97 740iL - Transmission fail safe program - Bimmerfest - BMW Forums
Old 04-30-2010, 01:00 PM
Rick 04 Rick 04 is offline
Mein Auto: 740IL
Hey there, I have a 97 740iL and recently, the transmission fail safe program came on. I realize I will probably need to change my transmission soon, and I was wondering if anyone had a recommendation where I could get a good (used) tranny to purchase. I really dont want to go to the dealership, so...HELP. by the way, the car has 197k miles on it.
Old 05-11-2010, 08:47 AM
faviola faviola is offline
Mein Auto: 1998 BMW 740I
I'm having the same problem and have about the same mile...Did anyone reply to you? Or did you find a soluntion? Thanks
Old 05-11-2010, 09:20 AM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
Pull the codes. There are lots of reasons for it to go into failsafe that have nothing to do with the trans.
Old 06-21-2010, 12:09 AM
ngraz617 ngraz617 is offline
Mein Auto: 2011 750I X M sport
http://www.autosportsunlimited.com/
I heard this is without a doubt one of the best places to purchase a transmission or engine. I only wish I knew about them when I had a problem. Kurt Koeller is a really nice guy and has been helping me with problems I'm having and I didn't even do any business with him.
Old 09-20-2010, 08:25 PM
Chopstix Chopstix is offline
Mein Auto: 740i
Just a note, Check Battery first, then alternater, then cold intake sensor,
when all fails ask a repair tech. 8-)
Old 11-06-2010, 08:45 AM
tekazgtr1984 tekazgtr1984 is offline
Mein Auto: '95 E38 740i
Yup, check voltage (battery, alternator) first. Then check for fluid leaks around the transmission. Then you could get the car coded to see what faults there might be, if any.
I had the same issue on my E38, couldn't figure out what it was for the life of me. Finally, I called up an indy shop here and the guy guessed it could be a faulty neutral safety switch. I took my car to him, and sure enough, that's what it was. The connector had a bit of water in it, resulting in a communication between the TCM and the NSS. He cleaned it out, sprayed in some water repellant, put it back together and everything works like it should again.
Best of luck!
tekazgtr1984 (aka Tyler)
(9/94, GF61, JPN: M60B40, ZF 5HP30)
Old 11-07-2010, 03:53 PM
dtkw's Avatar
dtkw dtkw is offline
Mein Auto: 740iL
Okay, mine has the same problem. But mostly when I accelerate to pass some slow cars then the error message appeared on the display.
HTML code is Off
