E36 (1991 - 1999)
Old 04-24-2010, 02:15 PM
HeavyHustla HeavyHustla is offline
Heavy Hustla
Mein Auto: 1993 325IS
Exclamation i have dash issues please help!
hi everyone i just drove home from class yesterday and turned off my car and realized i needed to go back out so when i get back into my car it was making the loud sound like i left on my lights but in a different rhythm. when i started up my car everything was fine but the measuring things on the dash stopped working.. so now i cant tell how fast im driving what RPM im at how much gas i have. also the digital millage reader is off. also i realized my cruis control dosent work and pretty much all the on board computer stuff doesn't work. i feel that this could just be a fuse that has blown but i have no idea were this fuse would be. by the way i have a 93 325is 2 door coupe with a 5 speed
Thanks guys id really appropriate anything i can get.
Old 04-24-2010, 09:15 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Try to reset the cluster
1. With the key in the off position, push the trip reset button in the cluster
2. Turn the ket to on position, but don't start the car
3. Release the button, the cluster will read out some numbers where your odometer is, then will sweep through the function of all the gauges
If this doesn't work, try to remove the cluster and make sure all the connections are secure behind, there are three. You don't need to remove the steering wheel if it is pointed straight. Just remove the two screws in the top of the cluster and slide it forward. Reach behind to release and attach the connections, there are some slide clasps that hold the plugs in.
Good luck
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 04-25-2010, 09:14 PM
Heavy Hustla
ya i tried to do that and it wont work because the gauges arnt even taking power i think im just goin to have to get another one
Old 04-25-2010, 09:15 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
the fuses are under the hood
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 04-25-2010, 09:39 PM
Heavy Hustla
ya i checked that much at least lol thanks tho
Old 04-26-2010, 09:02 AM
crisscross's Avatar
If it doesn't even sweep or light up and you have checked the plugs, then you have a broken solder in side more than likely and it will need to be replaced.
-Alan
-2000 F250 V10
Old 04-26-2010, 07:20 PM
Heavy Hustla
ya thats what i figured thanks for the help guys
bad, dash, issues, parts, working
