Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 04-26-2010, 01:57 PM
athletic01 athletic01 is offline
Mein Auto: BMW Z4 3.0 05
Z4 3.0 oil change price ?
What is the normal price for one oil change for a BMW Z4 3.0i approx ?
And how much does the BMW dealer charge normally ?
Thanks for the info.
Old 04-26-2010, 04:40 PM
jacapuano jacapuano is offline
Mein Auto: 2004 Z4 2.5i
I have a 2004 Z4 2.5I which takes seven quarts of oil. A local dealer here in Connecticut charges $119.95, but I had one done at an independent shop and the charge was about $80....and he used "genuine" BMW synthetic oil to boot. I think the charge for the 3.0 model should be about the same.
Hope this helps
2004 Alpine White 2.5i, beige top,5 speed,xenons, heated seats,chrome exhaust tips, OEM steel pedal pads.
Old 04-26-2010, 07:02 PM
scottyD's Avatar
scottyD scottyD is offline
Mein Auto: Z4 3.0si Coupe
7 quarts of BMW oil and filter kit runs about $60 if you do it yourself
Old 04-26-2010, 07:05 PM
Mario Free Mario Free is offline
Mein Auto: Z4 3.0i Sport
Dealership may charge up to $185 for an oil change including filter replacement. You can do it yourself for less than $70.
Old 04-26-2010, 09:58 PM
Psygnosis Psygnosis is offline
Mein Auto: 2004 Z4 3.0i Sport
I went to Seattle BMW because I had a hard time finding an independent, it was about $100
Old 04-28-2010, 11:08 AM
seth1993's Avatar
seth1993 seth1993 is offline
Mein Auto: BMW Z3
Dealerships are ridiculous I took mine up to get it done and they said it would be $120 (in Greenville, SC), plus extra to disassemble my aftermarket supercharger. I finally settled on a mechanic shop for about $75-$80 with synthetic mobile one oil and filter. Yeah it does look alot better on record if you took it to the dealer, but my opinion if you're looking to save money just find a good mechanic (who works commonly with foreign vehicles) who knows what he's doing.
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
Supercharged
Old 04-28-2010, 11:48 AM
Orcrone Orcrone is offline
Mein Auto: 2011 Z4 sDrive 35i
I get e-mail coupons from the two local dealerships. Currently one is having an $89.95 special and the other a $69.95 special. Car is still under the 4 year maintenance program so I don't know their regular prices.
Old 04-28-2010, 05:55 PM
Jermy1304 Jermy1304 is offline
Mein Auto: 2003 BMW Z4 3.0i
Let me help you with a DIY. The Oil Filter Housing is removed with a 36mm(yes, that big) Socket which I mount a 1/2 inch drive Ratchet, The Oil Plug is 17mm which i mount on a 3/8 inch Ratchet, There is a Gasket on the Oil Plug(Don't lose it when the oil poors out), It takes 7.2 Quarts when replacing the Oil Filter. At Wal-Mart, 5w-30 Castrol Full Synethic Oil is $25 per 5 quarts. Buy three of those for $75 and you have enough for two full oil changes. The Oil Filter should be roughly $12....So about $50 per Oil Change. Not bad at all for a 6,000 mile oil change!
***You will also NEED a Low-Profile Jack and Two Jack Stands.
Old 04-29-2010, 03:50 PM
captaineddie captaineddie is offline
Mein Auto: 2006 Z4 3.0si
Jack Points?
Is there a diagram somewhere that show the exact jack points on the Z4?
Old 04-29-2010, 05:16 PM
Ron Stygar's Avatar
19,585 Miles
It's in the Z4 FAQ.
Old 04-30-2010, 10:00 PM
Right behind the driver and passenger side wheels(in the direction the trunk). It should be a black rubber square lower than the rest of the under side of your car. you can't miss it.
Old 05-01-2010, 04:37 PM
OK. Thanks.
Old 05-02-2010, 03:36 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Even easier, get a MityVac oil extractor. Cheaper and easier than jacking and crawling under.
Warm engine, shut down, pull dipstick, stick oil extractor tube in dip stick hole and pump to start uscking. Remove oil filter cap and remove oil filter and disgard. Insert new oil filter, replace the O-ring on the cap and the small one at the end of the oil filter bolt, also washer. All come in the oil filter package.
Once oil is out, put fresh oil in.. Install dipstik, start and run until oil pressur elight goes out. Check oil level to make sure you put the right amount in.
You an buy the filters and oil at the BMW dealer. For anything but the S54 engine you can use any waultiy synthetic oil that meets BMW standards. I use Mobil 1 0W-40 in my LTW. BMW oil in the Roadster (S-52). If you join BMWCCA most dealers give a good discount on parts (including oil).
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-04-2010, 04:46 PM
Question MityVac
My Z4 doesn't have a dipstick. I don't suppose there's another way to drain the oil without crawling underneath??
Old 05-04-2010, 05:08 PM
Your Z4 certainly DOES have a dipstick. Pop the hood, look at the engine, go to the right side of it and pull your hand towards you until you stumble upon a red loop. Pull on it and say, "Hey look a dip stick!"
Old 05-04-2010, 08:38 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
The N52 engined Z4s from 2006 onwards don't have dipsticks, just the electronic oil level on the dash display.
Old 05-04-2010, 09:30 PM
My mistake, I lost track of who was posting. I thought this was the original owner of this thread.
Old 05-04-2010, 10:34 PM
Proph Proph is offline
Mein Auto: 05 Z4 3.0i, 07 F430
Sorry. You have to do it the old fashioned way.
Old 10-25-2016, 07:00 AM
KenniD KenniD is offline
Mein Auto: 2008 Z4
No oil dipstick on '08 Z4 3.0 Si
I don't understand why BMW would not have a back up manual oil level measure system. But it is what it is so I am wondering if anyone knows whether or not a retro fit is possible to install one on the engines that are missing it, i.e. is the hole still there but simply plugged?
Old 10-25-2016, 08:11 AM
AGammon AGammon is offline
Mein Auto: Z4 sDrive 3.5i
Oil change charge
I have just been quoted £280.00 today for an oil & filter change by my local BMW main dealer!
Old 10-25-2016, 04:00 PM
robertd33 robertd33 is offline
Mein Auto: 2013 35is
because they don't want you working on it. if you mess it up, it's then an "unreliable BMW". the same reason all of their repairs go WAY overboard... to make sure it's fixed. on your dime.
dealership wants $220 for my 2013 35is oil change.
Old 12-18-2016, 03:55 PM
Herkypilot Herkypilot is offline
Mein Auto: 2012 BMW Z4 35i
The Indy I used charged $180 for both oil/filter change & rear diff oil R/R. Still a bit high for me as I can certainly do both my self, just don't have time.
HP
HTML code is Off
