Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
I call alignment BS!
Long story short: car at the shop for a weeks worth of repairs: lower control arm replacement, 'knuckle joint', alignment, etc.
I test drive the car and it pulls a little to the right despite it being straight on before my wreck. I come back and tell them it pulls. First response was "Are you sure? It seemed straight to me." No sir, definitely it pulls to the right. Second response was "OH! Your car had some tire damage as well. We aligned the car to factory specs so it's not that. Since your tires had some problems then they're what's causing the car to pull to the right. We can't help that." I'm calling but before I make an issue of this, wanted to hear from some people who have more experience than I.
My YOKOHAMAS were BALD after only 7,000 miles of daily driving!!! |
Here is a quick way to prove him wrong. Move the pulling tire to the other side of the car, if the pull moves to that side, its the tire, if not...well, you know!
[quote=rumatt]Brashland, how did you crash? Were you watching your sig while driving?
QUOTE] |
i'm Brashland's friend who'll be helping him do the swap... i've got 3 questions that i'm hoping will make things easier...
1. where are good center jack points on the car? i'm not horribly familiar w/ BMW's so, please be merciful and detailed. 2. what sort of damage should i look for on the tires? i would think obvious would scream... are there any whispers i should watch for? 3. what torque should i hit the lugnuts to when i put the tires back on? thanks!
Philip 2001 Silverstone/Black
Well, actually, no. Will do this afternoon.
A: I have an E36 so I don't know the answer to this, but hopefully some one else can chime in and let you know. 2. what sort of damage should i look for on the tires? i would think obvious would scream... are there any whispers i should watch for? A: First, see if the pull changes, then you'll know its the tire. Feel over the tread for scalloping or irregular wear. 3. what torque should i hit the lugnuts to when i put the tires back on? A: 87lb/ft details here http://forum.e46fanatics.com/showthr...threadid=91281 |
![]() But seriously... check out this thread: http://www.bimmerfest.com/forums/sho...+jacking+point Or do a search for "center jacking point" and you'll find more info too.
'03 330Ci DHP '06 M3 SMG "du hast mich gefragt, und ich hab nichts gesagt" |
love the model... thanks... sorry, while a newb here, i'm just being lazy at this point... i figured you guys knew exactly where this stuff would be, and it would have taken me a while to find it... ![]() thanks for the assist!
yeah -- i think i found it...
:thinker: ![]() edit: it's up in the air now...
"This is a revolution, dammit! We're going to have to offend SOMEbody!" |
To make things more confusing, I decided to 'test' the tire so Saturday I switched my front tires. If a flat spot is causing my car to pull to the right, switching tires should make it pull to the other side, no?
Switched tires and.... not pulling to the right anymore, at least not to any great degree. So I'm not sure what to make of it. Maybe this is good enough until I get new tires, and the repair shop/insurance doese have a lifetime guarantee on the parts.
thoughts or comments? how sensitive are 3 series BMW's to tire wear?
It can be the tires, commonly refer to as 'RADIAL PULL'. I once had a car that did that. Both front tires were F up and I didn't know. I had the alignment done and it pulled to the right. I thought it was a bad alignment, took it back and they checked. They said it might be redial pull......bad tires......I didn't believe them so they swaped the left to the right side and it still pulled to the right. They kept on telling me it was bad tires but I just wouldn't believe it, so they swap the front the back and the problem was fixed. I did feel kind of stupid afterward..........
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
