Old 04-29-2010, 09:08 PM
bdavid13 bdavid13 is offline
Mein Auto: BMW
Finally test drove my first 740
Ok, car started right up then I hear tick tack from engine. Assuming the car is cold. I drove the car ran like a champ. Did not hear any noise while on the stop sign or during accelaration. I'm thinking lifter issues. Dealer/auto broker selling it fo $8800 but desperate for sale and willing to sell for $6500. 127k miles one owner. He's trying to get the car off his books.
Anyone have an idea what this noise is? Should I take the deal?
Old 05-01-2010, 01:54 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Sounds like a oil starvation issue... OR it sat for a long time.. Go back in a day or two unnanounced and start it again.. if I leave a car sit for a few weeks without running it all the oil drains into the pan..
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 05-02-2010, 10:40 AM
Oboyco Oboyco is offline
Mein Auto: 1998 740i
If the noise is coming from near the oil filter housing, it could be part of the fuel emissions system. This is normal on start up, check valve of some sort IIRC.
Old 05-03-2010, 07:29 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
if you are hearing this at idle, it is obviously not getting enough oil. if oil pressure is ok, then a flat lifter may be clogged with deposits from the oil or may just be broken and in need of replacement. i've looked at quite a few E38s with the problem of a flat lifter, this is going to prove to be an expensive job requiring the heads to be removed and everything else thats in the way. if the car is in great condition and you dont mind spending a bit of money on engine repairs, then this may be the right car. what year is it though? you will likely spend quite a bit of money on the car as long as you own it. i would try and find out what has been replaced on the car. certain parts need prove a need of replacement at or by certain mileage, like the water pump and hoses. if everything is original be prepaired for a load of repairs.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
HTML code is Off
