Old 04-20-2010, 11:43 AM
MvertDoug's Avatar
MvertDoug MvertDoug is offline
Making fast faster
Mein Auto: 2006 z4M roadster
S54 engine "stumbles" when at idle
S54 engine "stumbles" when at idle. It only does this after about five minutes or so of running. It always happens at idle when stationary. I stopped at a car lot yesterday,left it running and it "dropped" a couple of times. Almost like it throttles down then back up. Radiator fan kicking on? Air con is off when this happens. Anyone else notice this with the car running in the driveway?
2008 BMW M COUPE- -DME TUNE-RPI RAM AIR-H&R SPORT SPRINGS-GRUPPE M INTAKE-EISENMANN RACE EXHAUST-TEKARBON ANGEL EYES PROJECT
Old 04-20-2010, 11:49 AM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
When was the last time you ran a bottle of techron through?
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 04-20-2010, 11:56 AM
MvertDoug's Avatar
Making fast faster
09/2010. Added to my weekend list of todo's.
Old 04-20-2010, 12:14 PM
aestheticstorm's Avatar
aestheticstorm aestheticstorm is offline
Rad Racer World Champion
Mein Auto: '08 Z4 M Coupé (S.Bronze)
This happens to me a few times a week, after the engine has been running at least 25 minutes (like when I'm stopped at a red light). Is this a problem or some normal "reset" procedure by the computer? FYI I always use Chevron Supreme 92 (which has a Techron additive).
'08 Z4 M Coupé Sepang Bronze, Black/Black, Madeira Wood, CDV delete // 49th from End of Production
Old 04-20-2010, 12:18 PM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
Are you from the future?!?!
DreamingWell.com Web Services
Old 04-20-2010, 12:21 PM
jragan's Avatar
Do you have the charcoal pre-filter in place?
Old 04-20-2010, 12:23 PM
What's a charcoal pre-filter? Mine's stock setup.
Old 04-20-2010, 12:26 PM
MvertDoug's Avatar
Making fast faster
oops!
Does everyone here have their chacoal filter removed? I'm debating taking it in to service because my warranty only has five days left.
Old 04-20-2010, 12:28 PM
MvertDoug's Avatar
Making fast faster
Beat me to it. Yes it's removed. Ive seen the TSB that talks about that. It's going back in too. So much for that extra 1/2 HP.
Old 04-20-2010, 12:33 PM
jragan's Avatar
If you open up your air box, you'll actually have two filters in there. One is a charcoal pre-filter and then there's your actual paper filter. It's a pretty popular "mod" to remove the charcoal pre-filter, however there's a BMW TSB out that lists its removal as a possible cause for engine operational issues (no one's really been able to confirm or deny this occurrence, however).
Old 04-20-2010, 12:57 PM
Dammmittt's Avatar
Dammmittt Dammmittt is offline
///M
Mein Auto: 07 M Coupe
Mine used to do that too...never took out the charcoal filter...hasn't happened in ages though....not sure what the reason is/was. Plenty has changed since the last time it happened,a couple years ago.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website in the History of the Internet!
Old 04-20-2010, 01:41 PM
MvertDoug's Avatar
Making fast faster
Weird. I just noticed mine doing it a couple of weeks ago. I've had the char filter out for about 8 months.
Old 04-20-2010, 02:18 PM
jragan's Avatar
Could it be the DME adjusting to the first warm days?
Old 04-20-2010, 02:21 PM
MvertDoug's Avatar
Making fast faster
This could be. Also I do the DME "reset" trick every time I get her out of the garage. So even that could be as the DME resets itself.
Old 04-20-2010, 05:21 PM
MvertDoug's Avatar
Making fast faster
Charcoal filter back in. Weather preventing me from taking it out tomorrow.
Old 04-20-2010, 05:33 PM
Obviously it's not the filter as I'm having the same symptoms with it in.
Old 04-20-2010, 05:37 PM
MvertDoug's Avatar
Making fast faster
Have you taking it in to be looked at? I'm thinking about it.
Old 04-20-2010, 06:26 PM
I very highly doubt you'll be able to reproduce it to check anything out. I'm not losing sleep over it.
Might be a Sepang Bronze isolated problem
Old 04-21-2010, 06:24 AM
MvertDoug's Avatar
Making fast faster
That damn Sepang! My only issue with it is that it is causing me to stall out occasionally when I start off after idling for a bit. It's like I have to clean it out before i start or it just jumps and dies. I know I havent forgot how to drive it. Hopefully like I said just a fuel issue.
Old 04-21-2010, 06:39 AM
Zuzax's Avatar
Zuzax Zuzax is offline
Calvinball Professional
Mein Auto: '07 M Roadster
Could it be your Powerchip tune mucking things up?
Not a believer in the Sepang theory. I too have a Sepang (mightiest of the colors) and have not had the issue.
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock.
Old 04-21-2010, 07:14 AM
MvertDoug's Avatar
Making fast faster
If I'm still having problems down the road I'm going to PChip do a reflash. They are supposed to be coming out with a brand new program for the s54 in July.
Old 04-21-2010, 07:47 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Italian tune-up might be what she needs.
Have you got ahold of the techron concentrate yet? Is it a myth that the oil must be changed after using the concentrate?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 04-21-2010, 08:00 AM
MvertDoug's Avatar
Making fast faster
Do the Italian tune-up everyday I can. Found a good isolated straightaway last Sunday. 155 with the top down feels so good. Ive never changed the oil after techron since it goes in the gas. I need to check on that.
Old 04-21-2010, 10:49 AM
Erhan Erhan is offline
Mein Auto: 2007 MC
haha no it is not I have the same issue. I had the car serviced. The AC belt was broken so the dealer though that was the reason (which made sense). But than it happened a week after the service too. Right now I don't have a clue about the reason
Old 04-21-2010, 11:27 AM
Proph Proph is offline
Mein Auto: 05 Z4 3.0i, 07 F430
How often are you guys seeing this happen? On my M54 engine, it's happened twice in the 1+ year that I've own the car. I'm not too worried.
