Locating the 2002 525i fuel filter
I need someone who have experienced replacing the fuel filter for 2002 525i..to tell me where it's located.. can't find it by looking under the car. Thanks
It's there. It's on the driver's side under the car and under a plastic cover that will require you to remove about 4-5 screws. Take my advice on this one. Mark with a sharpie your in/out lines and don't get them crossed up.
good luck
- 2003 525I Sedan - Manual Tranny, M-tech Bumpers Front/Rear, shadowline, M5 Mirrors, 19" Miro 279's, NNR Coilovers, Front lip, 50% tint, Dinan ECU Stage II, Dinan CAI, Dinan Free Flow Exhaust, DICE Ipod, Connects2/Parrot Bluetooth, SSK Kit, AC Schnitzer Shift Knob, CDV Delete, - 2008 R350 Mercedes Wagon |
Under the chassis, your Left Butt area.
Remove the Plastic Cover, you will see it. Take note, diagram, take pic so you don't mess it up. |
Thanks for your help. I got a few suggestions of where the fuel filter is located, and this one is from pelicanparts.com..I just don't want to pull the back seat out trying to locate the fuel filter.
jared Fenton from pelicanparts.com I'm pretty sure that the fuel filter is located in the fuel tank, integrated with the fuel pump. You would need to remove the rear lower seat to access the covers \. |
M5Board has a good DIY at http://www.m5board.com/vbulletin/e39...placement.html
The filter is slightly different, but process should be essentially the same. |
http://www.bimmerfest.com/forums/sho...d.php?t=182047 <-Good resource. It's not dangerous; learn from his mistakes. Do it outside if you can.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
I just did mine, and took lots of pics. Here is my detailed write-up:
http://www.bimmerfest.com/forums/sho...t=#post6709199 Last edited by EconoBox; 03-18-2012 at 03:36 PM. |
And here also...http://www.bimmerfest.com/forums/sho...459&highlight=
MorrisRoad |
could the fuel filter be the reason why the car doesnt start .....
For the crosslinked record, this was posted today:
> E39 (1997 - 2003) > Fuel Filter DIY - Post-Mortem Examination and Observations Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
