#26
I'll try to be constructive as I am worried about your car.
This post is by someone else who was responding to a different unnecessary modification to the stock intake system.. Quote:
#27
Thank you, getting warmer to what i'm looking for. How exactly is my engine going to seize. The filter is protected from all sides (except the front). It's not in any of the pics but i built a water tight shield around it. Yes it will get wet in the rain, but will that really cause my engine to hydro lock? If you say yes, please explain. Thank you.
#28
Unencumbered by the thought process ![]() ![]() If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain. |
#29
ok here it goes, something constructive. honestly it is a good idea but first look at the cons and pros before attempting any of these tricks, remember that these cars will empty your pockets so saving a few hundred dollars now could put your engine and fragile components at risk. and they will not cost you $80
Everybody has! It's just not what you were hoping for.
Ok, seriously, your ingenuity is commendable, but your idea doesn't seem all that well thought out. Ballsy, yes. Smart, no.
![]() "The more you know, the more you don't know," Dave Chappelle ![]() "Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant WTT: Black Comfort Seats for Black Sport Seats. PM for info. |
#31
Summary..
Creative dumb idea not saying YOU are dumb. Just the idea. Good luck
#32
All I'm saying is that the 540i intake system can suck up A LOT of air. In any point at which your filter gets submerged in a puddle or any pool of water, guess what, that intake system is going to suck up water. Once it does that, game over. Do a search and you'll see people have actually experienced this even in a less aggressive intake system then yours. Now looking at the stock airbox setup , which actually performs quite well, you'll see that even if water were to enter the intake system, there are drain holes specifically located to prevent a hydro lock situation. This doesn't mean it prevents hydro-lock 100% however the odds are very different from your setup which doesn't provide these features which means the water only has one place to go, into the engine. Last edited by SoCaLE39; 04-30-2010 at 10:27 PM. |
#33
Anything else? Do you have a problem with a spec of dust i left somewhere, or that I changed my transmission fluid, after all, the Germans say not to touch it. |
#34
All parts used are very high quality (except the air filter i think) |
#35
Trust me, I love this car and want what's best for it. And yes, maybe I made a mistake with this set up, but until someone can truly explain to me why this will not work, I can't change my mind cuz someone called this set up a home depot hack job. |
#37
An intake is basically a giant shop vac, it can easily suck up water 5'
#38
im sorry 540ig5 but this is trully a dangerous idea. people have tried stuff like this before (look at bimmerforums) and have destroyed their engines. look for posts like "my car threw a rod" or stuff like that where their cars hydrolocked. if water gets in you are in a world of trouble. 4.4L engine so thats 0.55L of space within each cylinder at most (prolly less if they count the intake hoses and what not in their calculations), this is around how much water a poland springs water bottle holds. even one fourth to one half of that much water getting into a cylinder is good enough to destroy your engine. but then again im no expert but this is what the other forums say as well
![]() "Owning any german car is like hanukkah, every day another light" |
#39
I have no experience with water in an engine (and I hope you wont either), but from reading other's responses and picturing it in my mind, it seems plausible.
Unencumbered by the thought process ![]() ![]() If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain. Last edited by andyffer; 04-30-2010 at 10:51 PM. |
#41
mist going into that intake + sudden increase in pressure due to the volume change = loads of liquid going in. i really think you should do something about this asap before something bad happens to your engine
#42
Sorry, but can you be more specific, or should i say, rephrase that so I can understand exactly what you mean. Thanks.
#43
it might seem like you need a lot of water to get your engine hydrolocked, it might seem like you need to go over a puddle. but what happens (based on fluid mechanics, look up von karman and navier stokes if you dont believe me) is that the lower you go the fluid acts as if its more like a solid layer (or rather denser?). so lets say your travelling down the road at 60mph on a rainy day, the mist being produced from the cars in front of you and the water being sucked up from the layer of road your in will be in the direct path of your intake. the intake is confined and does not expand or contract, so when the mist enters the intake, the sudden pressure increase will turn that mist into liquid instantly and itl be sucked into one of the cylinders. when that cylinder gets to the compression stage, the cylinder will compress because of the momentum from the other cylinders, however liquid (especially water) is generally incompressible, so at high pressure they behave like solids so pretend you have a brick inside your cylinder and then you try to compress it. this will break your connecting rods (hence the term "threw a rod") and your engine will be in for a major overhaul and cost upwards of 3-4k if your lucky.
#44
So what you're saying is that once any amount of water gets on the filter, that water is guaranteed to wind up in your engine?
#46
where else do you think it will go? (if not right away, what will happen when the filter is saturated with water?)
#47
2002 M3 Cic / Topaz Metallic Blue 1998 540iA / Orient Metallic Blue SOLD 1989 635csi/ R.I.P 1986 325es/5 speed R.I.P 1999 328ic/5 speed (New) BMWCCA Member #366681 |
#48
I think there is not enough suction to make the relatively small amount of water on/in/around the filter to make that water travel all the way up to the engine. That's just what i think and I would love to be proven wrong here, rather then on a rainy day.
#49
well you can take this as theoretical or practical. if you do the calculations out, if you sit there and draw out the diagram and do the vectors for all the forces and calculate out all the flow profiles of the water entering the engine through the air intake, odds will be against you. the good part is, when it comes to practicality, you have better chances of this not happening. However, do you really want to take the chances of this happening to your car? even if the probabilty was as low as 1%? Also about the suction, air is being sucked into the engine, otherwise it wouldnt run. if your exposed to water, its like drowning. water will be sucked in, you do not need a lot of suction power. but its upto you, if you can live with the possibility of the engine hydrolocking, power to you. if you want to discuss this further, you can pm me
#50
You can clean your engine by shooting small amounts of water into the intake or a vacuum line. Rain water will not cause hydrolock. Let's not get silly. Ever clean an engine with solvent? I'm assuming you haven't. You literally suck liquid solvent up through a vacuum line. Guess what? No hydrolock. This has been common practice for the last....oh I don't know.....50 years or so.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
