X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
#251
Two fer two on stickies. And a Full Assist on the Tranny!
Funny five years ago when I proposed changing out the sound system on the X3 I actually got the equivalent of hate mail via pm and called just about every name in the book. Now its a sticky for helping others. Very Cool. There are some excellent contributors here to...Thanks guys for making this what it is meant to be: Helping BMW owners overcome obstacles to a better vehicle
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
#252
I managed to source a new pair of Morel Dotech Ovation Crossovers (to suit Morel's 4", 5" & 6" Splits) - to replace my budged Focal Polyglass Crossovers.
The Focal Crossovers had always made my Hertz components sound VERY mid range focussed & it sounded like a loud clock radio with some vocals... These new Morel's have totally transformed how these speakers reproduce their frequencies & I can't stop giggling with how good it sounds! ![]() If anyone wants a slightly more complicated speaker upgrade, then a pair of Hertz EM100 midranges, ET20 Tweeters and some suitable quality crossovers will give you a fantastic 'European' sound! With a little more tweaking of my Alpine Head Unit's EQ, I reckon I'll try entering in my local Sound Quality (SQ) car audio competitions - to see how she fares! ![]()
#253
*face-palm* Yeah... That would make sense, wouldn't it?
#254
weird thing is that the colors from spaghetti coders are german abbreviated
#255
Ok here is the diagram I used for my speaker install in my 2007, with std 8 speaker sound:
http://wds.spaghetticoder.org/en/svg...30.svg?m=e8385 RADRV is not the color code for wiring. On the front right for example, BL/RT is Positive and BL/BR is Negative. BMW abbreviates the wiring colors in German as follows: BL = Blue BR = Brown GE = Yellow GN = Green GR = Grey RT = Red SW = Black WS = White VI = Violet Hope that helps. |
#256
But the question isn't necessarily what are the colors, but which speaker location is which?
#257
Evlengr, Ive been following your posts and appreciate your insight. quick question will these work with an 06 x3?
http://www.sonicelectronix.com/item_...TS-G1044R.html
The wiring diagram tells you. Front left, front right, etc.
#259
As a caveat though, i can take ten people with the same speakers and same source material and almost all will say something different. Do you need a walkthrough on the installation?
#260
So you are going to be close with those. Make sure you can return them if they don't fit. Last edited by PSUEng; 04-23-2012 at 04:24 AM. |
#261
Im on a pretty tight budget but i love music and been wanting to upgrade my sound system for a while. My first question is that, if i throw in about $400 into a new HU, speakers, and a sub, will there really be THAT much of an improvement? i know its sort of an opinion question but i just want to now if its really worth it if i dont have the coin.
Who says BMW's are for the street? |
#262
Start with changing the speakers. It is akin to changing tires. It wont seem that much a difference at first, but you will notice it. then go to a sound processor and amp. I think I have a spare amp you can have. I am moving to a new house (finally)and cleaning out the cupboard again so to speak. PM me as I tend to be absent minded. Audio Control puts out a neat little line processor that looks very versatile and not too costly: http://www.sonicelectronix.com/item_...6.html?from=20 $150.00 Marry that with speakers: http://www.sonicelectronix.com/item_...e-SPS-410.html $50.00 a pair And you are still left with $200 for a nice Sub and Amp. Yes it can be done for $400. I would stretch it to $500 for a better Amp as more clean power will give you less problems as heat and distortion kills a sound system. Let me know what you think. I am in the middle of moving so a lot going on. If you can wait I will diagram it out for you. If not I can still help with the gear and a possible amp. i just have to remember where I put it .Cheers, EE ps thanks PSUEng for kibbits. I'd rather someone get the right info, then be right. Let's all put our collabarative exp together and get NFX a good, better, best suggestion on his sound system and budget.
#263
At the end of the day, the stock speakers are the weakest point of the sound system. Upgrade those to just about anything and you'll be better off.
#264
Thanks.
I've been reading this thread for a while, and finally pulled the trigger on 2 pairs of Apline 410 at the sonicelectronix and the Audio LC6i from Crutchfield last night. When you have a chance, can you please provide the guide of how to tap to the speaker wire to the Audio LC6i? For anyone out there who wants to buy the Audio LC6i, this is the perfect time to do it because Crutchfield has it onsale right now for $119, use the coupon code 3A825 for $20 of $100. |
#265
I have a pretty good low end now and the door speaker change made a large difference, all for 400. and looks totally stock. My two cents..
Silverstar upgraded headlights Velocity motoring vb3 19" 9.5 wheels Yokahama S drive tires Upgraded stereo system Dice Mediabridge |
#266
#267
It seems clear that replacing the door speakers will result in a substantial improvement in the X3 sound system. Has anyone also replaced the under-seat woofers with the Earthquake SWS-8Xi 2 ohm units, retaining the stock amp? Earthquake makes the 2 ohm units as a direct replacement - I'm wondering how much a difference they would make by themselves. Thanks, Robert.
#268
http://www.bimmerfest.com/forums/sho...ghlight=sws+8x
#269
X3 3.0d 2006 (MY07) |
#270
Correct. Business cd in Aus is dumbed down. No amps separate to hu.
Update. Can work it out here http://wds.spaghetticoder.org/en/e8385/Complete_vehicle/body/Audio,_video_and_navigation/Sound_output/
X3 3.0d 2006 (MY07) Last edited by x3oiler; 05-05-2012 at 11:25 PM. |
#272
Hi folks, after much delibration I have decided to keep my 2005 X3 as my year around vehicle. As a result I am want to do some mods and with the limitations ( I use that word lightly..) the stock stereo needs to go. The instructions in this post are EXCELLENT , especially from Evlengr! How about some pics of the HU?? There are pics of everything else!
Thx! Marven
![]() 2011 E90 335xi coming soon
#273
Thanks for the kind words. I have to find some time to do the wiring layout and want to show how to construct a harness for plug and play set ups.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more Last edited by Evlengr; 05-08-2012 at 07:08 PM. |
#274
Evlengr, for the speaker install.... how badly do you have to knock on the airbag to damage it? I'm one of the clumsiest guys in the world and I'm freaking out about ruining the airbag in any way. also i don't want the airbag to deploy with my face at point blank
#275
Not That hard--Really
I did not disconnect the wire for the air bag when I pulled the door panel off. Just make sure you have "Torx" screw-drivers (or bits), a nylon type pry bar (start on the bottom inside portion of the wood overlay). There are more directions in this thread but they are most important. (And don't pierce /tear the vapor barrier).
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more Last edited by Evlengr; 05-14-2012 at 08:58 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
