E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Replacing the antenna grommet on my z3
I’m having problems removing the antenna grommet on my z3. Can someone please advise me on this procedure? I have a power top do I need to remove the motor to access the antenna? This the mast antenna not a powered one.
Thanks in advance. |
I just did this a few weeks ago. You will need to remove the trunk carpet on the driver side. You will also need to take the power top pump and antenna base loose. You can then lower the antenna base out of the grommet and remove the old grommet from the fender. The install is the reverse.
Couple nuts is all it takes to loosen, then lay aside the pump.
This work for me.
Remove the antenna. I found a long screw with the correct threads that I screw into the antenna base. Gently push the antenna down until free of old grommet. Remove old grommet. Insert new grommet. Hold new grommet down and gently pull the screw that was screwed into antenna base up. Antenna base will slip into the grommet. Remove screw and re-install antenna. Usual precautions need to be followed.
96 Z3 1.9 Black/tan/black 97 M3/4 Estoril/dove gray 08 3400HST Kubota Orange/gray 08 GMC Sierra CrewCab |
I've done this twice without removing anything but antenna
Unscrew antenna, grab needle nose pliers and pull the old grommet out (be careful not to scratch the paint, some tape around the area won't hurt). Get some soapy water or equivalent and push down hard on the new grommet, done.
_________________________________________________ 2000 2.3 Oxford Green / Black Top / Beige Interior Koni Sport Shocks, M front Shock mounts reversed, Sharked, Strong Strut, Oxford Green II hardtop |
I used this very method.. I didn't even have to open the trunk. Super easy.
2007 E92 ED/ 2011 MINI R60 S All4/ 1996 Z3 play car, loving all the projects! |
This is exactly what I did, although on the re-install I had to modify the antenna base a bit because the grommet was much taller than the original and the antenna screw wouldn't reach the socket.
Thank you all for posting. I will fix this tonight.
It worked like a charm. Thank you all!
After removing the antenna an the old cracked grommet, I placed a long flat screw to hold the antenna base. To soften the grommet I placed it in the microwave oven for 18 seconds, be careful it will be hot. Replace it back on the antenna base while holding the screw and the grommet slided very easily.
I just did this and had absolutely zero problems with unscrewing the mast, putting the new grommet on (soaped up) and pressing it in.
MUCH quicker than disassembling, but then again, my old grommet was so bad I was able to take it out in pieces. If it were in better shape I probably would have had to disassemble to get it out. |
Replacing the antenna grommet on my Z3
Any other suggestions for this issue? |
for those saying the grommet was taller, it's possible that the antenna base is not fully inserted all the way up into the grommet. You should get a distinct pop or feel it slide into a locked and fully inserted position. At first i thought the grommet was too tall then realized it was not fully seated.
98 Z3 5 spd island bomb 93 Mitsubishi Pajero 02 Mazda Demio 07 X3 Cold, Step, Sport (in storage) 08 HD Street Glide "Loud & Proud" (in storage) 69 Corvette, 350/350, 4 spd, no A/C, no power, factory side-pipes (in storage) |
Thanks for your help - I used the long screw method.
After removing old grommet, I first inserted a long screw into antenna base, then seated the new grommet to the fender and then pulled the antenna base up with the use of vise grips pulling up on the the screw until the antenna base seats into the bottom side of the grommet. Note: Make sure you correctly align the grommet before seating it to the fender. |
I have a '96 non power antenna, suggestions on where to purchase a new one?
All help appreciated. |
http://www.bavauto.com/
Among many, many, many other places.....
Crappy : ) (Just outside of Nashville) |
Did mine a few weeks ago, soap and water and about 10 minutes to complete.
| Bookmarks |
| Tags |
| antenna grommet, mast antenna |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
