Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 11-04-2003, 10:10 AM
Jimmy325 Jimmy325 is offline
Away
Send a message via AIM to Jimmy325
Mein auto: is slow but comfy
Gary, suggestions for track setup for E46 M3 coupe
I know the recommended setup is SSR Comps 18x9.5 et35 with 265/40/18 all the way around.
However, that setup is $$$.
Is there any other setup that you can recommend that will allow me to run wide tires and have a square non-stagger setup for the track?
Jimmy
Old 11-04-2003, 11:28 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein auto: M3 & 323i/999 KP
OZ Superleggeras would be a less expensive replacement for the SSR comps. Plus, they're stronger.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
1995 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1989 325is S50
Alpinweiß/Black
1988 M3
Alpinweiß/Black Basket Case
Old 11-04-2003, 11:38 AM
Away
Originally Posted by The HACK
How often do you track, and how much experience do you have?
I would suggest if you're going to plunk down that much $$$, to go with R comps. 265 seems too wide for the front, but what the heck do I know.
The way I see it, unless you're ready to move past the stock setup and move to R-comps, there's no need for a seperate set of track and street tires/rims.
And also keep in mind, on the track brakes work in tandem with the tires, so you should upgrade the brakes as well along with the rims/tires, and also if you're going to use R-comps make sure you sure up all your suspension parts as well.
Wazzup Hack,
You raise excellent points. I am a track junkie wannabe who's still learning and will do around 6 events for 2004. The reasons I'm trying to find a separate set of track use tires/wheels is...
1. Keep burning 19's on my M3 is not going to be economical.
2. The E46 is such a piggy that I'd like to find ways to dial out some understeer.
3. I'm reaching adhesion limits on street tires.
I'm not ready for coilovers, bbk, and r compounds, and would suffice with more aggressive pads, alignment, and wheels/tires to use at track so I save on my street tires, 19's.
Oh yeah, also, 265 fronts have been used by many for the E46 M3 with great success, that's why I mentioned it. But then, what do I know as well? Might be too wide for me for now.
Jimmy
Old 11-04-2003, 11:39 AM
Away
Okay, let me check the available widths.
Old 11-04-2003, 12:15 PM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein auto: 1995 BMW M3
Everything else I know of would be staggered.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Old 11-04-2003, 12:23 PM
Away
So I guess the SSR Comps are the ONLY non staggered solution then.
Thanks Gary.
Old 11-04-2003, 12:43 PM
Away
You're reaching adhesion limits on street tires because you're not being smooth. That's probably why you're wearing through tires so quickly as well. The more experience you have the better you will be at being smooth thus conserving your tires AND go quicker without exceeding the limit of grip.
I'm talking about this like I am experienced...I'm not. I've only had 5 schools so far and I can tell you, I went through a lot more tire and rubber on my first 2 schools than I did with my last three. What I thought was tire limit turns out to be my own driving skill's limit.
One quick and cheap way to dial out understeer is actually with swaybars. Put on adjustible sways and tighten the rear and loosen the front will do, and it's cheaper than upgrading all around in rims. Also, you CAN go 245 front and 255 rear and that'll aso go a long way in dialing out understeer I believe.
Finally, I would still run at least one school in stock form before I make any changes. The biggest regret that I have is still spending all that time and $$$ on mods, only to find out that I can't even out-drive my car in stock form.
But don't let me stop you from getting those rims and tires...I think they'll go a long way and will be big improvements.
Yeah, I've noticed the same too. Smoothness equals a bit less rubbing of the rubber. Most of it is due to lack of proper camber for the track though. However, I find myself hindered by the lack of grip on the 225 front tires. I'm doing quick enough in my own group, passing slower cars left and right, yet another M3 was pulling on me, he's got r compounds, sways, coilovers, harness etc.
I'm not about to make the jump now, going to do another event on street tires and then get track wheels with street tires so I can conserve the 19's.
It just kills me to see my 19" tires go so fast.
Old 02-25-2007, 04:13 PM
speedminded speedminded is offline
Send a message via AIM to speedminded
Mein auto: ...
Team Dynamics Pro Race 1.2 is available in 18 x 9's. Not quite 9.5" but definitely alot cheaper than the wheels mentioned so far.
Old 02-25-2007, 04:37 PM
Also, Enkei has some great options now too.
1989 325is S50
Alpinweiß/Black
1988 M3
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
