Old 12-16-2011, 02:59 PM
morrisroad's Avatar
morrisroad morrisroad is offline
Mein Auto: BMW 530
Here's the latest. I received the replacement injector and much to my chagrin, after installing it the injector leaked! So, after replacing the upper o-ring thinking it might be the source of the problem, and various other troubleshooting, I ended up putting the old injector back on. I captured the troubleshooting here on this link http://www.bimmerfest.com/forums/sho...067&highlight=. Instead of spending another week waiting an messing around with a GB remanufactured injector, I ordered a new VDO one. Replaced it, without any issues. Now, I'll have to report back to see if there is any changes when it gets below 0.
MorrisRoad
Old 12-16-2011, 03:43 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
i will be surprised if injectors can resolve cold start up issue
Old 12-16-2011, 07:06 PM
kgorczyn kgorczyn is offline
Mein Auto: 2000 528i SP/PP
Thanks for your updates. I'm closely watching your thread
Old 12-17-2011, 08:44 AM
morrisroad's Avatar
Mein Auto: BMW 530
Updated Recap of what has been done to solve, but still have miss:
New Plugs
New Intake boots upper and lower
New air filter
New DISA
New emission control air pump and valve
New Bosch Coils
New Fuel filter
New CCV
New valve cover gasket
New Injectors
VANOS - Beisian Procedure to replace rings
Checked for vacuum leaks, including behind intake and caps
Cleaned the MAF, did the unplug test and used MAF Cleaner
Cleaned the ICV
Cleaned the the throttle body
Checked for codes- none
Now some of the above in italics, I did b/c the broke or needed to be changed. There were some very noticeable acceleration improvements when I changed the fuel filter and injectors. DISA also improved this as well. I can't say I noticed much after doing the VANOS other than the RPMS stay a bit higher when started.
MorrisRoad
Old 12-19-2011, 10:13 PM
so where you are with a cold start up issue and a new injectors ?
Old 12-20-2011, 11:00 AM
See my thread and see if you have the same/similar things as me....
http://www.bimmerfest.com/forums/sho....php?p=6512696
Old 12-20-2011, 11:08 AM
morrisroad
Old 12-20-2011, 11:10 AM
He installed new injectors, but it did not fix the problem.
Old 12-20-2011, 11:11 AM
i was sure about it
see #77
Old 12-20-2011, 04:39 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Does the car run OK after warming up? If so I'm starting to think it might be a temp sensor for the engine computor. The only way that would show up would be through a scan from the dealer--a stat might cause the same problem maybe. Still noodling
Old 12-20-2011, 06:43 PM
morrisroad's Avatar
Mein Auto: BMW 530
Runs fine when warm.
MorrisRoad
Old 12-21-2011, 05:45 AM
IQBMW IQBMW is offline
Mein Auto: 520i
I have 2002 520i done 79K. Last night the battery went flat and got it replaced with new one. Early morning, the car started with vibrations at low RPM (~700) and after racing at 2000 rpm, i thought things will be smooth but, the engine was put off. I waited couple of mins and restarted the engine but vibrations at low rpm persists. AT high there is no vobrations but Iam scared to release the pedal as it may switch off again. I am getting no warning or fault indication while running. The weather is moist and cold (17C).
What could be the issue for engine to switch off and low rpm vibrations.
Old 12-21-2011, 07:54 AM
looks like a misfire and not a cold start issue
Old 12-21-2011, 08:57 AM
Mein Auto: 520i
But mostly after 2 to 3 ingnition the rpm stabilise and vibrations stops. But this time RPM kept swinging bewteen 0 to 700 and no damping in vibration. What are the possible solutions.
Old 01-10-2012, 01:47 PM
morrisroad's Avatar
Mein Auto: BMW 530
I documented this on another thread, but 3 of the GB remanufactured injectors I received developed leaks. I replaced them with new VDO ones, but it has been relatively mild to access the situation in cold weather. Once it is around -10C, I will be sure to report.
MorrisRoad
Old 01-10-2012, 10:01 PM
jorjio_k jorjio_k is offline
Mein Auto: BMW 528 99
did u check the manifold itself for cracks?did u replace the manifold gaskets?
Broken Angel
Old 01-14-2012, 06:33 AM
morrisroad's Avatar
Mein Auto: BMW 530
Today it was -18 C and so here is what I can report. But before I do, I need to lay out a scale to describe what cold rough idle means as I describe it. Let's say we have a scale 1-10 where 1 is a really bad, violent shaking, sputters or stalls and 10 means it runs without any misses slight or otherwise. In all the cases cold would be lower than -5C. When I first reported this problem, I would peg the rough idle was a 4 when it was cold and in one occasion a 2.
When I started it today at -18C I would peg it at a 9. The car started fine, idle slowly came down as it warmed up. On first start there was a very slight miss enough that could notice, this presence is less apparent as it warmed up. I would say that the last three things (DISA, filter, injectors) I did made the biggest difference with the most ancillary benefits (e.g. acceleration, car runs smoother). Note that I changed out the last leaky injector recently that came with the batch of rebuilds I purchased.
Given that I have done as much as I can do, my next step is to take it to the dealership and see if they can scope it out with more advanced tools.
I've checked the manifold, and don't believe its the manifold gasket.
MorrisRoad
Old 01-14-2012, 10:18 AM
is it loosing coolant?if it is,there is a possibility that it is going into the cylinder thus giving the rough idle when first started?
How did you check the manifold?did u take it out?why you don't think it is the manifold gaskets?
Broken Angel
Old 01-23-2012, 09:33 AM
morrisroad's Avatar
Mein Auto: BMW 530
No coolant is being lost.
MorrisRoad
Old 01-30-2012, 02:31 PM
NoBull NoBull is offline
Mein Auto: 08 335 Vert
Wouldn't this produce rough idle in ANY weather and not just cold weather?
I'm losing a little coolant and also have a very slight rough idle but only around 35F or lower temps.
Old 01-30-2012, 03:07 PM
morrisroad's Avatar
Mein Auto: BMW 530
The issues is not with warm idle - that's just fine. There are no coolant leaks. The issue, slight miss, presents when the weather is cold, at > -5C.
MorrisRoad
Old 01-31-2012, 07:22 AM
morrisroad, that's my point. If coolant is leaking into the engine leaning the mixture I would think that would produce rough idle regardless of whether it's cold or not outside. Lean is lean. But maybe not?
Old 01-31-2012, 08:50 AM
UsedBits UsedBits is offline
BMW CCA Member #: 444067
Mein Auto: 2002 540iA with sport pkg
When warm and running (idling) smoothly, can you detect a misfire on *hard* acceleration? Not just from standing start, but also from, say, 40 to 90?
Unfortunately, I have no solution. My car (e39 540i) also has rough cold idle (codes indicate cylinders 1, 4, and 5) when cold, better when warm. But on two occasions, under hard acceleration, a detectable miss occurred right when the SES light began to flash.
2002 e39 (540iA) with factory 'sport package' modified with:
'03 fr. and r. bumpers, front air ducts, and spoiler
18" Staggered MPars (style 37)
Dinan exhaust
shorter springs
European center console arm rest
VECTOR radar detector (non-working)
.|(oOO)\(lll)(lll)/(OOo)|
. \o\0=======|=======0/o/
...|__|.............|__|
Old 02-01-2012, 10:21 AM
morrisroad's Avatar
Mein Auto: BMW 530
With all of the changes (vanos, fuel filter, coils...) it runs very well when warm. The acceleration is without a miss.
As far a lean goes, coolant in engine, wouldn't we expect a drop in coolant levels if that was the case? I don't see this.
MorrisRoad
Old 02-03-2012, 03:25 AM
reestovee reestovee is offline
Bitsy
Mein Auto: 525ia
When was the last time you changed the spark plugs? Worked to fix my problem.
idle, intake gasket, maf, rough, vanos
