Motorsports, Racing & Track
From Formula One to Auto-X, discuss everything related to going fast here... |
#51
If the driver mis-matched revs bad enough to cause a spin, you'd see the rears lock up. |
#52
Not much to add that you guys haven't already said, except I also think he turned in too late.
That, combined with the braking mistakes you've cited = spin.
If you're in control, you're not driving fast enough -- Parnelli Jones |
#56
Next.....
"Now go get your own car, we'll see how you do in a crowd." |
#57
I can't tell if he turned in too late, but what is apparent is that he didn't preload the suspension for the turn-in. It appears that he's snapping the wheel over and there just isn't enough preloading on the suspension for the turn. |
#58
I hate seeing clips like this one. I have my theory as to what happened but I want to read what people post first though. Viper crash at PIR (1.8mb) |
#59
ugh what a crash. This one has me stumped. Pretty rare a car would swerve just like that for the wall.
Wild guess is either: --he locked up the rears by mismatching revs --something broke. |
#60
SMG does have its benefits.
From what I can tell, he was braking to get into the infield section but screwed up the heel-toe downshift thus locking up the the rear end. Ouch! |
#62
I guess I agree, the sound is rough so you can't really tell if the engine revs real high (miss shift) but it does appear by the single skid mark that he locked the one wheel up. Too bad. Any chance that the damage is just body work?
#65
I am not familar with the track layout, but why would the driver be downshifting? The car was positioned in the middle of the track and does not appear to be slowing down for a turn. The car could be approarching some kind of turn on an oval track layout, but do you need to downshift for that?
#67
I think it was set up as a roval--a road course inside an oval.
#68
A limited slip diff only allows the tires to rotate freely (independently) to a certain degree, then the 'limited slip' portion kicks in making both tires turn in unison (to a degree, thus the 'limited slip'). |
#69
Another clip:
Spinning GTO (590k) |
#70
I'm looking at it (the Viper clip) and is it possible his left rear tire went down? I don't see a blowout
facebook.com/sctsracing 02 M3 SMG Coupe - prepared class BMW Club racer 08 135i 6sp - stock class BMW Club racer Photo gallery |
#71
I asked a firend of mine who is a track junkie, here's what he said:
I didn't see any lockup on the rear tires early in the incident, so I don't think it was a "money shift". I would guess the guy got on the brakes to start slowing for an upcoming turn, and also started to turn the wheel. He was braking too hard, and trailing throttle oversteer ensued (tail got light, and stepped out a little bit towards the driver's right since he was starting to turn the car to his left?) Then it looks like his reflexes weren't fast enough to correct for the tail stepping out, and off he went towards the wall! I just don't see enough steering input to create a trailing throttle oversteer situation. If you look at the front wheels just prior to hitting the wall, he is countersteering, but it seems to have no effect on the car's direction...leading me to believe that there was a rear lockup or tire failure or something that caused the car to dive directly into the wall like that. I'm going to check with a guy I know that has a viper and see if he knows about this incident. Curiousity has gotten the best of me.
I agree with Stahl on the Viper.
Something happened to lock the rears up. In a kart, it would be like "sticking" the motor at the end of a straight: rears lock and you're around faster than you can blink. I think it happens way too suddenly to be an overzealous trail-brake situation. Also, I don't think it was a "money shift," as when I think of that, I think of it happening during an upshift. It was either a mechanical failure (but there's no smoke) or a botched downshift like Stahl suggested. Off to the GTO...
#75
Ah, the GTO... a classic case of being "pushy loose" as the Nascar boys say.
Driver turned into the left-hand (last) part of the chicane slightly too early, was on the power early, then had to keep the wheel turned because he was 1) understeering or 2) running out of track. He should've been straightening the steering at that point, not adding or maintaining lock. The front tires bit, and snapped the rear end around. So that line error, coupled with excess steering input and gobs of throttle (and the engine getting up on the cam) at the exit = the spin.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
