Old 04-11-2010, 05:09 PM
davy_b davy_b is offline
Mein Auto: Bmw 645Ci
645ci induction ??????????????
anyone have an induction kit in their 645ci was thinking about gruppe m
http://www.gruppem.co.jp/matching/pr...?goods_id=1380
or can you recommend anything else ????
Old 04-11-2010, 05:37 PM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2017 540i
Dinan's High Airflow Intake is only $799 - http://www.dinancars.com/store/produ...cat=435&page=1
Nick / TopDownInFL (sans the "top down")
2017 540i - Carbon Black Metallic | M Package | Lots of bells and whistles
Previous Bimmers:
2012 650i Coupe
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 04-11-2010, 09:43 PM
JESMAL's Avatar
JESMAL JESMAL is offline
Makin Lotsa Noise
Mein Auto: ACS e64 650i SMG S.Black
Dinan's would be the most effective setup. Have done temperature tests and found that at idle, the Dinan setup had 25% less heat soak than the GruppeM. But GruppeM wins on looks and sound. Very aggressive induction note, if thats what you're after. Heat soak is a big issue where I live and I have the GruppeM, might not be as big a problem where you are. Performance-wise, both provided almost the same increase based on a comparison between two stock 650i engines running stock exhausts. Very very minimal difference.
