto: 540i
It's often caused by repeated short runs where the engine doesn't fully warm up and condensation in the rocker box isn't fully burnt off.
I maybe paranoid but that doesn't mean they're not after me!
Old 03-31-2010, 10:55 PM
Actually that pic is normal at 100K, not a cause for concern at all.
This is real sludge seen in this forum:
Old 04-01-2010, 05:11 AM
Fudman's Avatar
Fudman Fudman is online now
Now that is SLUDGE!!!
The brown stuff you see is indeed condensation from within the engine. The color ranges from brown to a thick yellow-white mayo-like sludge. It is present in virtually every e39 to varying degrees. It often means, but not always, a failing CCV. Replacing the CCV is a PITA and is a common component failure in e39s due to the poor design. The CCV is supposed to vent the crankcase (like a PCV) and allow this condensation to flow back into the sump but it gets clogged by an accumulation of this condensate. In colder weather, this condensate clings to the CCV pipes/tubes, as they do not warm sufficiently on short trips to flow back into the CCV. The BMW "fix" is insulated pipes/tubes, however, this is only a partial solution. Best to avoid short trips and allow the car to warm sufficiently.
Old 04-01-2010, 07:10 AM
Mein Auto: 330xi
Thanks to all for replying. It does look like the photo above but with some extra **** (sludge) that I cleaned off and now the cap is just brown (looks like rust). As Fudman mentioned above it did look like brown to a thick yellow-white mayo-like sludge.
The former owner only used the car to go on short trips, usually 5 miles a day, to the train station. He told me that in the entire time he had it (11 years) he took only 5 or 6 long trips and the rest was basically daily to the train station. He only changed the oil once a year too by BMW.
So, I guess I will have the oil changed and use it more often now that I own it.
Old 04-01-2010, 07:47 AM
Joe Mauer Joe Mauer is offline
Mein Auto: 1999 528i
I had an interesting thing happen with my wife's Ford F350 diesel. Because of the snow, we didn't run it at all during February. Once we got it back on the road, I drove it to town and back (less than 15 minutes total run time). After that trip, I happened to remove the oil filler cap and noticed a light-colored residue inside the cap, which I wiped off. After the next trip (also short), the residue had returned, but there was less of it than before. At that point, I changed the oil and took it on a long trip with a heavy trailer. Now the residue is gone.
I am not sure what that means for this thread, but I think it supports the condensation theory mentioned by the others here.
Seeing that residue on my wife's oil cap spooked me a little. Those Powerstroke motors are notorious for cylinder liner failures resulting from cavitation on the coolant side of the cylinders. It's a great truck, but I am always fearful of what I will see on the dipstick.
Solidjake's Avatar
Zero. Leaks.
Go out and redline the bish a few times
It's begging for it
Old 04-01-2010, 04:54 PM
JTuck JTuck is offline
RWD and so happy...
Mein Auto: 1998 540i
"Go out and redline the bish a few times
It's begging for it"
Exactly. Otherwise known as an Italian tune-up.
Old 04-01-2010, 05:22 PM
mic0ne23 mic0ne23 is offline
Send a message via AIM to mic0ne23 Send a message via Yahoo to mic0ne23
Mein Auto: 2000 bmw 528i
Originally Posted by Solidjake View Post
like this?
mine looks the same too
Old 12-28-2010, 10:45 AM
WOW.. how would you know if you have all that? just by removing the valve cover? or would there be a huge mess under the cap too?
Old 12-28-2010, 11:44 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Mine does not.
Old 12-28-2010, 03:13 PM
doru's Avatar
Also, accelerated oil changes will get rid of that stuff in time.
I had some deposits when I purchased the car - it was maintained by the BMW interval. It was under the oil filler cap and on the dipstick. Then I took things in my hands and the first 2 oil changes were at something around 3000 miles, after that between 5 and 7 thou miles to day. The mayo and brown stuff is gone. Also, I had the CCV freeze on me a year or so after I purchased the car. No problems since. I also took a flashlight and looked inside oil filler cap and it looks great -what I can see. When I did the Vanos, what I could see was looking great too.
Old 12-28-2010, 03:49 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport, Scuderia
Like the picture of the crud with the valve cover removed?! No way. The only way to clean that is a tear down. No amount of oil changes, solvents, or magic elixirs will clean that up...it has been tried here, and other forums....just doesn't happen when it is that bad.
540 M-Sport package (Canadian market), factory Bluetooth phone kit, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, H&R 15mm spacers, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 12-28-2010, 08:45 PM
doru's Avatar
I'm not talking about that fouled engine. I agree that nothing can remove that. When I purchased my car, it was still under BMW warranty, very low mileage, practically new. I was talking about my car which started to develop a mild sludge/mayo. The inception of the process if you will, not that graphic pic.
Old 12-29-2010, 12:00 PM
Hooray!'s Avatar
Hooray! Hooray! is offline
Mein Auto: 2002 530i Sport Premium
like this?
Mine looks like this as well (73,000 miles); I use RedLine 5W30 change every 5000 miles, did the VANOS with Fudman and inside the engine looks mint (zero deposits) so I'm wondering if the oil condensate simply goes to the highest point in the engine (the cap). After changing my oil last week, I warmed up the car and rechecked oil to top off last 1/2 quart and noticed already small beads of moisture on the cap (clear at this point)... could be my CCV, I suspect it has never been changed (FL car).
I drive 24 miles one way to work so car gets a chance to warm up by mid-point in the commute daily; using my daughter's VW Golf now as my winter car but miss my e39.
2002 530i
Exterior: Black
Interior: Black
Packages: Sport, Premium, Cold Weather
Options: HID, Folding Rear Seats, Ski-pass
Old 12-29-2010, 12:18 PM
golferjohnm's Avatar
golferjohnm golferjohnm is offline
Mein Auto: '01 540i 6sp '01 X5 4.4
Italian tune-up, now that's effin' funny
Old 02-02-2011, 01:00 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the record, there is apparently some brown sludge buildup in this 540i cylinder head removal thread ...
Old 02-02-2011, 02:22 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
my 525i is clean but 530i has a bit
cleaning Air Distribution piece looks like help
PITA
Old 02-02-2011, 02:25 PM
Abby2010 Abby2010 is offline
Mein Auto: 2002 525i Sport
Ccv
Fudman, is the CCV real difficult to replace? I'm thinking w/105,000 I should probably do this.
Old 02-02-2011, 03:27 PM
Fudman's Avatar
If you are not displaying any CCV symptoms (smokey exhaust, high oil consumption, etc.), I would recommend holding off because it is a PITA (my opinion). It also depends on your driving habits. The accumulation of the "mayo" is typically attributed to driving short distances in cold weather and not letting the engine heat up sufficiently to burn off the condensate. If you do a weekly highway run of 10-20 miles, that should help to minimize accumulation.
I don't recommend this job because I have average mechanical skills and found myself somewhat lucky that my car started back up afterwards. It took me about 8 hrs over two days. Read my DIY (it applies to your MY). Access to the CCV is tight. It is doable but I needed to apply some workarounds to simplify the installation. Read the entire thread as others have modified steps in my procedure with success. Good luck!
http://www.bimmerfest.com/forums/sho...240&highlight=
Old 02-02-2011, 04:12 PM
Thanks. I have zero smoke on start up and my oil cap looks about like the one in this thread so I think I will just not worry about it right now. Thanks for the info & link!
