reverse lights - Bimmerfest - BMW Forums
Old 04-26-2010, 09:37 AM
fedup fedup is offline
Mein Auto: 2000 bmw 528i
Wink reverse lights
my reverse lights stopped working i replaced the revese light switch and they still dont work. somebody please help
Old 04-26-2010, 10:08 AM
could it be a fuse or relay?
Old 04-26-2010, 11:03 AM
cn90 cn90 is offline
Check:
- bulbs
- fuses
- wiring
Old 04-26-2010, 11:21 AM
i changed the bulbs and the wiring looks good and none of the fuses say back up lights...
Old 04-26-2010, 12:12 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
All external lights are controlled by the LKM, located behind the right kick panel. There are no individual fuses.
Old 04-26-2010, 12:59 PM
above the battery? what kick panel and if all the lights r controlled by lkn then would u have to replace it because one set of lights don't work?
Old 04-26-2010, 01:11 PM
Did you check the sockets themselves to be sure there is no corrosion?
Old 04-26-2010, 01:25 PM
yeah nice and clean. i'm wondering if it's the connection to the clutch?
Old 04-26-2010, 01:49 PM
No, in the clutch pedal, there are 2 switches:
1. One for cruise control.
2. One for starter motor.
The REVERSE switch is mounted in the Man Transmission, which you mentioned you already replaced it.
Old 04-26-2010, 03:39 PM
five.two.five five.two.five is offline
Mein Auto: 2002 525I
Did you measure the voltage on the Blue/Yellow wire near the tail lights while the gear selector is in reverse and ignition on? This wire should read at least +12 volts on a digital multimeter and 0 volts while in any other gear. If the meter displays at least 12 volts, then you need to double check the bulbs and sockets for a poor connection and/or bad socket. If the meter displays 0 volts, then you should double check the reverse switch you had replaced, it might be defective and/or the connector is not properly seated into the socket.
Here is another thread that might help you troubleshoot your problem.
http://www.m5board.com/vbulletin/e39...-car-gear.html
Old 04-26-2010, 04:01 PM
Unhappy reverse lights
i don't have access to to check the voltage. is there a relay or something; anything?
Old 04-26-2010, 04:40 PM
i recently had the clutch replaced, maybe they forgot to hook something up?
