Five Speed Reverse Gear - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-26-2010, 01:52 PM
Tigon Tigon is offline
Mein Auto: '94 525i
Does anyone here know if a 328's manual transmission should require additional force (an aggressive tapping or smacking instead of gently gliding to the left) to shift into reverse.
I'm looking at a used 1997 328is with a manual transmission that seems to only have that one issue.
I brought a relative of mine with who ran it through all of its gears and said everything else checked out.
I thought I should play it safe and find out if that is standard operation.
Old 04-26-2010, 02:00 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
It takes some force to get it into reverse, but you shouldn't need to smack it.
Turbo Build Here
Old 04-26-2010, 02:05 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
You shouldn't need to smack your stick...just push it hard...
Instagram | @randytheus
Old 04-26-2010, 02:09 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
The trick is to put the trans into any forward gear *before* engaging reverse....if that doesn`t help, then the reverse idler gear is probably very worn.
The road goes ever onward....
(R.I.P. Jever)
Old 04-26-2010, 02:41 PM
JC540I's Avatar
JC540I JC540I is offline
Mein Auto: 95' 540ia-orient Blue
+1 If i don't end up doing as bob has stated it sounds like all my gears are grinding! horrrible, Unless it is warm and i have been running it most the day. Need a bit of force but shouldn't need to put your shoulders into it ;P
"Straight roads are for fast cars, turns are for fast drivers." -Colin McRae
Owned/own:
1995 M3-cosmos black(E36)
1998 528I-schwartz black(E39)
1999 328IS-steel blue(E36)
1995 540IA-orient blue(E34) 5/6 speed swap soon.
328, manual, transmission
